Solved There are not messages in the PanelDue
Good afternoon,
I'm using the version firmware 3.2 and I have also try the version 3.2.2
I have try the version 3.2.9 and the version 3.2.11 in the PanelDue5i and in both of them it happens the following:
When I run this macro from the navigator the messages appear in the PanelDue. But, if I run it from the PanelDue as if it was a macro they don't appear in the PanelDue but yes in the navigator.
I think that it can be because I'm inside the macros in the PanelDue, how can I correct it?
Is there any command that I can send to make the PanelDue go to the home screen?
;Descarga de material M291 R"Retirando Material" P"Espere a que los LED se enciendan para retirar el filamento" S1 T0 ; Mensaje M400 M106 P2 S0 ; Apagar LED G4 S3 M106 P2 S255 ; Encender LED M300 S5000 P100 ; Emite un sonido M292 ; Sal del Mensaje G4 P200 ; Espera M300 S5000 P100 ; Emite un sonido M291 R"Retirando..." P"Compruebe que el material se ha retirado correctamente y espere a que termine el proceso" S1 T0 ; Mensaje G92 E0 ; Pone E a 0 M83 ; Posicion relativa G4 S3 G92 E0 ; Pone E a 0 M400 ; Termina datos M82 ; Posicion absoluta G10 P0 S0 R0 ; Establece temperatura M84 E0 ; Desabilita motor E M300 S5000 P100 ; Emite un sonido M292 ; Sal del Mensaje G4 P200 ; Espera M300 S5000 P100 ; Emite un sonido M400 ; Termina datos
Thank you in advance for your help,
Aitor
@Aitor this issue should be solved with paneldue-3.4.0-pre1.
Closing this thread here, if you still experiencing problems, re-open or best to start a new thread.
https://forum.duet3d.com/topic/24889/paneldue-3-4-0-pre1-released/6
