    Connect Ubuntu PC Directly to DUET EtherNet Without a Router?
    Duet Web Control
    direct ethernet connection ubuntu
    8
    37
    2.7k
    • 3mmundefined
      3mm
      Anybody know how to connect an Ubuntu LInux PC directly to a DUET3D EtherNet controller using only an EtherNet cable without using a router? I have looking around, somebody has probably figured out how to do it. Any help would be appreciated.
      I desire to use DUET Web Broswer user interface with that arrangement.
      Does such a configuration require a cross-over cable, among the other things?
      Thanks in advance
      3mm
      There are 10 types of people: Those who understand binary and those who don't.
      fcwiltundefined droftartsundefined 3 Replies Last reply Reply Quote 0
      • fcwiltundefined
        fcwilt @3mm
        @3mm
        Well either the Duet or the PC would have to have auto configuring network connectors.
        If neither does then a cross-over cable would be needed - or a small network switch.
          droftarts administrators @3mm
          @3mm you need to configure the Linux PC’s Ethernet and the Duet to different static IP addresses that are in the same sub domain. See https://duet3d.dozuki.com/Wiki/Setting_up_networking_on_Duet#Section_Wired_direct_connection
            droftarts administrators @fcwilt
            @fcwilt said in Connect Ubuntu PC Directly to DUET EtherNet Without a Router?:
            @3mm
            No. You have to set both to static IP addresses, as there’s no DHCP server to allocate the IP address when connected by a single cable.
            No, you don’t need a crossover cable, Duet and PC network adapter will auto negotiate that. You shouldn’t need a switch or hub either.
            • fcwiltundefined
              fcwilt @droftarts
              @droftarts said in Connect Ubuntu PC Directly to DUET EtherNet Without a Router?:
              Did you actually read what I posted?
              I specifically stated that a cross-over cable or switch would only be needed if neither the Duet or the PC had an auto-configuring network port.
              The OP asked about the need for a cross-over cable and that is the issue I addressed.
              I assumed the OP understood about IP address issues.
                Of course.
                That was his second question. It wasn’t clear what you were referring to.
                Big assumption!
                  @3mm here’s a guide to setting a static IP address in Ubuntu. https://linuxize.com/post/how-to-configure-static-ip-address-on-ubuntu-20-04/
                  The first part is how to do it in terminal, later in the article it shows how to do it in the GUI, much easier!
                  See my earlier link for how to set up the Duet.
                  3mmundefined 1 Reply Last reply Reply Quote 0
                  • 3mmundefined
                    3mm @droftarts
                    @droftarts
                    Excellent. Thank you so much!
                    Best Regards
                    3mm
                    • 3mmundefined
                      3mm @3mm
                      @droftarts
                      Hi, after screwing around quite a bit and reading the URLs you cited and a few others derived from those you cited, I was able to connect the NoteBook running Ububut 14.04 Linux, directly (using a straight through CAT5e cable) to the DUET-EtherNet (v2) controller, via static IPv4 configuration. However, it wont stay connected. It acts like a timing problem? I'm wondering what the minimum version of (FireFox) web-browser is required? And maybe, is there a time-out retry setting somewhere in the controller firmware? It occurs to me that the NoteBook, a Dell "Inspiron Mini 1012" just might be too old...too slow. I have a marketing brochure dated 1999 for that model.
                      Any ideas to what might be a solution? I've changed cables; fiddled around with settings in the Linux. I may try changing to a more recent PC with a more recent version of Linux.
                      Thanks in advance for your time in this matter.
                      3mm
                      gaweyoundefined droftartsundefined 2 Replies Last reply Reply Quote 0
                      • gaweyoundefined
                        gaweyo @3mm
                        @3mm said in Connect Ubuntu PC Directly to DUET EtherNet Without a Router?:
                        sounds like you might have dhcp client still running, does the IP for the PC change when it stops working or does it say static? i
                          @3mm Is the netbook connected by WiFi to your network as well? If so, what IP addresses are the wired and wireless connections configured to? Most likely you have set the wired Ethernet in the same range as the WiFi. To check each one, see https://help.ubuntu.com/stable/ubuntu-help/net-findip.html.en
                          You can also use the terminal command ip a to list IP addresses.
                          • 3mmundefined
                            3mm
                            @gaweyo
                            No. But thanks for the reply.
                            @droftarts
                            No. WiFi is disabled.
                            I have further information. When the NoteBook connects to the DUET-E controller & the Web-Console, EtherNet/Controller stays connected so long as there is not a lot of I/O hand-shaking. For instance, I can issue motion commands via the web-interface without any disconnects, but when I click the 'G-Code Files' tab, sometimes it'll load the page and then disconnect, other times it'll instantly disconnect. The only way I can reconnect and have a stable connection is power-cycling the DUET-E (EtherNet) v1.02 controller.
                            When the connection crashes, the WebConsole emits an error message:
                            ! Request Timeout
                            The last HTTP request has timed out. Please make sure the connection between your
                            device and the board is not interrupted.
                            DUET-E Controller Info:
                            (old)
                            Duet 2 WiFi/EtherNet Board (v1.02)
                            Firmware: 2.03 (2019-06-13b2)
                            Web Interface: 1.21
                            The settings in the DUET-E controller are:
                            M552 S0 ; Disable network
                            ; ----------------- static IP direct connect via CAT5e cable DUET-E controller config ------------
                            M552 P192.168.2.2     ; Static IP Addr - DUET's IP Addr
                            M553 P255.255.255.0 ; NetMask
                            M552 S1                      ; Enable network
                            The settings in Ubuntu 14.04 Linux - /etc/network/interfaces file are:
                            auto lo
                            iface lo inet loopback
                            auto eth0
                            iface eth0 inet static
                                 address 192.168.2.1
                                 netmask 255.255.255.0
                            While in the Ubuntu DeskTop 'NetworkManager' taskbar dialog
                            the IPv4 Settings are:
                              Address: 192.168.2.1
                              Netmask: 255.255.255.0
                              Gateway:   0.0.0.0
                            I think this should be working.
                            Maybe its a really old DUET-E firmware version problem thats been fixed? The NoteBook Linux seems to be doing something that may be
                            scrambling the controller logic?? It isn't a perfect world. Although these DUET products are very good IMO. I was lucky finding you guys. Thanks.
                            3mm
                              1. Please run M122 and post the resulting report here.
                              2. It may help us diagnose this if you install WireShark on the notebook, capture the data to/from the Duet and stop the capture immediately after a disconnection. Then attach the capture file to a post.
                                @3mm It's possible it's a firmware bug, as you're on RRF 2.03. Updating to 2.05.1 would be sensible, and shouldn't require you to make any changes (caveat: from memory!).
                                What version of DWC are you using? I think you said you're using Firefox as your browser, but I'm not sure we have tested what version would be compatible. I'd generally say to use the latest available.
                                It's also possible that it's an SD card issue; sharing the M122 response as @dc42 suggests might show if that's a problem (you can connect via USB to get this, if it's not working in the browser). Try a new one, or reformat the old one after copying the files off it. See https://duet3d.dozuki.com/Wiki/SD_Card for specification, formatting etc.
                                • 3mmundefined
                                  3mm @dc42
                                  @dc42 said in Connect Ubuntu PC Directly to DUET EtherNet Without a Router?:
                                  Hi DC42,
                                  I down-loaded & installed WireShark on the Linux box, now I gotta fiddle around a bit to use it, and tomorrow I'll upload the M122 output, gotta hit the sack, its 4:00am here in LA, and I have a meeting with pirate atty (aren't they all?) tomorrow. Thanks for your attention to this matter.
                                  3mm
                                  • 3mmundefined
                                    3mm @3mm
                                    Hi DC42,
                                    3mm
                                    Hi DC42,
                                    <sigh> Well, the version of Ubuntu and the age of the Dell NoteBook running ubuntu 14.04 LTS that I was trying to use with the DUET-E controller, and then later install WireShark into...not a good fit, it just did not work correctly. So, now that I've changed to a HP 8640P LapTop, and have installed the latest xubuntu (ubuntu 20.04.10 LTS) Linux operating system and installed the latest WireShark, --those peices are working properly together. The for WebControl, FireFox version: 86.0 (64bit) Ubuntu canonical - 1.0, which is a fairly recent version.
                                    I now am able to finally cause the new laptop+ubuntu OS to connect to the DUET-E controller, (using NetPlan) I finally have been able to acquire the WireShark diagnostic traffic file that you requested.
                                    So now, just as before, everytime I connect (via static IP & a direct EtherNet CAT5 cable) from the LapTop to the DUET-E controller, the connection remains functioning (40 + minutes, while moving the hot-end, setting the temps, heating things up, etc) as long as I do not access the G-Code Files directory which loads and displays all the files. The EtherNet remains connected for around 5 seconds and then drops the connection and emits an 'HTTP timeout error'. The only way I can reconnect is to power-cycle the DUET-E controller.
                                    The LapTop IP Address: 192.168.2.1/24 (the /24 is required by ubuntu)
                                    DUET-E Controller Addr: 192.168.2.2/24 (ditto)
                                    NetMask: 255.255.255.0
                                    network configuration file: /etc/netplan/99_config.yaml
                                      network:
                                        version: 2
                                        renderer: networkd
                                          ethernets:
                                            enp0s25:
                                              addresses:
                                                     - 192.168.2.1/24
                                                     - 192.168.2.2/24
                                    sudo netplan apply<cr>
                                    M122 Status List:
                                    M122 Status List.txt
                                    WireShark Diagnostic (dropout occurs around 1331) file - Rename file from .txt to .pcapng:
                                    EtherNet_DropOuts_Around_1331_pcapng.txt
                                    Thanks in advance for your help.
                                    3mm
                                      @3mm Thanks for the information. You didn't update to 2.05.1? The M122 command reports "Used output buffers: 6 of 24 (8 max)", which is high. There were quite a lot of fixes in later RRF 2.x versions for this issue.
                                      To update, you should be able to upload this file to DWC: https://github.com/Duet3D/RepRapFirmware/releases/download/2.05.1/Duet2Firmware-2.05.1.zip
                                      Download it as a zip (don't unzip it), and upload it to the Duet via DWC > Settings > General > Upload Files button.
                                      Note that this WILL update DWC to version 2.x, which is a bit different from 1.x. You can go back to 1.x if you prefer it.
                                      3mmundefined 2 Replies Last reply Reply Quote 0
                                      • SupraGuyundefined
                                        SupraGuy
                                        Crossover cable issue has been addressed.
                                        If I were dealing with a Linux PC, I'd probably use a separate network card and configure DHCP on that interface.
                                        Google gave me a basic link to configure it here
                                        This also allows you to use it with a switch for other network functions for things that you might not want connected to the Internet. You can also edit the configuration file to always assign the same IP address by MAC address, allowing you to always be able to find any given host by IP address, when desired.
                                        My ISP router doesn't support assigning addresses to devices, so I shut off it's DHCP server entirely, and have set up DHCP services on a Linux machine so that I can always find things like my MotionEye cameras, the Duet, and a few other things on the network.
                                        Edit: The advantage to doing it this way is that you can still take the Duet based printer somewhere else and still easily connect it to most networks.
                                        Lead screw driven printer, powered by Duet 2 Wifi
                                        MPCNC powered by Duet 2 Wifi
                                        CoreXY printer driven by Duet 3 6HC
                                        LowRider CNC powered by Duet 2 Wifi
                                        • 3mmundefined
                                          3mm @droftarts
                                          Thank you for your time in this matter and for the update link. I'll give it a whirl... In the mean time, I have successfully broken the Linux software connection point. I can not cause the EtherNet port to talk to the InterNet or to the printer. There is a bug in the mapping (NetPlan) software and it broke something for which I can not find any documentation. I chose xubuntu as it sports a smaller memory usage footprint than the standard ubuntu version. Only there is a problem, that port of Linux is poorly documented, does not have a large user community AND they changed a lot of the ways Linux operates AND it is really buggy! In my opinion. So, I'm going to overwrite it with a ubuntu 20.04.10 LTS OS, to try to get back to a standard Linux normalicy, so if there is a problem, I'll be able to find literature for it.
                                          Thanks a lot...3mm
                                          • 3mmundefined
                                            3mm @SupraGuy
                                            @SupraGuy said in Connect Ubuntu PC Directly to DUET EtherNet Without a Router?:
                                            @SupraGuy
                                            Unfortunately, my PC is a laptop, and actually I did try (using ubuntu 14.04 LTS) the DHCP method, but I was suffering the EtherNet dropout problem and DC42 asked that I capture the failure modality using WireShark, which I was unable to cause to work properly with that version of Linux. So I dug out an HP-8640p LapTop onto which I loaded a different version Linux OS & WireShark. However I could not cause that configuration to easily swap between static IP and DHCP, as I would like to be able to connect the LapTop to the InterNet occasionally, and other times only to the printer. Then I broke that OS somehow and I've given up trying to resolve that problem, I'm just going to rebuild the OS with a standard Ubuntu 20.04.10 LTS Linux. The Net Mapping (NetPlan) software is very powerful, but seems a bit sketchy, in my opinion.
                                            Thanks for your suggestions - 3mm
