Duex5 Endstop Issue
@martin7404 said in Duex5 Endstop Issue:
So with Muldex that can sol e the U problem, but with 3 Z motors on duex and Bltouch on duetwifi?
I did try moving all three z axis motors to the wifi but my leveling was the same.
@3DPrintingWorld said in Duex5 Endstop Issue:
Then what ever issue you are having is very likely related to the endstop sensors and/or the wiring.
I have my 3 Z steppers and Z endstop sensors connected to my Duex5 and they all work without problem now that I am running firmware 3.2.2.
I have not seen this issue repeat since installing 3.2.2. Despite it being bad practice to have the endstop on a different board then the stepper. I will keep a eye on this should nozzle alignments not stay consistent as I often do multi material printing. The end goal is to move the y-axis to senseless homing which will make also room on the mainboard for the remaining endstop.
Despite it being bad practice to have the endstop on a different board then the stepper...
It's not bad practice, except that on Duet 3 there is one combination that is currently unsupported (endstop connected to main board and motor connected to expansion board).
@dc42 said in Duex5 Endstop Issue:
Ok, good to know! I would consider this problem solved since I am not seeing any issues since updating to 3.2.2
