    Duet2 + Breakout Board with external stepper driver
    • Steppenleguanundefined
      Steppenleguan
      Hey guys,
      i´m pretty new when it comes to duets and building printers in general but I´m currently working on a project that uses a dual z axis motors (Nema23 , 4,2A) with external stepper drivers (DM542T).
      I have problems to make the motors run. I tried it with an Arduino setup and wired all neg inputs in parallel and connected it to the Arduino (also the ENA+) and it worked just fine. Sadly i cannot manage to get the integration of the drivers in the config.g file.
      What is the output voltage of the breakout boards PUL+ signal? The driver demands a 2k Ohms resistor with 24V signals.
      Also what is the max current and e steps I should set for an external driver in the config.g ?
      I used the guide of a dude named betrue3d.dk to set the z axis up, but it didn´t work.
      Do i need to use things like "Taa:bb:cc:dd (firmware 1.21 and later) Minimum driver step pulse width, step pulse interval, direction setup time and direction hold time, in microseconds" value when setting up an external driver? I don´t seem to understand the instructions there.
      It would be nice to get your help. Thanks!
      fcwiltundefined droftartsundefined 3 Replies Last reply Reply Quote 0
      • fcwiltundefined
        fcwilt @Steppenleguan
        @Steppenleguan said in Duet2 + Breakout Board with external stepper driver:
        From the documentation:
        The Duet Expansion Breakout Board uses a differential output signal of -3.6V to +3.6V. The differential outputs help the LEDs in the optocouplers in most drivers turn off faster. Also they are compatible with drivers that accept RS485 signal levels instead of 5V. Most external drivers are quite happy with the 3.6V differential signals. However, for those few drivers that really do need 5V, you can achieve this by connecting STEP+ from your driver to +5V, which is available on the H6_PWM and/or H7_PWM pin headers (see wiring diagram above), and STEP- for your driver to STEP- on the expansion board. Similarly for DIR and ENA.
        Depending on the driver, your ENA input may be a Disable input, not an Enable input. You can fix this by swapping the ENA+ and ENA- wires.
        You don't set the current for an external driver in config.g.
        The steps/mm set in config.g depends on the settings of the external driver and your hardware.
        For my printer with 20 tooth pulleys on the stepper and the stepper driver set to 8192 steps per revolution the steps/mm in config.g was 204.75. That value was computed based on a 20 tooth pulley creating 40 mm of movement per revolution - 8192 / 40 = 204.75.
        Start with these values: T2:2:10:10
          droftarts administrators @Steppenleguan
          @Steppenleguan Your driver uses 0-5V signalling; see https://www.omc-stepperonline.com/download/DM542T.pdf
          Pulse signal: In single pulse (pulse/direction) mode, this input represents pulse signal, each rising edge active; 4-5V when PUL-HIGH, 0-0.5V when PUL-LOW.
          To set 0-5V signalling, see https://duet3d.dozuki.com/Wiki/Duet_Expansion_Breakout_Board#Section_Notes
          Section 9 of the pdf shows the signalling; it looks like it should be T2.5:2.5:5:5, but YMMV.
            Max current and microstepping are set by the DIP switches on the external driver; you don't have to set them in config.g. You will have to set the steps per mm (M92), so the Duet knows how many steps to send to the driver to move it 1mm.
            Do you mean this one? https://betrue3d.dk/duet-wifieth-use-m584-to-autolevel-or-sync-z-axis-using-2-or-more-motors/
            I can see quite a lot of issues and errors with that guide. If you have your Z motors connected to different stepper motor drivers, then use our guide: https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors
            If that doesn't help, please post your config.g and relevant bed/homing files, and send M122 to the Duet and post response, to show firmware version and diagnostics.
            Steppenleguanundefined 1 Reply Last reply Reply Quote 1
              Steppenleguan @droftarts
              Yes, i was using this guide. At least his guide was understandable for a non gcode and native english speaker 😄
              I know i have a lot of finetuning to do, but you can find the config.g for this project here:
              ; generated by RepRapFirmware Configuration Tool v3.2.3 on Sun Feb 28 2021 15:17:04 GMT+0100 (Mitteleuropäische Normalzeit)
              M550 P"R2-3D2"                                     ; set printer name
              M669 K1                                            ; select CoreXY mode
              ; Define Drives
              ; Physical Drive connection
              M569 P0 S1 ; Drive 0 X
              M569 P1 S1 ; Drive 1 Y
              ; M569 P2 S0 ; Left z-motor (original Z)
              M569 P3 S0 ; Drive3 [Extruder 1] - new Extruder 1 [ENABLED]
              M569 P4 S0 ; Drive4 [Extruder 2] - new Extruder 2 [ENABLED]
              M569 P5 R1 T2:2:10:10 S0 ; Extruder0 - BreakoutBoard_Driver5 - new Z Axis Left
              M569 P6 R1 T2:2:10:10 S0 ; Extruder1 - BreakoutBoard_Driver6 - new Z Axis Right
              ;Pnnn Motor driver number
              ;Snnn Direction of movement of the motor(s) attached to this driver: 0 = backwards, 1 = forwards (default 1)
              ;Rnnn Driver enable polarity: 0 = active low, 1 = active high, -1 = driver is always disabled and is not monitored (default 0)
              ;Tnnn (firmware 1.14 and later) Minimum driver step pulse width and interval in microseconds
              ;Taa:bb:cc:dd (firmware 1.21 and later) Minimum driver step pulse width, step pulse interval, direction setup time and direction hold time, in microseconds
              ;Dnn (firmware 2.0 and later, only applies to TMC2660, TMC22xx, TMC2160, TMC5160 and TMC5161 stepper drivers) Driver mode: 0=constant off time, 1=random off time, 2=spread cycle, 3=stealthChop or 		stealthChop2 ;mode 3 for TMC22xx/TMC2160/TMC516x only). The default is spreadCycle for TMC2660, TMC2160 and TMC516x drivers, and stealthChop2 for TMC22xx.
              ;In stealthChop mode the drivers will switch over to spreadCycle automatically at high speeds, see the V parameter.
              ;Fnn (firmware 2.02 and later) Off-time in the chopper control register, 1 to 15
              ;Cnnnn (firmware 2.0 and later, only applies to TMC2660, TMC22xx, TMC2160 and TMC516x stepper drivers) Lowest 17 bits of the chopper control register value.
              ;Bnn (firmware 2.02 and later) Blanking time (tbl) in the chopper control register, 0 to 3. See the TMC driver datasheet.
              ;Hnn (firmware 2.02 and later) thigh parameter for those stepper driver chips that support it, e.g. TMC5160 and TMC2160. Send M569 P# (where # is the driver number) with no additional parameters to see how this ,translates into mm/sec. See also the V parameter.
              ;Yaa:bb or Yaa:bb:cc (firmware 2.02 and later) Hysteresis start, end and decrement values in the chopper control register. See the TMC driver datasheet for the meaning.
              ;Vnnn (firmware 2.02 and later) tpwmthrs parameter for those stepper driver chips that support it. This is the interval in clock cycles between 1/256 microsteps below which the drivers will switch from stealthChop ;to to spreadCycle mode. Only applies when the driver is configured in stealthChop mode. Typical value are from 100 (high speed) to 4000 (low speed). Send M569 P# (where # is the driver number) with no additional ;parameters to see how this translates into mm/sec.
              ; M569 P7 S1 ; Extruder2 - Physical Tool 2
              ; M569 P8 S1 ; Extruder3 - Physical Tool 3
              ; M569 P9 S1 ; Extruder4 - Physical Tool 4
              M584 X0 Y1 Z5:6 E3:4 P3                        					; set drive mapping Driver 0 For X, 1 for Y, Z=5:6, Extruder 3:4
              ; M671 X-20:220 Y0:0 S0.5 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis ; copied from guide
              M350 X16 Y16 E16:16 I1                  					; configure microstepping with interpolation
              M92 X80.00 Y80.00
              M92 Z800:800	           							; set steps per mm
              E92 E400:400
              M566 X6000.00 Y6000.00 Z60.00:60.00 U60.00 E120.00:120.00            	  	; set maximum instantaneous speed changes (mm/min)
              M203 X30000.00 Y30000.00 Z1000:1000 U1000 E1800.00:1800.00	          	; set maximum speeds (mm/min)
              M201 X5000.00 Y5000.00 Z250:00:250.00 U250.00 E250:250           		; set accelerations (mm/s^2)
              M906 X2000 Y2000 I0                   						; set motor currents (mA) and motor idle factor in per cent
              M906 E800:800 I50
              M84 S30                                            				; Set idle timeout
              M208 X800 Y800 Z760:760 S0                   	   ; set axis maxima
              M574 X1 S1 P"xstop"                                ; configure active-high endstop for low end on X via pin xstop
              M574 Y1 S1 P"ystop"                                ; configure active-high endstop for low end on Y via pin ystop
              M574 Z2 S1 P"e0stop"
              M574 Z1 S2                                         ; configure Z-probe endstop for low end on Z
              M950 S0 C"exp.heater7"                             ; create servo pin 0 for BLTouch
              M558 P9 C"^zprobe.in" H5 F120 T6000                ; set Z probe type to bltouch and the dive height + speeds
              G31 P500 X0 Y0 Z2.5                                ; set Z probe trigger value, offset and trigger height
              M557 X15:785 Y15:785 S20                           ; define mesh grid
              M308 S0 P"bedtemp" Y"thermistor" T100000 B4138     ; configure sensor 0 as thermistor on pin bedtemp
              M307 H0 B0 S1.00                                   ; disable bang-bang mode for the bed heater and set PWM limit
              M143 H0 S180                                       ; set temperature limit for heater 0 to 180C
              M308 S1 P"spi.cs1" Y"rtd-max31865"                 ; configure sensor 1 as thermocouple via CS pin spi.cs1
              M143 H1 S400                                       ; set temperature limit for heater 1 to 400C
              M308 S2 P"spi.cs2" Y"thermocouple-max31856"        ; configure sensor 2 as thermocouple via CS pin spi.cs2
              M950 H2 C"e1heat" T2                               ; create nozzle heater output on e1heat and map it to sensor 2
              M307 H2 B0 S1.00                                   ; disable bang-bang mode for heater  and set PWM limit
              M143 H2 S400                                       ; set temperature limit for heater 2 to 400C
              M950 F0 C"fan0" Q500                               ; create fan 0 on pin fan0 and set its frequency
              M106 P0 S0 H-1                                     ; set fan 0 value. Thermostatic control is turned off
              M950 F1 C"fan1" Q500                               ; create fan 1 on pin fan1 and set its frequency
              M106 P1 S1 H1 T45                                  ; set fan 1 value. Thermostatic control is turned on
              M950 F2 C"fan2" Q500                               ; create fan 2 on pin fan2 and set its frequency
              M106 P2 S1 H2 T45                                  ; set fan 2 value. Thermostatic control is turned on
              M563 P1 D0 H1 F0                                   ; define tool 1
              G10 P1 X0 Y0 Z0                                    ; set tool 1 axis offsets
              G10 P1 R0 S0                                       ; set initial tool 1 active and standby temperatures to 0C
              M575 P1 S1 B57600                                  ; enable support for PanelDue
              and here the bed.g
              ; bed.g
               G29  ; probe the bed and enable compensation
              ;G28 ; home
              ;M401 ; deploy Z probe (omit if using bltouch)
              ;G30 P0 X20 Y100 Z-99999 ; probe near a leadscrew, half way along Y axis
              ;G30 P1 X180 Y100 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors
              ;M402 ; retract probe (omit if using bltouch) ;also copied from instructions
              I don´t think the gcode in your guide is too easy to understand. Maybe you have some tips for me. For now, BL Touch is disabled, as i am missing some resistors to getting the 3.3V Signal output.
                @Steppenleguan Okay...
                First, firmware version? Send M115 or M122 and post reply.
                These timings are still too fast. Is the problem that the Z doesn't move at all? Once you have the signal voltage correct (0 to 5V), increase the first two numbers. Try T2.5:2.5:10:10 and if that doesn't work T5:5:10:10.
                M671 X-20:220 Y400:400 S0.5
                You need this line to level the bed. Your M208 is M208 X800 Y800 Z760:760 S0, so I guess your leadscrews are at something like M671 X-50:850 Y0:0 S0.5
                But make sure the motor on the left (at X-50) is plugged into stepper driver 5, and the motor on the right is plugged into stepper driver 6 (defined by M584 ... Z5:6 ... ).
                M92 X80.00 Y80.00
                E92 E400:400
                A few errors here. E92 is not a valid gcode command. for M566, M203, and M201, each axis only takes ONE value, except E which takes a value for each E axis. Remove the U values. Try this instead:
                M92 X80.00 Y80.00 Z800 E400:400                 ; set steps per mm
                M566 X6000.00 Y6000.00 Z60.00 E120.00:120.00    ; set maximum instantaneous speed changes (mm/min)
                M203 X30000.00 Y30000.00 Z1000 E1800.00:1800.00 ; set maximum speeds (mm/min)
                M201 X5000.00 Y5000.00 Z250.00 E250:250         ; set accelerations (mm/s^2)
                M906 E800:800 I50
                Be aware that setting M906 I0 will mean motors turn off after the idle timeout period, and will need to be rehomed or will lose position.
                For the bed.g, change the probing points to the size of your bed. You shouldn't need the M401 and M402 commands:
                ; G29  ; probe the bed and enable compensation (I would comment out this line, and do mesh compensation separately)
                G28 ; home
                G30 P0 X15 Y400 Z-99999 ; probe near a leadscrew, half way along Y axis
                G30 P1 X785 Y400 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors
                What board version is you Duet 2 WiFi, and what version BLTouch? Because it's only early Duet 2 WiFi boards that can't cope with higher voltages on the Probe.In, and only early versions of BLTouch that don't work happily on 3.3V or 5V. It's unlikely you have early versions of both, so probably no need for resistors, or cutting the trace. See https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_For_all_Duet_2_WiFi_Ethernet_boards_prior_to_version_1_Num_04
                I would try the BLTouch on 3.3V and see if it works.
                  @droftarts Sorry, here, the M122. The system is moving by now. I just left out the resistor on the PUL+ and it worked. The speed is a bit lackluster and the homing doesn´t yet work, but ill find out tomorrow. Up until now, thanks a lot for your help!
                  You will also find homeall.g and homez.g
                  M122
                  RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2.2 running on Duet WiFi 1.02 or later
                  Board ID: 08DJM-9178L-L2MS8-6J9DJ-3S46S-TVHUN
                  Used output buffers: 3 of 24 (20 max)
                  Static ram: 23460
                  Dynamic ram: 73604 of which 24 recycled
                  Never used RAM 14992, free system stack 191 words
                  Tasks: NETWORK(ready,217) HEAT(blocked,322) MAIN(running,449) IDLE(ready,20)
                  Owned mutexes: WiFi(NETWORK)
                  Last reset 00:01:06 ago, cause: power up
                  Last software reset at 2021-03-04 15:53, reason: User, GCodes spinning, available RAM 14992, slot 1
                  Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
                  Error status: 0x00
                  Aux0 errors 8,8,8
                  MCU temperature: min 29.0, current 31.4, max 31.8
                  Supply voltage: min 23.9, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
                  Driver 0: position 0, standstill, SG min/max not available
                  Driver 1: position 0, standstill, SG min/max not available
                  Driver 2: position 0, standstill, SG min/max not available
                  Driver 5: position 0
                  Driver 6: position 0
                  Driver 7: position 0
                  Driver 8: position 0
                  Driver 9: position 0
                  Driver 10: position 0
                  Driver 11: position 0
                  Date/time: 2021-03-04 19:58:05
                  Cache data hit count 79494073
                  Slowest loop: 7.99ms; fastest: 0.21ms
                  === Storage ===
                  Free file entries: 10
                  SD card longest read time 10.2ms, write time 0.0ms, max retries 0
                  === MainDDARing ===
                  === AuxDDARing ===
                  Segments left: 0
                  Movement lock held by null
                  HTTP is idle in state(s) 0
                  Telnet is idle in state(s) 0
                  File is idle in state(s) 0
                  USB is idle in state(s) 0
                  Aux is assembling a command in state(s) 0
                  Trigger is idle in state(s) 0
                  Queue is idle in state(s) 0
                  LCD is idle in state(s) 0
                  Daemon is idle in state(s) 0
                  Code queue is empty.
                  === Network ===
                  Slowest loop: 30.24ms; fastest: 0.00ms
                  HTTP sessions: 1 of 8
                  - WiFi -
                  Network state is active
                  WiFi firmware version 1.25
                  WiFi MAC address 98:f4:ab:d1:e4:90
                  WiFi Vcc 3.40, reset reason Turned on by main processor
                  WiFi flash size 4194304, free heap 25784
                  WiFi IP address 192.168.2.125
                  WiFi signal strength -59dBm, mode 802.11n, reconnections 0, sleep mode modem
                  Clock register 00002002
                  Homeall
                  ; homeall.g
                  ; called to home all axes
                  M584 Z2 		; Split Z into 2 (Z+U)
                  G1 Z250 U250 F2000 H1 	; Move up to 250mm in the +Z direction. S1 to stop if endstop is triggered
                  G1 H1 X-805 Y-805 F3600 ; move quickly to X or Y endstop and stop there (first pass)
                  G1 H1 X-805             ; home X axis
                  G1 H1 Y-805             ; home Y axis
                  G1 X5 Y5 F6000          ; go back a few mm
                  G1 H1 X-805 F360        ; move slowly to X axis endstop once more (second pass)
                  G1 H1 Y-805             ; then move slowly to Y axis endstop
                  ; G90                     ; absolute positioning
                  G1 Z-2 U-2 F600 H2 	; Move 2mm in the -Z direction - (I'm not sure what S2 is for?)
                  G1 Z+3 U+3 F100 H1 	; Move slowly 3mm in the +Z direction, stopping at the homing switch
                  M584 Z5:6 		; Join U to Z again (pay attention to drive numbers used)
                  G1 Z-5 F3000 		; Move back again 5mm in the -Z direction
                  G90 			; Back to absolute mode
                  ;G91                    ; relative positioning
                  ;G1 Z5 F100             ; lift Z relative to current position
                  ;G90                    ; absolute positioning
                  Homez
                  ; homez.g
                  ; called to home the Z axis
                  G91 					; Relative mode
                  G1 Z3 U3 F100 H1 			; Move slowly 3mm in the +Z direction, stopping at the homing switch
                  It also says it couldn´t find 0:/filaments , does this mean i should add a folder on the SD card with that name?
