    Heater problems Duet2 Wifi
    • TokeDKundefined
      TokeDK
      I caused a heater cartridge short (I believe), I accidentally worn the wire insulation to the hot end down by overtightning the assembly.
      I replaced a blown 7.5a fuse, insulated the wires with electrical tape as an attempt to revive it.
      Now I'm having thermister faults...
      I changed the thermister as I thought that was the issue, but I'm getting VSSA faults on both the bed and hotend, after the bed has warmed up and while the hotend is warming up?
      I read that a heater cartridge short can cause VSSA fault, so should I assume that I need to replace the heater cartridge?
        I could have damaged the VSSA fuse on the board. Can you try the other heater terminals? E1 instead of E0?
        TokeDKundefined 1 Reply Last reply Reply Quote 0
        • TokeDKundefined
          TokeDK @Phaedrux
          @Phaedrux Do you mean switching the "terminals" so E1 --> E0?
          E0 (heated bed) works fine as far as I can tell although I had to do a PID autotune after the suspected short, and the bed is heating slower than I remember.
            The bed should be on the bed heater terminals? Is it a DC heated bed?
            • TokeDKundefined
              TokeDK @Phaedrux
              @Phaedrux Uhm, do you mean phsyical screw terminal? In that case it is, and yes it is DC.
              Apologies for dumb questions... Still learning 😄
                https://duet3d.dozuki.com/Wiki/Choosing_a_bed_heater
                https://duet3d.dozuki.com/Wiki/Hardware_Overview
                Usually the bed would be connected to the bed heater terminals since the bed is usually high current draw unless you are using a mosfet or ssr to switch a different power source.
                • TokeDKundefined
                  TokeDK
                  I did turn out to be a hot end short causing the weird errors. Closed.
