    First Benchy printed - Issues
    3D Printing General Chat
    673
    • TF_Sinthorasundefined
      TF_Sinthoras
      Hello Community,
      I have build up my BLV MGN Cube (XY-Core) with a Duet2 Wifi and now I get everything to Work. I did the PID Calibration of Heatbed and Hotend, Calibration via 20mm Cube and now I have printed my first Benchy. I get some Issues and have no Idea how to go on, can you help me with your experience? Material is PETG from "DasFilament". I run this Material on my Ender 3 already and have quite good results.
      Here the Pictures:
      Ripple
      Ripple
      sudden little Overextrusion
      fine Stringing
      fine Stringing
      You have any ideas? Thanks a lot for everything.
      Tobias
      theruttmeisterundefined Stephen6309undefined 2 Replies Last reply Reply Quote 0
      • Vetiundefined
        Veti
        post your config
          TF_Sinthoras
          ; generated by RepRapFirmware Configuration Tool on Tue Oct 09 2018 13:27:56 GMT+0300
          M80 ; Turns on the ATX power supply
          M550 P"BLV MGN CUBE Z-565" ; Set machine name
          M669 K1 ; Select CoreXY mode - war 667
          M552 S1 ; Enable network
          M587 S"BlackIC" P"/Taschi99" ; Configure access point. You can delete this line once connected
          M586 P0 S1 ; Enable HTTP
          M586 P1 S0 ; Disable FTP
          M586 P2 S0 ; Disable Telnet
          M569 P0 S1 ; Drive 0 goes backwards blv: its was S1
          M569 P1 S1 ; Drive 1 goes backwards blv: its was S1
          M569 P3 S0 ; Drive 3 goes backwards WAS 0
          M584 X0 Y1 Z2 E4 ; NEW set drive mapping Z2 left, Z4 right
          M350 X16 Y16 Z16 E16 I1 ; Configure microstepping with interpolation war 16 16 16 1
          M92 X200 Y200 Z400 E409.27 ; Set steps per mm for Bondtech. X200 Y200 Z400 E415 ; Kali: X198.51 Y198.90
          M566 X700 Y700 Z24 E2000 ; Set maximum instantaneous speed changes (Jerk) (mm/min) Z240
          M203 X18000 Y18000 Z250 E2000 ; Set maximum speeds (mm/min) z1000
          M201 X3000 Y3000 Z100 E4000 ; Set accelerations (mm/s^2) z100
          M906 X1600 Y1600 Z1600 E1600 I30 ; Set motor currents (mA) and motor idle factor in per cent z800
          M84 S120 ; Set idle timeout
          ; Pressure advance
          ; M572 D0 S0.05 ; disabled Pressure advance
          M208 X-22 Y22 Z0 S1 ; Set axis minima
          M208 X301 Y310 Z500 S0 ; Set axis maxima
          M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
          ; Filament sensor
          M591 D0 P1 C3 S1 ; Set Filament sensor Simple type (High) for extruder drive 0, connected to endstop input 3 (E0)
          M558 P1 C"^zprobe.in" H5 F300 T9000 ; set Z probe type to bltouch and the dive height + speeds
          G31 P500 X0 Y0 Z0.74 ; set Z probe trigger value, offset and trigger height
          M557 X25:300 Y60:300 S80 ; define mesh grid
          M308 S0 P"bedtemp" Y"thermistor" A"Bed" T100000 B4725 C0.0000000706 R4700 ; configure sensor 0 as thermistor on pin bedtemp
          M307 H0 A156.6 C925.3 D2.2 V23.4 B0 ; Heatbed PID Heater 0 model: gain 159.6, time constant 925.3, dead time 2.2, max PWM 1.00, calibration voltage 23.4, mode PID
          M308 S1 P"e0temp" Y"thermistor" A"Hotend" T100000 B4725 C0.0000000706 R4700 ; configure sensor 1 as thermistor on pin e0temp
          M307 H1 A269.2 C128.8 D7.6 V23.7 S0.9 B0 ; Hotend PID .4mm Heater 1 model: gain 269.2, time constant 128.8, dead time 7.6, max PWM 0.90, calibration voltage 23.7, mode PID
          M143 H1 S270 ; set temperature limit for heater 0 to 260C
          M308 S2 P"mcu-temp" Y"mcu-temp" A"Duet Board" ; Configure MCU sensor
          M950 F1 C"fan2" Q500 ; create fan 1 on pin fan1 and set its frequency
          M563 P0 S"E3Dv6" D0 H1 F0 ; define tool 0
          ; Custom settings
          M564 H0 ; Let the Jog buttons work blv: added to allow jog buttons
          • Argoundefined
            Argo
            What are your Slicer settings?
            Looks like it is a bit too hot or needs a bit more retraction or is printed too fast.
            I'd say too much acceleration also as I see ringing on the side.
            • theruttmeisterundefined
              theruttmeister @TF_Sinthoras
              @TF_Sinthoras said in First Benchy printed - Issues:
              Hello Community,
              Here the Pictures:
              Ripple
              Ripple
              Looks like classic motor instability. Steppers have a speed range where they provide smooth motion as well as speeds where they do not. If you print a tower that increases in speed with height you can identify the optimum speed for your motors.
              Then use that speed for the outer wall.
              For example, I print everything but the outer wall at 80mm/s, but the outer wall at 25mm/s.
              Its oozing when it reaches the end of a line, slicers have multiple different ways of dealing with that. Look at retraction (retracting too slowly can give the hotend enough time to ooze, for example). Could also be too high a temp.
              fine Stringing
              fine Stringing
              Either not retracting enough, or more likely too high a temp.
              Tobias
              Isolate, substitute, verify.
                TF_Sinthoras
                Thank you all for the advices, the thing with the Speed is interesting, I will try that on the weekend.
                I use 245°C for printing of the PETG Filament. Is this already High for PETG?
                Speed at the moment is 60mm/s
                Retraction at 6mm
                Retract speed at 50mm/s
                Extruder is a Bondtech BMG
                Hotend E3D V6 Full Metal
                Seems that to be okay?
                Blacksheep99undefined theruttmeisterundefined 2 Replies Last reply Reply Quote 0
                • Blacksheep99undefined
                  Blacksheep99 @TF_Sinthoras
                  @TF_Sinthoras
                  Is it a direct drive? 6mm retraction is more a bowden retraction distance which is why i ask. I print pet closer to 45mm/s.
                    Retraction at 6mm
                    I agree with the @Blacksheep99, the retraction distance seems very long, its been a decade since I used a bowden, but it seems high even for that. The time to retract that far is probably causing the blobs.
                    And 245°C might be fine... but it varies based on exact material, extruder, individual thermistor etc. Best thing to do is print some test parts at 5 or 10 degree intervals.
                    PET can tend to be a bit more stringy than PLA. It doesn't have quite a big a thermal window, so it needs a little more work to get a temp high enough for your speed needs without getting stringing.
                    • Vetiundefined
                      Veti
                      print a temperature tower as well after calibrating the retraction distance
                      • Stephen6309undefined
                        Stephen6309 @TF_Sinthoras
                        @TF_Sinthoras The ripple may be caused by the infill. Try increasing the number of perimeters.
                        I'm currently using M207 S1.5 F6000 R0 Z0.03 for firmware retraction on my BMG Direct drive and it works for PETG and PLA.
                          TF_Sinthoras
                          Thank you all for the messages,
                          I made a temp tower because I used the 245 degrees I used on my ender 3, but it turns out that 235 give me the best results.
                          I use a bowden extruder, maybe I should reduce the retract and look where it gets me. But in my mind the more retracts is preventing blobs, because there is not to much material, so why reduce it to reduce blobs?
                          Do you have a good file for retract distance calibration?
                          The ripple I got away by changing the place for the printer and putting some rubber sheet under it, this helped a lot.
                          Blacksheep99undefined 1 Reply Last reply Reply Quote 0
                            @TF_Sinthoras You can use the retraction tab here to tune it.
                            https://teachingtechyt.github.io/calibration.html
