    Duet Mini + Toolboard 1LC questions.
    My Duet controlled machine
    • PaulHewundefined
      PaulHew
      Just received my Duet Mini and toolboard. Nice bit of kit.
      1. What gauge of cable is reccomended for the power input into the toolboard.
      2. Do I need a resistor on the Duet Mini End? (Forget that, Tony has just replied to an email!)
      3. Temp1 and IO2 are they JST-ZH?
      4. and to confirm - stepper is JST-PH?
      Regards
      Paul
      RailCore II - Duet Mini + 1LC, Voron V0.1 - Duet Mini
      Voron 2.4 disassembled..... Waiting for the RailCore Mini....
        1. I use 0.75mm^2 red/black cable.
        2. Yes, so are IO1 and the CAN connector.
        3. Yes.
        • PaulHewundefined
          PaulHew
          @PaulHew said in Duet Mini + Toolboard 1LC questions.:
          per is JST-PH?
          Thanks David.
