    Finding out names of parameters and variables
    Gcode meta commands
    592
    • ZipZapundefined
      ZipZap
      Hello fellow printers,
      i have a beginner question, regarding macros using parameters and variables.
      My System (Duet 2 WiFi; RRF & DWC on 3.2.2) is up to date. There is a new plugin called object model.
      I want to use the set active temperature of a heater (the bed to be specific) for a cooldown macro. Where do i get it? Does the object model help me?
      I am completely new to programming and stuff, please be gentle.
      Greetings from germany,
      Julien
      Most important guide -> Triffid Hunter's Calibration Guide
      HyperCube EVO (derivate) in 250x250x300 - enclosed for ABS - Duet2WiFi - custom watercooling
        Well you may not need to use the object model at all. What exactly do you want to do?
        Have you looked through the object browser plugin? You can see in there what things are available.
        • ZipZapundefined
          ZipZap
          Should run as follows:
          • read active bed temp
          • subtract 1 from active bed temp and wait to reach it
          • dwell a specific time
          • repeat, until active bed temp is below 60°C (in a for-loop or something)
          I thought about someting like this:
          for(i = "temp"; i > 60; i--){
          temp = "temp" - 1; subtract 1°C and wait to reach it
          M109 S"temp"; dwell 60 seconds
          G4 S60;
          In the Model, there is the name "heat.bedHeaters[0]", could this be the active temp? When yes, how do i use this parameter in calculations - do i have to use it as
          • heat.bedHeaters[0] or
          • "heat.bedHeaters[0]" ?
          OwenDundefined 1 Reply Last reply Reply Quote 0
          • OwenDundefined
            OwenD @ZipZap
            @ZipZap
            You can learn which object is which by observing the object model browser. You need to refresh it after changes.
            Assuming your bed heater is heater zero then something like this might work
            Note untested and typed on phone.
            Can't remember is active needs to be quoted
            while (heat.heaters[0].active > 60) && (heat.heaters[0].current > 60) && (heat.heaters[0].state = "active")
                M190 R0.1 S{heat.heaters[0].active-1}
                M116
                echo "waiting 60 seconds"
                G4 S60
            echo "cool down finished"
            Edit:
            You may have to set your heating commands to wait for < 1 degree accuracy or use a larger step
            Changed example to use M190
            ZipZapundefined 1 Reply Last reply Reply Quote 1
            • ZipZapundefined
              ZipZap
              Thanks for the help.
              I found the information about the parameters and testet while refreshing the model.
              I will try it out tomorrow.
              /Julien
              • ZipZapundefined
                ZipZap @OwenD
                @OwenD said in Finding out names of parameters and variables:
                And this was the point.
                Your adaption of M190 doesn't work, but: I figured out a solution.
                Taking the subtraction into a seperate variable makes it work. I think, you can't calculate inside a G or M-Command.
                Thanks a bunch to you guys, now i know the syntax, and how to get the parameters and declaring and using variables.
                It would be very helpful, if i wouldn't have overlooked the G-Codes in the Dozuki and the very good PDF-Manual, that is pinned on top of this category (my bad)...
                Here is my working example:
                	var cooltemp = {heat.heaters[0].active}
                	set var.cooltemp = var.cooltemp -1
                	M190 P0 R{var.cooltemp}
                	echo "wait"
                	G4 S60
                echo "cooldown finished"
                I will expand upon it and make it more versatile, ex. add in a real cooldown funktion, that works for ABS.
                Edit: Oh yeah, and i had to update everything to 3.3RC2 or course.
                OwenDundefined 1 Reply Last reply Reply Quote 1
                • OwenDundefined
                  OwenD @ZipZap
                  @ZipZap
                  the math should work without variables.
                  I misread the R value as being a +/- target based on the S value
                  ZipZapundefined 1 Reply Last reply Reply Quote 0
                  • ZipZapundefined
                    ZipZap @OwenD
                    @OwenD
                    I know what you mean about M190, but the math does not work properly.
                    I tested it just now: Temperature was 70°C, the macro (your corrected example) was
                    	M190 P0 R{heat.heaters[0].active -1}
                    	echo "wait"
                    	G4 S20
                    After activating, the [active] drops immediately to 39°C, which makes no sense to me.
                    Calculating the temperatur drop beforehand, doesn't cause this issue:
                    	echo "wait"
                    	G4 S20
                    Where is the error? Is it really the calculation within commands?
                    • OwenDundefined
                      OwenD @ZipZap
                      @ZipZap
                      Actually I also noticed an odd seemingly random number result on one occasion.
                      Perhaps @dc42 can comment?
                      • OwenDundefined
                        OwenD
                        Looks like the error isn't so random.
                        I can confirm the same results as @ZipZap
                        Oddly, if I replace the R parameter with an S parameter then force it to wait while cooling with M116, I don't get the jump to 39 degrees.
                        And even stranger is that it doesn't always go to 39 degrees. Sometime it reduces by 1 degree as expected.
