    correctly Config for my Fan
    Config Tool
    386
    • chuserundefined
      chuser
      Thank you for your Answer.
      @fcwilt said in correctly Config for my Fan:
      Are you saying that out5 and out6 are working correctly?
      yes working correctly
      What do you mean by "burns"?
      The fan rotate, then stops and smokes and that already at 50%
      Are you saying you have measured that the outputs are providing 5 volts?
      yes corretly
      • fcwiltundefined
        fcwilt @chuser
        @chuser said in correctly Config for my Fan:
        Not all fans can be controlled with PWM to vary the speed.
        Perhaps the one that is smoking is one of those that cannot be controlled.
        If it is still working try 100% - that feeds un-pulsed power to the fan just as if was receiving power from a 5 volt DC source.
        • chuserundefined
          chuser
          Thanks for the tip
          I tried that but it did not work.
          The fan spins for about 5 seconds and then it stops.
          And I noticed now that as soon as the fan stops the board reboot. no smoke appears.
          Isn't there a possibility to use the out3 withouth PWM?
          • fcwiltundefined
            fcwilt @chuser
            Thanks for the tip
            Perhaps you are drawing more current than the on-board power 5 volt power supply can provide?
            It's limited to about 700ma according to the docs.
            That would explain why the board re-boots.
            chuserundefined 1 Reply Last reply Reply Quote 0
            • chuserundefined
              chuser @fcwilt
              @fcwilt
              The fan which makes troubles has only 0.072mA - in my opinion that shouldn‘t be the reason for re-booting
              What do ya think?
                If you don't need PWM control or switching, can you connect it directly to a 5v source and run it as always on?
                Is this the fan?
                https://www.mouser.ca/ProductDetail/Sunon/MC30060V2-000U-A99?qs=EU6FO9ffTwdvsqO4GP3Tbg==
                • chuserundefined
                  chuser @Phaedrux
                  @Phaedrux yes its this type of fan.
                  I will do a test run tomorrow and will let you know!
                    Does the fan work on the other ports without issue?
                    • chuserundefined
                      chuser
                      @fcwilt @Phaedrux Thank you very much for the help.
                      I have measured the power current of the fan and found that it is too much. The current of the fan rised above 1A after a short time.
                      I have replaced the fan and now everything works.
                      fcwiltundefined 1 Reply Last reply Reply Quote 1
                      • fcwiltundefined
                        fcwilt @chuser
                        So it turned out to be the fan that was causing the reset as we suspected.
                        Glad to hear you got it all sorted.
