    Single axis "printer" possible?
    RepRapFirmware on other controllers
    570
    • whopping pochardundefined
      whopping pochard
      Hi all,
      I've been working on putting together a little rig for empirically testing hotend components (because I'm a giant nerd, I love data, and had an extra SKR 1.4 board laying around).
      I have it set up with a basic extruder and groove mount block for pushing plastic, as well as with a second groove mount placed below a tiny linear axis. The idea is to write a gcode macro to take temperature measurements at 0.1 mm increments across the heat break.
      Is it possible to just define a single axis, and still have it home that axis and accept subsequent move commands? Should I assign it to a non-XYZ axis name? Any other hints or suggestions?
      Thanks!
      jrocklandundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
      • jrocklandundefined
        jrockland @whopping pochard
        @whopping-pochard in your homeall file, just remove everything and write g92 x0 y0 z0.
        You will be able to "print".
        whopping pochardundefined 1 Reply Last reply Reply Quote 1
        • fcwiltundefined
          fcwilt @whopping pochard
          @whopping-pochard
          Most certainly.
          What Duet hardware are you using and what firmware is it running?
          It doesn't matter what you name the axis unless you need to use the Z probe features in which case name it Z.
          You will have to write your own gcode files for testing of course.
          whopping pochardundefined 1 Reply Last reply Reply Quote 0
            whopping pochard @jrockland
            @jrockland Ahhhh that is what was tripping me up! Thanks!!
              whopping pochard @fcwilt
              @fcwilt Thanks! I’m running the latest 3.x firmware on the SKR 1.4. My original Duet boards are all in actual printers. 😁
              • fcwiltundefined
                @whopping-pochard said in Single axis "printer" possible?:
                I doubt you will be able to get it to work unless you use a Duet board.
                šŸ˜‰
                  jay_s_uk @fcwilt
                  @fcwilt why not? its exactly the same firmware (although the LPC version does have a few limitations, only due to memory constraints though)
                  • fcwiltundefined
                    fcwilt @jay_s_uk
                    @jay_s_uk said in Single axis "printer" possible?:
                    Did you not see the "wink"?
                    I was just messing with him for not using a Duet product.
                      whopping pochard
                      Poe's Law strikes again!! šŸ˜‚
                      • fcwiltundefined
                        But I did include the wink as required. šŸ˜‰
