    New SD Card Creation
    Firmware installation
    431
    • PaulHewundefined
      PaulHew
      My SD card failed yesterday.
      New ones arrived and I have been chasing my tail for the last 2 hours.
      Read the Wiki have most of the firmware files on the card.
      I just cannot find the DWC files.
      Can someone point out where they are please.
      Regards,
      Paul.
      RailCore II - Duet Mini + 1LC, Voron V0.1 - Duet Mini
      Voron 2.4 disassembled..... Waiting for the RailCore Mini....
      • pkosundefined
        pkos
        It should be here:
        https://github.com/Duet3D/RepRapFirmware/releases
        DuetWebControl-SD.zip - the one appropriate for your release.
        Voron 2.4 (Duet 3 6HC + 3HC standalone), Voron SW (Duet 3 mini 5+ standalone), Voron Trident (Duet 3 mini 5+ standalone), Voron 0.1
        • PaulHewundefined
          PaulHew
          Thank you, greatly appreciated.
          Put those files in but have not got a webpage.
          Obviously missing something somewhere.
          • pkosundefined
            pkos
            To be sure, you used this guide?
            https://duet3d.dozuki.com/Wiki/SD_Card
            • PaulHewundefined
              PaulHew
              This is what I have in my Sys directory
              Yes I did follow it......
              Regards,
              Paul
              • pkosundefined
                pkos
                ok. so you have a sys directory on the root of the sd card.
                now you need another directory called www - also on the root - and unpack the DuetWebControl-SD.zip into it.
                • PaulHewundefined
                  PaulHew
                  Yep, have already done that.
                  Appreciate the assistance, btw.
                  P.
                  • PaulHewundefined
                    PaulHew
                    Network connection has not fired up again.
                    Same problem I have had for the last 2 years since I bought the board new.
                    Needs a little time to warm itself up I think / hope.
                    Cannot wait to get a Duet3 Mini 5.....
                    Regards,
                    Paul
                    • pkosundefined
                      pkos
                      Ok. So to make sure we are on the same page.
                      You have a new SD card.
                      It's formatted either to FAT16 (for 4GB or lower) or FAT32 (for above 4GB but below 32GB).
                      It's formatted for 512 byte sectors and either 64kb or 32kb sectors (fat16 or fat32 respectively).
                      You did a full format and not a quick format.
                      And you still aren't getting anywhere.
                      Correct?
                      • PaulHewundefined
                        PaulHew
                        Always full format use SD Card Formatter as per Wiki.
                        As I said, there has been an underlying problem with the network connection on this board, I have posted about it numerous times.
                        Funny that the Pi can use the cable that the Duet cannot use.
                        I was running Klipper on this board as I got really miffed with this network issue and it worked well, until I asked how to do a 4 point mesh to align rails on the CoreXY and was told to jog on.
                        So back to RRF where the support is good!
                        P.
                        • pkosundefined
                          pkos
                          Interesting. Did you try to troubleshoot networking via YAT and usb connection?
                          • PaulHewundefined
                            PaulHew
                            Network is up now. As I said, just takes it an age for the network to load / warm up
                            Now I need to try and pull all of my macros in and get back to where I was!
                            Thanks again.
                            • pkosundefined
                              pkos
                              Good luck 🙂
                                I wonder if the wifi module needs a touch-up on the soldering. Sounds like maybe a cold joint.
                                PaulHewundefined 1 Reply Last reply Reply Quote 0
                                • PaulHewundefined
                                  PaulHew @Phaedrux
                                  @Phaedrux I have been thinking about that also. It is a Duet2 Ethernet.
                                  I have a spare ethernet board, Just need to plan a time to fit it!
                                  P.
