Duet Expansion Board Connectors
I think the T1 connector is positioned wrong.
Can it be pulled off from the pins and replaced in the correct orientation, without damage?
Thanks.
Yes it does appear to be flipped around.
Is that a new board? Would you like an exchange?
It should be possible to pull it off and flip it around carefully maybe with a little heat on the pins from an iron to loosen it, but if you're not comfortable with that contact your vendor and initiate an exchange.
@Phaedrux said in Duet Expansion Board Connectors:
Yes it's a new board.
I didn't know if the plastic part was held just by friction or if they pins were somehow "swaged" into the plastic.
Best to play it safe and exchange it.
In the meantime I can order another one.
Thanks.
