Why did my print pause?
Filament Monitor
  • undefined
    alankilian
    I don't understand why my print paused.
    The reading from the filament monitor doesn't show anything out of range.
    Any ideas or anything I should grab next time it does this?
    3/1/2021, 12:13:38 PM m115
    FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.2 ELECTRONICS: Duet Ethernet 1.02 or later FIRMWARE_DATE: 2021-01-05
    3/1/2021, 12:12:55 PM M24
    Printing resumed
    3/1/2021, 12:12:30 PM m591 d0
    Duet3D rotating magnet filament monitor v3 with switch on pin e0stop, enabled, sensitivity 27.00mm/rev, allow 10% to 200%, check every 20.0mm, version 3, mag 130 agc 114, measured sensitivity 28.00mm/rev, min 55% max 104% over 5461.2mm
    3/1/2021, 11:43:48 AM Printing paused at X36.9 Y-4.2 Z0.6
    3/1/2021, 11:43:45 AM Resume state saved
    3/1/2021, 11:03:18 AM M32 "0:/gcodes/Divider_12.gcode"
    File 0:/gcodes/Divider_12.gcode selected for printing
    • undefined
      alankilian
      What causes NEGATIVE extrusion amounts to be measured?
      Extruder 0 reported 'tooLittleMovement'
      m122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2 running on Duet Ethernet 1.02 or later
      Board ID: 08DGM-95BLL-N6PSS-6JKD2-3S46Q-1JSRL
      Used output buffers: 3 of 24 (20 max)
      Static ram: 23460
      Dynamic ram: 68540 of which 60 recycled
      Never used RAM 20020, free system stack 108 words
      Tasks: NETWORK(ready,177) HEAT(blocked,309) MAIN(running,452) IDLE(ready,19)
      Owned mutexes:
      Last reset 02:34:18 ago, cause: software
      Last software reset at 2021-03-01 12:14, reason: User, GCodes spinning, available RAM 19920, slot 0
      Error status: 0x00
      Aux0 errors 0,0,0
      MCU temperature: min 22.5, current 23.9, max 24.5
      Supply voltage: min 12.7, current 12.9, max 13.2, under voltage events: 0, over voltage events: 0, power good: yes
      Driver 0: position 25961, standstill, SG min/max 0/557
      Driver 1: position 25961, standstill, SG min/max 0/534
      Driver 2: position 25961, standstill, SG min/max 0/546
      Driver 3: position 0, standstill, SG min/max 0/341
      Driver 5: position 0
      Driver 6: position 0
      Driver 7: position 0
      Driver 8: position 0
      Driver 9: position 0
      Driver 10: position 0
      Driver 11: position 0
      Date/time: 2021-03-01 14:48:25
      Slowest loop: 73.64ms; fastest: 0.10ms
      === Storage ===
      Free file entries: 9
      SD card longest read time 2.1ms, write time 4.9ms, max retries 0
      DMs created 83, maxWait 917775ms, bed compensation in use: none, comp offset 0.000
      === MainDDARing ===
      Scheduled moves 7394, completed moves 7394, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
      === AuxDDARing ===
      Heater 0 is on, I-accum = 0.7
      Heater 1 is on, I-accum = 0.7
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      Daemon is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 14.69ms; fastest: 0.07ms
      HTTP sessions: 1 of 8
      Interface state active, link 100Mbps full duplex
      === Filament sensors ===
      Extruder 0: pos 46.41, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0
      M591 D0
      Duet3D rotating magnet filament monitor v3 with switch on pin e0stop, enabled, sensitivity 27.00mm/rev, allow 10% to 200%, check every 20.0mm, version 3, mag 130 agc 114, measured sensitivity 27.59mm/rev, min -1% max 103% over 5622.2mm
      • undefined
        alankilian
        ARGH!!!!!
        Nevermind.
        The damn filament end is stuck in the spool.
        This darn MatterHackers filament has a giant hook on it so it doesn't let go of the spool and sometimes I forget to get in there with a knife and cut it off.
        • undefined
          alankilian
          By the way, this is EXACTLY why I bought this in the first place.
          The MatterHackers MHBuild series filament just gets stuck to the spool at the end and didn't trigger my filament runout switch, so this was a COMPLETE success for the filament motion sensor.
          • undefined
            T3P3Tony administrators
            Glad to hear it!
            www.duet3d.com
            1 out of 5
