    Magnetic sensor reports negative min value
    Filament Monitor
    • Alucardiundefined
      Alucardi
      I have tried setting up the magnetic filament sensor but i cannot use it. Keeps reporting negative min values. I have just a slight movement in the bowden connector between the extruder and the sensor. Could that be the reason?
      • alankilianundefined
        alankilian
        Can you post your M591 D0 (Or whatever you're connected to)?
        Maybe the AGC value is too low or high indicating the magnet is not in the ideal location.
        Alucardiundefined 1 Reply Last reply Reply Quote 0
        • Alucardiundefined
          Alucardi @alankilian
          @alankilian it was as simple as adding a solid mount to the sensor. Now it works fine 🙂
