    Conditional commands in macro
    Gcode meta commands
    108
    • Madtraxx
      Madtraxx last edited by
      Hi all,
      I'm trying to get a conditional move command into a tool change macro, as with X being over 195 it will crash the lever into the actual tool change tab (ultimaker 3 style).
      For this I have the following command, yet whatever I try I cannot seems to get it right (as I keep getting a "Bad command" message
      • jay_s_uk
        jay_s_uk last edited by jay_s_uk
        Put it in {} brackets.
        so
        if {move.axes[0].machinePosition > 195}
        and then carry on as you were
        • Madtraxx
          I tried, yet I still get the error and lines 2 and 3 are executed even when X<195
            You don't need to use { } in that command. What version of RRF are you using?
            • T3P3Tony
              @Madtraxx
              what happens when you send:
              echo move.axes[0].machinePosition
              You can also add that to the command to check things are working as expected:
              if move.axes[0].machinePosition > 195.0
                  G90
                  G0 X196 Y175
              G90
              Also if you are still having issues please post the macro text here (not an image)
              www.duet3d.com
              • Madtraxx
                Madtraxx last edited by Madtraxx
                Currently I am using RepRapFirmware for Duet 2 WiFi/Ethernet 2.03 (2019-06-13b2). Beginner's mistake here i guess to assume I used 3.2.2 (but it was only the Duet WEb Control 3.2.2)...
                @T3P3Tony sending that command trhough the console gives me back the same "Bad command" message.
                • T3P3Tony
                  T3P3Tony administrators @Madtraxx last edited by
                  @Madtraxx yes, you need to upgrade to RRF3 to use conditional gcode
                  www.duet3d.com
                  • Madtraxx
                    I changed to DFF v3 and changed the needed config lines to make my printer operational again.
                    Running "echo move.axes[0].machinePosition" in the console I still get the following:
                    Also changing the macro to the code that @T3P3Tony mentioned also didn't seem to work.
                    • T3P3Tony
                      @Madtraxx is that 3.2? I ask because normally the upgrade is 2.5.1 ->3.0 ->3.1.1 or later as long as you are on 3.1.1 or later that command should work
                      I know i said RRF3 before I should have said RRF3.x (at least 3.1.1)
                      www.duet3d.com
                      • Madtraxx
                        Flashing the correct firmware this time (>3.3.1) has resolved the issue. Thanks for all the information!
