    Out of inputs on Mini 5+
    • fcwiltundefined
      fcwilt
      I am out of inputs on my Mini 5+.
      Currently connected are a 1 PanelDue, 3 endstops, 1 Z probe, 1 Filament monitor, 1 Momentary Push Button Switch.
      I would like to find a way to connect one more push button.
      I don't want to use "crash" detection to free up one of the endstop inputs.
      Anyway to use a thermistor input to do that?
      Thanks.
      • T3P3Tonyundefined
        T3P3Tony administrators @fcwilt
        This post is deleted!
          You should be able to use a thermistor input or a IOx.OUT pin. If you need a lot of inputs, you can connect a SammyC21 via CAN.
          fcwiltundefined 2 Replies Last reply Reply Quote 0
          • fcwiltundefined
            fcwilt @dc42
            @dc42 said in Out of inputs on Mini 5+:
            Thanks for that info.
            I will give it a try.
            • fcwiltundefined
              fcwilt @dc42
              I assume I need to uses a M950 command with a J parameter to specify an input.
              Trying that with a thermistor input didn't generate any errors on the DWC console but grounding the pin seems to be resetting the board.
              How do I turn an output pin like IO1.out into a input pin?
              Thanks.
