Duet 3 Mini 5+ VIN under-voltage issues in SBC mode
In the meantime, it would be fantastic if it could pause the print instead of marking it as completed after one of these events, so that it's easier to resume. Or at the very least, it would be useful if it didn't cause the axes to lose their "homed" status.
M122 === Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.3beta2+1 (2021-04-09 14:40:21) running on Duet 3 Mini5plus Ethernet (SBC mode) Board ID: FDQG2-Q296U-D65J0-40KMG-1K03Z-HXFTZ Used output buffers: 1 of 40 (11 max) === RTOS === Static ram: 100072 Dynamic ram: 91712 of which 64 recycled Never used RAM 51856, free system stack 172 words Tasks: Linux(ready,115) HEAT(delaying,322) CanReceiv(notifyWait,774) CanSender(notifyWait,371) CanClock(delaying,340) TMC(notifyWait,99) MAIN(running,484) IDLE(ready,20) AIN(notifyWait,260) Owned mutexes: HTTP(MAIN) === Platform === Last reset 04:37:40 ago, cause: software Last software reset at 2021-04-09 21:48, reason: User, none spinning, available RAM 51804, slot 0 Software reset code 0x0012 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00430000 BFAR 0xe000ed38 SP 0x00000000 Task Linu Freestk 0 n/a Error status: 0x00 Aux0 errors 0,0,0 Aux1 errors 0,0,0 MCU revision 3, ADC conversions started 19812079, completed 19812078, timed out 0, errs 1 tnd=0 rnd=0 wrs=0 wrx=1 war=1 Supply voltage: min 0.0, current 24.3, max 24.4, under voltage events: 1, over voltage events: 0, power good: yes Heap OK, handles allocated/used 0/0, heap memory allocated/used/recyclable 0/0/0, gc cycles 0 Driver 0: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 68, reads 20759, writes 20, timeouts 0, DMA errors 0 Driver 1: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 68, reads 20758, writes 20, timeouts 0, DMA errors 0 Driver 2: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 58, reads 20760, writes 18, timeouts 0, DMA errors 0 Driver 3: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 68, reads 20757, writes 20, timeouts 0, DMA errors 0 Driver 4: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 68, reads 20759, writes 20, timeouts 0, DMA errors 0 Driver 5: position 0, assumed not present Driver 6: position 0, assumed not present Date/time: 2021-04-10 02:26:25 Cache data hit count 4294967295 Slowest loop: 2.05ms; fastest: 0.12ms === Storage === Free file entries: 10 SD card 0 not detected, interface speed: 0.0MBytes/sec SD card longest read time 0.0ms, write time 0.0ms, max retries 0 === Move === DMs created 83, maxWait 0ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = 0 -1, chamberHeaters = -1 -1 Heater 1 is on, I-accum = 0.0 === GCodes === Segments left: 0 Movement lock held by null HTTP* is doing "M122" in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger* is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === CAN === Messages queued 149946, send timeouts 0, received 199896, lost 0, longest wait 2ms for reply type 6049, peak Tx sync delay 345, free buffers 17 (min 16) === SBC interface === State: 4, failed transfers: 0 Last transfer: 4ms ago RX/TX seq numbers: 6547/6547 SPI underruns 0, overruns 0 Number of disconnects: 0, IAP RAM available 0x118dc Buffer RX/TX: 0/0-0 === Duet Control Server === Duet Control Server v3.3-b2 Code buffer space: 4096 Configured SPI speed: 8000000 Hz Full transfers per second: 35.80 Codes per second: 0.00 Maximum length of RX/TX data transfers: 3148/796 -
@fletcher, thanks for that. From the report, I presume the fault was a spurious VIN undervoltage report, not a VSSA error.
Now I have a better idea of what causes the spurious undervoltage reports. I still need a M122 report from this firmware following a VSSA fault report.
@dc42 My machine is happy to oblige!
4/10/2021, 8:21:11 AM M122 === Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.3beta2+1 (2021-04-09 14:40:21) running on Duet 3 Mini5plus Ethernet (SBC mode) Board ID: FDQG2-Q296U-D65J0-40KMG-1K03Z-HXFTZ Used output buffers: 1 of 40 (13 max) === RTOS === Static ram: 100072 Dynamic ram: 91712 of which 64 recycled Never used RAM 51856, free system stack 172 words Tasks: Linux(ready,115) HEAT(delaying,322) CanReceiv(notifyWait,774) CanSender(notifyWait,371) CanClock(delaying,340) TMC(notifyWait,99) MAIN(running,374) IDLE(ready,20) AIN(notifyWait,260) Owned mutexes: HTTP(MAIN) === Platform === Last reset 18:32:25 ago, cause: software Last software reset at 2021-04-09 21:48, reason: User, none spinning, available RAM 51804, slot 0 Software reset code 0x0012 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00430000 BFAR 0xe000ed38 SP 0x00000000 Task Linu Freestk 0 n/a Error status: 0x00 Aux0 errors 0,0,0 Aux1 errors 0,0,0 MCU revision 3, ADC conversions started 79666166, completed 79666165, timed out 0, errs 4 tnd=0 rnd=0 wrs=0 wrx=4 war=4 Supply voltage: min 0.0, current 0.1, max 24.4, under voltage events: 2, over voltage events: 0, power good: no Heap OK, handles allocated/used 0/0, heap memory allocated/used/recyclable 0/0/0, gc cycles 0 Driver 0: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 68, reads 52912, writes 0, timeouts 0, DMA errors 0 Driver 1: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 68, reads 52912, writes 0, timeouts 0, DMA errors 0 Driver 2: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 58, reads 52911, writes 0, timeouts 0, DMA errors 0 Driver 3: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 68, reads 52911, writes 0, timeouts 0, DMA errors 0 Driver 4: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 68, reads 52912, writes 0, timeouts 0, DMA errors 0 Driver 5: position 0, assumed not present Driver 6: position 0, assumed not present Date/time: 2021-04-10 16:21:10 Cache data hit count 4294967295 Slowest loop: 2.50ms; fastest: 0.09ms === Storage === Free file entries: 10 SD card 0 not detected, interface speed: 0.0MBytes/sec SD card longest read time 0.0ms, write time 0.0ms, max retries 0 === Move === DMs created 83, maxWait 0ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = 0 -1, chamberHeaters = -1 -1 Heater 1 is on, I-accum = 0.0 === GCodes === Segments left: 0 Movement lock held by null HTTP* is doing "M122" in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger* is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === CAN === Messages queued 450532, send timeouts 0, received 600717, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 345, free buffers 17 (min 17) === SBC interface === State: 4, failed transfers: 0 Last transfer: 3ms ago RX/TX seq numbers: 30955/30955 SPI underruns 0, overruns 0 Number of disconnects: 0, IAP RAM available 0x118dc Buffer RX/TX: 0/0-0 === Duet Control Server === Duet Control Server v3.3-b2 Code buffer space: 4096 Configured SPI speed: 8000000 Hz Full transfers per second: 35.82 Codes per second: 0.00 Maximum length of RX/TX data transfers: 3148/796 4/10/2021, 8:21:05 AM Error: VSSA fault, check thermistor wiring Omitted: several hundred similar VSSA fault messages before this one. It was still repeating the error when I checked just now, and I had to
M999
reset to get the web interface responsive enough to copy-paste! -
10/04/2021, 18:06:12 Error: VSSA fault, check thermistor wiring 10/04/2021, 18:06:08 Error: VSSA fault, check thermistor wiring 10/04/2021, 18:06:03 Error: VSSA fault, check thermistor wiring 10/04/2021, 18:05:59 Error: VSSA fault, check thermistor wiring 10/04/2021, 18:05:56 m122 === Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.3beta2+1 (2021-04-09 14:40:21) running on Duet 3 Mini5plus Ethernet (SBC mode) Board ID: A45XG-F396U-D65J0-40KML-1F03Z-H03XP Used output buffers: 5 of 40 (36 max) === RTOS === Static ram: 100072 Dynamic ram: 92364 of which 0 recycled Never used RAM 48412, free system stack 112 words Tasks: Linux(resourceWait,119) HEAT(delaying,198) CanReceiv(notifyWait,774) CanSender(notifyWait,363) CanClock(delaying,340) TMC(notifyWait,99) MAIN(running,312) IDLE(ready,20) AIN(notifyWait,259) Owned mutexes: HTTP(MAIN) === Platform === Last reset 07:09:53 ago, cause: software Last software reset at 2021-04-10 00:26, reason: User, none spinning, available RAM 48444, slot 2 Software reset code 0x0012 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task Linu Freestk 0 n/a Error status: 0x00 Aux0 errors 0,0,0 Aux1 errors 0,0,0 MCU revision 3, ADC conversions started 30627993, completed 30627992, timed out 0, errs 5 tnd=0 rnd=0 wrs=0 wrx=5 war=5 Supply voltage: min 0.0, current 35.9, max 35.9, under voltage events: 1, over voltage events: 0, power good: yes Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/1130/1130, gc cycles 0 Driver 0: position 64902, standstill, SG min/max 0/510, read errors 0, write errors 1, ifcnt 62, reads 265, writes 41, timeouts 6924, DMA errors 0, failedOp 0x6a Driver 1: position -15887, standstill, SG min/max 0/510, read errors 0, write errors 1, ifcnt 62, reads 6828, writes 41, timeouts 361, DMA errors 0, failedOp 0x6f Driver 2: position 328, standstill, SG min/max 0/242, read errors 0, write errors 1, ifcnt 76, reads 5597, writes 47, timeouts 1586, DMA errors 0, failedOp 0x72 Driver 3: position 0, standstill, SG min/max 0/270, read errors 0, write errors 1, ifcnt 76, reads 6731, writes 47, timeouts 450, DMA errors 0, failedOp 0x41 Driver 4: position 0, standstill, SG min/max 0/274, read errors 0, write errors 1, ifcnt 76, reads 7183, writes 47, timeouts 0, DMA errors 0 Driver 5: position 0, assumed not present Driver 6: position 0, assumed not present Date/time: 2021-04-10 18:05:56 Cache data hit count 4294967295 Slowest loop: 1000.25ms; fastest: 0.08ms === Storage === Free file entries: 10 SD card 0 not detected, interface speed: 0.0MBytes/sec SD card longest read time 0.0ms, write time 0.0ms, max retries 0 === Move === DMs created 83, maxWait 14959696ms, bed compensation in use: mesh, comp offset 0.000 === MainDDARing === Scheduled moves 1805, completed moves 1805, hiccups 0, stepErrors 0, LaErrors 0, Underruns [6, 0, 8], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = 0 -1, chamberHeaters = -1 -1 === GCodes === Segments left: 0 Movement lock held by null HTTP* is doing "M122" in state(s) 0 Telnet is idle in state(s) 0 File* is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger* is idle in state(s) 0 Queue* is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === CAN === Messages queued 248388, send timeouts 0, received 309852, lost 0, longest wait 2ms for reply type 6049, peak Tx sync delay 380, free buffers 17 (min 16) === SBC interface === State: 4, failed transfers: 0 Last transfer: 4ms ago RX/TX seq numbers: 9831/9831 SPI underruns 0, overruns 0 Number of disconnects: 0, IAP RAM available 0x118a8 Buffer RX/TX: 0/0-0 === Duet Control Server === Duet Control Server v3.2.2 Code buffer space: 4096 Configured SPI speed: 8000000 Hz Full transfers per second: 35.96 Maximum length of RX/TX data transfers: 3628/1248 10/04/2021, 18:05:54 Error: VSSA fault, check thermistor wiring 10/04/2021, 18:05:50 Error: VSSA fault, check thermistor wiring Nothing important.....
Hope this helps @dc42 -
@Fletcher and @paulhew, thanks! Those M122 reports have helped me to pin down the issue some more.
I have put a new firmware build at https://www.dropbox.com/sh/xplbsekbnmmmgtv/AADbXUoNb99JghhlSbzV4Njya?dl=0. When you can, please switch to that one and report any further errors, with M122 reports again.
FYI you don’t need to be printing to generate these errors; my 5+ and SBC has generated 7 errors in the last 24hrs sitting idle! So save your filament and frustration if you’re helping out with this. Thanks!
@dc42 More M122!
4/11/2021, 12:40:50 PM M122 === Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.3beta2+1 (2021-04-11 10:20:02) running on Duet 3 Mini5plus Ethernet (SBC mode) Board ID: FDQG2-Q296U-D65J0-40KMG-1K03Z-HXFTZ Used output buffers: 1 of 40 (16 max) === RTOS === Static ram: 100072 Dynamic ram: 91712 of which 64 recycled Never used RAM 51856, free system stack 172 words Tasks: Linux(ready,127) HEAT(delaying,322) CanReceiv(notifyWait,774) CanSender(notifyWait,371) CanClock(delaying,340) TMC(notifyWait,99) MAIN(running,415) IDLE(ready,20) AIN(notifyWait,260) Owned mutexes: HTTP(MAIN) === Platform === Last reset 04:43:27 ago, cause: software Last software reset at 2021-04-11 15:57, reason: User, none spinning, available RAM 51804, slot 2 Software reset code 0x0012 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task Linu Freestk 0 n/a Error status: 0x00 Aux0 errors 0,0,0 Aux1 errors 0,0,0 MCU revision 3, ADC conversions started 20273300, completed 20273299, timed out 0, errs 0 tnd=0 rnd=0 wrd=0 wtd=0 war=0 Supply voltage: min 0.0, current 36.1, max 36.1, under voltage events: 2, over voltage events: 0, power good: yes Heap OK, handles allocated/used 0/0, heap memory allocated/used/recyclable 0/0/0, gc cycles 0 Driver 0: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 164, reads 49562, writes 18, timeouts 0, DMA errors 0 Driver 1: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 164, reads 49561, writes 18, timeouts 0, DMA errors 0 Driver 2: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 144, reads 49561, writes 18, timeouts 0, DMA errors 0 Driver 3: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 164, reads 49561, writes 18, timeouts 0, DMA errors 0 Driver 4: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 164, reads 49561, writes 18, timeouts 0, DMA errors 0 Driver 5: position 0, assumed not present Driver 6: position 0, assumed not present Date/time: 2021-04-11 20:40:50 Cache data hit count 4294967295 Slowest loop: 2.05ms; fastest: 0.11ms === Storage === Free file entries: 10 SD card 0 not detected, interface speed: 0.0MBytes/sec SD card longest read time 0.0ms, write time 0.0ms, max retries 0 === Move === DMs created 83, maxWait 0ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = 0 -1, chamberHeaters = -1 -1 Heater 1 is on, I-accum = 0.0 === GCodes === Segments left: 0 Movement lock held by null HTTP* is doing "M122" in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger* is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === CAN === Messages queued 126986, send timeouts 0, received 169317, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 348, free buffers 17 (min 17) === SBC interface === State: 4, failed transfers: 0 Last transfer: 4ms ago RX/TX seq numbers: 18024/18024 SPI underruns 0, overruns 0 Number of disconnects: 0, IAP RAM available 0x118dc Buffer RX/TX: 0/0-0 === Duet Control Server === Duet Control Server v3.3-b2 Code buffer space: 4096 Configured SPI speed: 8000000 Hz Full transfers per second: 35.72 Codes per second: 0.00 Maximum length of RX/TX data transfers: 3940/820 4/11/2021, 12:40:49 PM Error: VSSA fault, check thermistor wiring -
@fletcher, thanks for that, it's a different variation that I haven't seen before.
Please can you (any anyone else with a Duet 3 Mini + SBC doing nothing more important) try the new build at https://www.dropbox.com/sh/oxyezimiusnosxa/AAAgjLNKuTL8oEcXgihZqojXa?dl=0.
I got one overnight.
12/04/2021, 09:05:59 m122 === Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.3beta2+1 (2021-04-11 10:20:02) running on Duet 3 Mini5plus Ethernet (SBC mode) Board ID: A45XG-F396U-D65J0-40KML-1F03Z-H03XP Used output buffers: 1 of 40 (25 max) === RTOS === Static ram: 100072 Dynamic ram: 92364 of which 0 recycled Never used RAM 48412, free system stack 102 words Tasks: Linux(ready,119) HEAT(delaying,198) CanReceiv(notifyWait,774) CanSender(notifyWait,363) CanClock(delaying,340) TMC(notifyWait,99) MAIN(running,310) IDLE(ready,20) AIN(notifyWait,259) Owned mutexes: HTTP(MAIN) === Platform === Last reset 19:50:27 ago, cause: software Last software reset at 2021-04-10 18:09, reason: User, none spinning, available RAM 48412, slot 0 Software reset code 0x0012 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task Linu Freestk 0 n/a Error status: 0x00 Aux0 errors 0,0,0 Aux1 errors 0,0,0 MCU revision 3, ADC conversions started 84893701, completed 84893700, timed out 0, errs 2 tnd=0 rnd=0 wrd=0 wtd=2 war=2 Supply voltage: min 23.8, current 23.9, max 36.1, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/1808/1808, gc cycles 0 Driver 0: position 58000, standstill, SG min/max 0/510, read errors 0, write errors 1, ifcnt 37, reads 44160, writes 25, timeouts 36912, DMA errors 0, failedOp 0x6f Driver 1: position -54000, standstill, SG min/max 0/510, read errors 0, write errors 1, ifcnt 37, reads 14454, writes 25, timeouts 1082, DMA errors 0, failedOp 0x72 Driver 2: position 62974, standstill, SG min/max 0/228, read errors 1, write errors 1, ifcnt 39, reads 11324, writes 27, timeouts 4209, DMA errors 0, failedOp 0x71 Driver 3: position 0, standstill, SG min/max 0/274, read errors 0, write errors 1, ifcnt 39, reads 14446, writes 27, timeouts 1088, DMA errors 0, failedOp 0x01 Driver 4: position 0, standstill, SG min/max 0/258, read errors 0, write errors 1, ifcnt 39, reads 15534, writes 27, timeouts 0, DMA errors 0 Driver 5: position 0, assumed not present Driver 6: position 0, assumed not present Date/time: 2021-04-12 09:05:58 Cache data hit count 4294967295 Slowest loop: 1000.36ms; fastest: 0.07ms === Storage === Free file entries: 10 SD card 0 not detected, interface speed: 0.0MBytes/sec SD card longest read time 0.0ms, write time 0.0ms, max retries 0 === Move === DMs created 83, maxWait 4879213ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 570944, completed moves 570944, hiccups 0, stepErrors 0, LaErrors 0, Underruns [987, 0, 3], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = 0 -1, chamberHeaters = -1 -1 Heater 1 is on, I-accum = 0.0 === GCodes === Segments left: 0 Movement lock held by null HTTP* is doing "M122" in state(s) 0 Telnet is idle in state(s) 0 File* is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger* is idle in state(s) 0 Queue* is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === CAN === Messages queued 1335191, send timeouts 0, received 858481, lost 0, longest wait 2ms for reply type 6049, peak Tx sync delay 501, free buffers 17 (min 16) === SBC interface === State: 4, failed transfers: 0 Last transfer: 3ms ago RX/TX seq numbers: 27444/27444 SPI underruns 0, overruns 0 Number of disconnects: 0, IAP RAM available 0x118a8 Buffer RX/TX: 0/0-0 === Duet Control Server === Duet Control Server v3.2.2 Code buffer space: 4096 Configured SPI speed: 8000000 Hz Full transfers per second: 41.67 Maximum length of RX/TX data transfers: 5652/1512 It was idle at this time
VSSA errors started @3.17am and finished @5:49amMy printers are in my workshop and I guess the temp dropped to about 8 degrees overnight, even though we had snow!
Not sure if it is relevant.Regards,
Paul -
@paulhew, thanks. Was it a VSSA warning?
Please try the new build at https://www.dropbox.com/sh/oxyezimiusnosxa/AAAgjLNKuTL8oEcXgihZqojXa?dl=0.
@dc42 I edited my original post. Yes, VSSA
Will load the firmware for you now and monitor.
Regards,
Paul. -
My M122 after the board started with VSSA faults. Machine was idle at the time.
m122 === Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.3beta2+1 (2021-04-12 08:36:30) running on Duet 3 Mini5plus WiFi (SBC mode) Board ID: W4ZW4-V296U-D65J0-40KM0-LR03Z-H6928 Used output buffers: 1 of 40 (12 max) === RTOS === Static ram: 100072 Dynamic ram: 97524 of which 0 recycled Never used RAM 46108, free system stack 200 words Tasks: Linux(ready,149) HEAT(delaying,314) CanReceiv(notifyWait,944) CanSender(notifyWait,371) CanClock(delaying,332) TMC(notifyWait,99) MAIN(running,596) IDLE(ready,20) AIN(notifyWait,260) Owned mutexes: HTTP(MAIN) === Platform === Last reset 00:28:47 ago, cause: software Last software reset at 2021-04-12 17:01, reason: User, GCodes spinning, available RAM 45892, slot 1 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task Linu Freestk 0 n/a Error status: 0x00 Aux0 errors 0,0,0 Aux1 errors 0,0,0 MCU revision 3, ADC conversions started 2063042, completed 2063041, timed out 0, errs 0 tnd=0 rnd=0 wrd=0 wtd=0 war=0 Supply voltage: min 0.1, current 0.1, max 18.9, under voltage events: 1, over voltage events: 0, power good: no Heap OK, handles allocated/used 0/0, heap memory allocated/used/recyclable 0/0/0, gc cycles 0 Driver 0: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 20, reads 24, writes 9, timeouts 0, DMA errors 0 Driver 1: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 20, reads 24, writes 9, timeouts 0, DMA errors 0 Driver 2: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 20, reads 24, writes 9, timeouts 0, DMA errors 0 Driver 3: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 20, reads 24, writes 9, timeouts 0, DMA errors 0 Driver 4: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 20, reads 24, writes 9, timeouts 0, DMA errors 0 Driver 5: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 20, reads 24, writes 9, timeouts 0, DMA errors 0 Driver 6: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 20, reads 24, writes 9, timeouts 0, DMA errors 0 Date/time: 2021-04-12 17:29:53 Cache data hit count 3667011328 Slowest loop: 2.60ms; fastest: 0.09ms === Storage === Free file entries: 10 SD card 0 not detected, interface speed: 0.0MBytes/sec SD card longest read time 0.0ms, write time 0.0ms, max retries 0 === Move === DMs created 83, maxWait 0ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = 0 -1, chamberHeaters = -1 -1 === GCodes === Segments left: 0 Movement lock held by null HTTP* is doing "M122" in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger* is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === Filament sensors === Extruder 0 sensor: ok Extruder 1 sensor: ok === CAN === Messages queued 15540, send timeouts 15538, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 17 (min 17) Last cancelled message type 4514 dest 127 === SBC interface === State: 4, failed transfers: 0 Last transfer: 3ms ago RX/TX seq numbers: 57208/57208 SPI underruns 0, overruns 0 Number of disconnects: 0, IAP RAM available 0x113e8 Buffer RX/TX: 0/0-0 === Duet Control Server === Duet Control Server v3.3-b2 Code buffer space: 4096 Configured SPI speed: 2000000 Hz Full transfers per second: 33.13 Codes per second: 0.04 Maximum length of RX/TX data transfers: 2928/1088 -
@serbitar, it looks like you rebooted before doing the M122. Is that correct?
@dc42 I had reset the board much earlier, around 17:00.
At 17:24 the VSSA faults started.
At 1729 I did m122 and then reset the board so that I could copy the result out of DWC. The m122 is from before that reset. -
Error: VSSA fault, check thermistor wiring 4/12/2021, 11:07:17 AM M122 === Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.3beta2+1 (2021-04-11 10:20:02) running on Duet 3 Mini5plus Ethernet (SBC mode) Board ID: PG824-LA67A-G65J0-40TFS-L3D0Z-ZGG9A Used output buffers: 1 of 40 (12 max) === RTOS === Static ram: 100072 Dynamic ram: 92492 of which 0 recycled Never used RAM 48284, free system stack 126 words Tasks: Linux(ready,139) HEAT(delaying,231) CanReceiv(notifyWait,944) CanSender(notifyWait,357) CanClock(delaying,332) TMC(notifyWait,99) MAIN(running,599) IDLE(ready,20) AIN(notifyWait,260) Owned mutexes: HTTP(MAIN) === Platform === Last reset 01:46:38 ago, cause: power up Last software reset at 2021-04-11 19:13, reason: User, none spinning, available RAM 48284, slot 0 Software reset code 0x0012 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task Linu Freestk 0 n/a Error status: 0x00 Aux0 errors 0,0,0 Aux1 errors 0,0,0 MCU revision 3, ADC conversions started 7620048, completed 7620047, timed out 0, errs 1 tnd=0 rnd=0 wrd=0 wtd=1 war=1 Supply voltage: min 0.0, current 0.1, max 24.3, under voltage events: 1, over voltage events: 0, power good: no Heap OK, handles allocated/used 99/1, heap memory allocated/used/recyclable 2048/12/0, gc cycles 0 Driver 0: position 16418, ok, SG min/max 0/72, read errors 0, write errors 0, ifcnt 15, reads 20007, writes 15, timeouts 1, DMA errors 0, failedOp 0x01 Driver 1: position 8692, ok, SG min/max 0/54, read errors 0, write errors 0, ifcnt 15, reads 19999, writes 15, timeouts 9, DMA errors 0, failedOp 0x6a Driver 2: position 120, standstill, SG min/max 0/352, read errors 0, write errors 0, ifcnt 15, reads 20008, writes 15, timeouts 0, DMA errors 0 Driver 3: position 0, ok, SG min/max 0/34, read errors 0, write errors 0, ifcnt 13, reads 20001, writes 13, timeouts 9, DMA errors 0, failedOp 0x6a Driver 4: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 11, reads 20012, writes 11, timeouts 0, DMA errors 0 Driver 5: position 0, assumed not present Driver 6: position 0, assumed not present Date/time: 2021-04-12 19:07:16 Cache data hit count 4294967295 Slowest loop: 108.23ms; fastest: 0.06ms === Storage === Free file entries: 10 SD card 0 not detected, interface speed: 0.0MBytes/sec SD card longest read time 0.0ms, write time 0.0ms, max retries 0 === Move === DMs created 83, maxWait 5180087ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 623, completed moves 623, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = 0 -1, chamberHeaters = -1 -1 === GCodes === Segments left: 0 Movement lock held by null HTTP* is doing "M122" in state(s) 0 Telnet is idle in state(s) 0 File* is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger* is idle in state(s) 0 Queue* is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === CAN === Messages queued 57504, send timeouts 57501, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 17 (min 17) Last cancelled message type 30 dest 127 === SBC interface === State: 4, failed transfers: 0 Last transfer: 3ms ago RX/TX seq numbers: 30312/30312 SPI underruns 0, overruns 0 Number of disconnects: 0, IAP RAM available 0x118dc Buffer RX/TX: 0/0-0 === Duet Control Server === Duet Control Server v3.2.2 Code buffer space: 4096 Configured SPI speed: 8000000 Hz Full transfers per second: 5.95 Maximum length of RX/TX data transfers: 3220/1640 File /opt/dsf/sd/gcodes/hdd-rack-frame large left.gcode is selected, paused -
Just had another VSSA.
12/04/2021, 21:12:04 Error: VSSA fault, check thermistor wiring 12/04/2021, 21:12:01 m122 === Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.3beta2+1 (2021-04-12 08:36:30) running on Duet 3 Mini5plus Ethernet (SBC mode) Board ID: A45XG-F396U-D65J0-40KML-1F03Z-H03XP Used output buffers: 4 of 40 (20 max) === RTOS === Static ram: 100072 Dynamic ram: 91932 of which 0 recycled Never used RAM 51700, free system stack 172 words Tasks: Linux(resourceWait,127) HEAT(delaying,322) CanReceiv(notifyWait,774) CanSender(notifyWait,371) CanClock(delaying,340) TMC(notifyWait,99) MAIN(running,484) IDLE(ready,20) AIN(notifyWait,259) Owned mutexes: HTTP(MAIN) === Platform === Last reset 09:07:01 ago, cause: software Last software reset at 2021-04-12 12:04, reason: User, GCodes spinning, available RAM 51700, slot 1 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task Linu Freestk 0 n/a Error status: 0x00 Aux0 errors 0,0,0 Aux1 errors 0,0,0 MCU revision 3, ADC conversions started 39529293, completed 39529292, timed out 0, errs 1 tnd=0 rnd=0 wrd=0 wtd=1 war=1 Supply voltage: min 0.0, current 0.1, max 24.0, under voltage events: 1, over voltage events: 0, power good: no Heap OK, handles allocated/used 0/0, heap memory allocated/used/recyclable 0/0/0, gc cycles 0 Driver 0: position 0, standstill, SG min/max 2/2, read errors 0, write errors 1, ifcnt 61, reads 12224, writes 11, timeouts 20730, DMA errors 0, failedOp 0x6f Driver 1: position 0, standstill, SG min/max 2/2, read errors 0, write errors 1, ifcnt 61, reads 32954, writes 11, timeouts 0, DMA errors 0 Driver 2: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 63, reads 32953, writes 11, timeouts 0, DMA errors 0 Driver 3: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 63, reads 32953, writes 11, timeouts 0, DMA errors 0 Driver 4: position 0, standstill, SG min/max 2/2, read errors 0, write errors 1, ifcnt 63, reads 32954, writes 11, timeouts 0, DMA errors 0 Driver 5: position 0, assumed not present Driver 6: position 0, assumed not present Date/time: 2021-04-12 21:12:00 Cache data hit count 4294967295 Slowest loop: 36.07ms; fastest: 0.10ms === Storage === Free file entries: 10 SD card 0 not detected, interface speed: 0.0MBytes/sec SD card longest read time 0.0ms, write time 0.0ms, max retries 0 === Move === DMs created 83, maxWait 0ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = 0 -1, chamberHeaters = -1 -1 Heater 1 is on, I-accum = 0.0 === GCodes === Segments left: 0 Movement lock held by null HTTP* is doing "M122" in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger* is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === CAN === Messages queued 295399, send timeouts 0, received 393841, lost 0, longest wait 2ms for reply type 6049, peak Tx sync delay 384, free buffers 17 (min 16) === SBC interface === State: 4, failed transfers: 0 Last transfer: 4ms ago RX/TX seq numbers: 54864/54864 SPI underruns 0, overruns 0 Number of disconnects: 0, IAP RAM available 0x118a8 Buffer RX/TX: 0/0-0 === Duet Control Server === Duet Control Server v3.2.2 Code buffer space: 4096 Configured SPI speed: 8000000 Hz Full transfers per second: 35.62 Maximum length of RX/TX data transfers: 3268/604 12/04/2021, 21:12:00 Error: VSSA fault, check thermistor wiring -
Thanks, everyone. There are two clear patterns emerging.
I am testing a new firmware build overnight, so maybe I will have news in the morning.
@dc42 Did MicroChip get back to you. Or is this all you and the teams hard work.....Just to say thank you really ..
Paul
@dc42 Just out of interest, what is the critical bit in our logs that assist you DC42?
