    7x ClearPath SD motors
    371
    • djstreeundefined
      djstree
      Re: Clearpath Servo Motors and Step/Dir/Enable Pin Avaiability
      Hi!
      is it possible to use a PanelDue on CONN_SDCARD
      and simulaneously use the two STEP/DIR channels on CONN_LCD ?
      • djstreeundefined
        djstree
        Forgive the quick sketch ... Thinking about a breakout board like so.
          dc42 administrators @djstree
          @djstree said in 7x ClearPath SD motors:
          Hi!
          Yes.
            Those NL37WZ16 buffers have very nice output drive characteristics. Unfortunately they specify a minimum Vih of 0.7V * Vcc, which at VCC=5 is 3.5V. That's more than the 3.3V nominal (and possibly as low as 3.2V) provided on the expansion board connector.
            djstreeundefined 1 Reply Last reply Reply Quote 0
            • djstreeundefined
              djstree @dc42
              @dc42 good spot, thanks.. I'll find another part.
                If you feed +5V and IN- to the Clearpath input instead of IN+ and ground, then you could perhaps use SN74LVC06A powered from +3.3V.
                • djstreeundefined
                  djstree
                  Something along these lines? Agains, sorry for the sketch. I'm on the tablet!
                    Yes, that's what I had in mind.
                    • djstreeundefined
                      djstree
                      Along with some other I/O conns ...
                      • djstreeundefined
                        djstree @dc42
                        This post is deleted!
