    Tevo Little monster crashes at enstop
    303
    • Captainstabalotundefined
      Captainstabalot
      I just finished wiring up the Duet 2 wifi on my TLM, im having a problem where the printer doesnt stop and the enstop and continues to travel until i emergency stop. with the M119 commend it shoes all three endstops triggered, but still crashed with the G28 command. Im very new to RR firmware as i just switched from marlin. Any help is appriciated!
      ; homedelta.g
      ; generated by RepRapFirmware Configuration Tool v3.2.3 on Wed Mar 03 2021 12:58:55 GMT-0800 (Pacific Standard Time)
      G91 ; relative positioning
      G1 H1 X705 Y705 Z705 F1800 ; move all towers to the high end stopping at the endstops (first pass)
      G1 H2 X-5 Y-5 Z-5 F1800 ; go down a few mm
      G1 H1 X10 Y10 Z10 F360 ; move all towers up once more (second pass)
      G1 Z-5 F6000 ; move down a few mm so that the nozzle can be centred
      G90 ; absolute positioning
      G1 X0 Y0 F6000 ; move X+Y to the centre
      M550 P"My Printer" ; set printer name
      M665 R155 L397.19 B85 H515 ; Set delta radius, diagonal rod length, printable radius and homed height
      M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them
      M551 P"password" ; set password
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S1 ; enable FTP
      M586 P2 S1 ; enable Telnet
      M92 X80.00 Y80.00 Z80.00 E663.00 ; set steps per mm
      M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
      M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2)
      M906 X1000 Y1000 Z1000 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 Z0 S1 ; set minimum Z
      M574 Z1 S1 P"zstop" ; configure active-high endstop for low end on Z via pin zstop
      M950 S0 C"exp.heater7" ; create servo pin 0 for BLTouch
      G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
      M557 R150 S45 ; define mesh grid
        Does M119 show not triggered when the endstops are not pressed and triggered when they are pressed?
        Are you sure you've go the endstops connected to the right terminals to match the motors? See here: https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareDeltaPrinter#Section_Testing_the_motors_and_endstops_individually
        Also, these links will be handy in case you haven't seen them yet
        https://duet3d.dozuki.com/Wiki/Calibrating_a_delta_printer
        Captainstabalotundefined 1 Reply Last reply Reply Quote 0
          Captainstabalot
          3/3/2021, 2:14:31 PM m119
          Endstops - X: at min stop, Y: at min stop, Z: at min stop, Z probe: not stopped
          I verfied my wireing. Then i manually triggered each endstop and the corresponding LED turns off. Its my y axis this is actuing strange. when i have the x and z stop without issue, but then the y stepper starts jamming before it gets to the endstop. In frustration i pushed it the rest of the way and it counted as home. If i use home all again after it had been shoved to the endstop it acts fine. I am following the wiki for calibration but im stuck at homing right now.
            Captainstabalot @Phaedrux
            @Phaedrux If i hold the printer home before start it will home fine. I can move it down to the bed and when i bring it to the max it stops and the endstops properly. but as soon as i send a G28 its comes up and crashes.
              Can you provide the results of sending M122 and M98 P"config.g"?
                You've gone through this part?
                Testing the motors and endstops individually
                You can test the three tower motors individually by putting the printer in relative mode (G91 command) and then using the G1 command with H2 parameter. For example, sending G1 S2 X10 should move the X carriage up 10mm, and sending G1 H2 X-10 should move the X carriage down 10mm. Similarly for Y and Z. If a motor moves the wrong way, you can reverse it by changing the corresponding M569 command in config.g. For example, if the X motor moves the wrong way, change M569 P0 S1 to M569 P0 S0.
                When you have the motors moving the right way, test the endstops. See Connecting endstop switches.
                It is essential that the endstop switch connected to the X endstop input is on the same tower as the motor connected to the X motor output that drives the carriage on the X tower. A common mistake is to have endstop or motor connections swapped. So check this carefully. Make sure that the carriage that moves when you send a G1 S2 X command is on the same tower as the endstop that when triggered shows as X triggered in M119 or in the Machine Properties page of DWC.
                After that you can check the combined effects of endstop switches and motors. Send G91 as before, but use H1 instead of H2 in the G1 commands. Each motor should stop early when you trigger the corresponding endstop.
                  @Phaedrux said in Tevo Little monster crashes at enstop:
                  M122
                  M122
                  RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05 running on Duet WiFi 1.02 or later
                  Board ID: 0JD0M-9P6B2-NJ4S8-6JKDJ-3S46K-TS6QM
                  Used output buffers: 1 of 24 (8 max)
                  Static ram: 25712
                  Dynamic ram: 92464 of which 536 recycled
                  Exception stack ram used: 480
                  Never used ram: 11880
                  Tasks: NETWORK(ready,744) HEAT(blocked,808) MAIN(running,3824) IDLE(ready,160)
                  Owned mutexes:
                  Last reset 00:52:07 ago, cause: power up
                  Last software reset at 2021-03-03 15:21, reason: User, spinning module GCodes, available RAM 11944 bytes (slot 0)
                  Error status: 0
                  Free file entries: 10
                  MCU temperature: min 23.4, current 23.8, max 27.4
                  Supply voltage: min 0.3, current 24.1, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
                  Driver 0: standstill, SG min/max 78/345
                  Driver 1: standstill, SG min/max 96/337
                  Driver 2: standstill, SG min/max 49/325
                  Date/time: 2021-03-03 16:45:29
                  Slowest loop: 5.07ms; fastest: 0.05ms
                  Hiccups: 0, FreeDm: 160, MinFreeDm: 154, MaxWait: 361900ms
                  === DDARing ===
                  Scheduled moves: 141, completed moves: 141, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
                  Segments left: 0
                  Movement lock held by null
                  http is ready with "M122 " in state(s) 0
                  telnet is idle in state(s) 0
                  file is idle in state(s) 0
                  serial is idle in state(s) 0
                  aux is idle in state(s) 0
                  daemon is idle in state(s) 0
                  queue is idle in state(s) 0
                  Code queue is empty.
                  === Network ===
                  Slowest loop: 80.14ms; fastest: 0.00ms
                  HTTP sessions: 1 of 8
                  • WiFi -
                    Network state is running
                    WiFi firmware version 1.23
                    WiFi MAC address 48:3f:da:88:8a:06
                    WiFi Vcc 3.36, reset reason Turned on by main processor
                    WiFi flash size 4194304, free heap 22832
                    WiFi IP address 10.0.0.33
                    WiFi signal strength -40dBm, reconnections 0, sleep mode modem
                  3/3/2021, 4:46:53 PM M98 P"config.g"
                  HTTP is enabled on port 80
                  FTP is enabled on port 21
                  TELNET is enabled on port 23
                  Warning: M950 command is not supported
                  Warning: M308 command is not supported
                  Error: G29: Must home printer before bed probing
                    Ok, so your config.g is formatted for RRF3, but your duet only has RRF2 installed. Updating your firmware should help get things back on track.
                    If you still have access to DWC. Upload these 3 zip files, one at a time in the system tab. Don't extract them. Reboot after each. Use M115 to verify the firmware has been applied.
                    https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
                    https://github.com/Duet3D/RepRapFirmware/releases/download/3.2.2/Duet2and3Firmware-3.2.2.zip
                    That will get your firmware and DWC up to date.
                    After that's done, send M122 and M98 P"config.g" again and report the response. Homing will likely work better then as well.
                      Captainstabalot
                      G1 H2 X-10
                      3/3/2021, 5:18:33 PM m122
                      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2.2 running on Duet WiFi 1.02 or later
                      Used output buffers: 3 of 24 (13 max)
                      Static ram: 23460
                      Dynamic ram: 72436 of which 24 recycled
                      Never used RAM 16160, free system stack 191 words
                      Tasks: NETWORK(ready,169) HEAT(blocked,308) MAIN(running,451) IDLE(ready,20)
                      Owned mutexes: WiFi(NETWORK)
                      Last reset 00:00:19 ago, cause: software
                      Last software reset at 2021-03-03 17:18, reason: User, GCodes spinning, available RAM 16124, slot 0
                      Error status: 0x00
                      Aux0 errors 0,0,0
                      MCU temperature: min 24.9, current 25.4, max 25.9
                      Supply voltage: min 24.0, current 24.2, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
                      Driver 0: position 70856, standstill, SG min/max not available
                      Driver 1: position 70856, standstill, SG min/max not available
                      Driver 2: position 70856, standstill, SG min/max not available
                      Driver 5: position 0
                      Driver 6: position 0
                      Driver 7: position 0
                      Driver 8: position 0
                      Driver 9: position 0
                      Driver 10: position 0
                      Driver 11: position 0
                      Date/time: 2021-03-03 17:18:32
                      Cache data hit count 22939044
                      Slowest loop: 5.47ms; fastest: 0.21ms
                      === Storage ===
                      SD card longest read time 3.4ms, write time 0.0ms, max retries 0
                      === MainDDARing ===
                      === AuxDDARing ===
                      Segments left: 0
                      HTTP is idle in state(s) 0
                      Telnet is idle in state(s) 0
                      File is idle in state(s) 0
                      USB is idle in state(s) 0
                      Aux is idle in state(s) 0
                      Trigger is idle in state(s) 0
                      Queue is idle in state(s) 0
                      LCD is idle in state(s) 0
                      Daemon is idle in state(s) 0
                      === Network ===
                      Slowest loop: 16.17ms; fastest: 0.00ms
                      • WiFi -
                        Network state is active
                        WiFi firmware version 1.25
                        WiFi flash size 4194304, free heap 24400
                        WiFi signal strength -44dBm, mode 802.11n, reconnections 0, sleep mode modem
                        Clock register 00002002
                      3/3/2021, 5:19:04 PM M98 P"config.g"
                      FTP is disabled
                      TELNET is disabled
                      Awesome! ok i am homing properly now. Thank you for your time and help im going to follow the Delta calibration you sent me and hope all goes well from here. Thanks again!
