    Bondtech settings vref
    • DennisDundefined
      DennisD
      Hi everyone,
      This is my first post here on the forums, thanks for having g me here
      first i do apologize, English is not my native language and i am sorry for any typing errors.
      I own an almost stock Creality CR 10 30x30 and was working great till my melzi gave up on me.
      and i just bought some upgrades to upgrade from the melzi board.
      i bought a Duet 2wifi and 7i paneldue
      a Bondtech Direct drive kit with pancake stepper and E3d V6
      and its almost working.. Its homing . jay 🙂
      it is working but i am getting some errors
      Temperature reading fault on heater.
      and M140: Can't activate heater 0 while in fault state
      i check the sensors but they do read temps both near room temps .so i asume they are ok
      i heard that there is a special sensor in the e3d heaterblock. if so it does work but do not have a clue what other sensor i have to put in the config.
      perhaps there is someone i can compare configs to.
      i did use the configtool to create the settings but i have no idea where to put the bondtech settings vref steps etc etc or where to find them in the reprap tool sorry for all the questions ..
      code_text  Configuration file for Duet WiFi (firmware version 3)
      ; generated by RepRapFirmware Configuration Tool v3.2.3 on Thu Mar 11 2021 22:25:55 GMT+0100 (Midden-Europese standaardtijd)
      G90                                            ; send absolute coordinates...
      M83                                            ; ...but relative extruder moves
      M550 P"Braboz test"                            ; set printer name
      M918 P1 E4 F2000000                            ; configure direct-connect display
      M552 S1                                        ; enable network
      M586 P0 S1                                     ; enable HTTP
      M586 P1 S0                                     ; disable FTP
      M586 P2 S0                                     ; disable Telnet
      M569 P0 S1                                     ; physical drive 0 goes forwards
      M569 P1 S1                                     ; physical drive 1 goes forwards
      M569 P2 S0                                     ; physical drive 2 goes forwards
      M569 P3 S0                                     ; physical drive 3 goes backwards
      M584 X0 Y1 Z2 E3                               ; set drive mapping
      M350 X16 Y16 Z16 E16 I1                        ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z400.00 E93.00               ; set steps per mm
      M566 X1200.00 Y1200.00 Z24.00 E300.00          ; set maximum instantaneous speed changes (mm/min)
      M203 X9000.00 Y9000.00 Z180.00 E6000.00        ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z100.00 E5000.00          ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E1000 I50                  ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                        ; Set idle timeout
      M208 X0 Y0 Z0 S1                               ; set axis minima
      M208 X300 Y300 Z260 S0                         ; set axis maxima
      M574 X2 S1 P"xstop"                            ; configure active-high endstop for high end on X via pin xstop
      M574 Y2 S1 P"ystop"                            ; configure active-high endstop for high end on Y via pin ystop
      M574 Z2 S1 P"zstop"                            ; configure active-high endstop for high end on Z via pin zstop
      M558 P0 H5 F120 T6000                          ; disable Z probe but set dive height, probe speed and travel speed
      M557 X15:215 Y15:195 S20                       ; define mesh grid
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
      M950 H0 C"bedheat" T0                          ; create bed heater output on bedheat and map it to sensor 0
      M307 H0 B0 S1.00                               ; disable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                        ; map heated bed to heater 0
      M143 H0 S70                                    ; set temperature limit for heater 0 to 70C
      M308 S1 P"e0temp" Y"thermistor" T100000 B4092  ; configure sensor 1 as thermistor on pin e0temp
      M950 H1 C"e0heat" T1                           ; create nozzle heater output on e0heat and map it to sensor 1
      M307 H1 B0 S1.00                               ; disable bang-bang mode for heater  and set PWM limit
      M143 H1 S275                                   ; set temperature limit for heater 1 to 275C
      M950 F0 C"fan0" Q500                           ; create fan 0 on pin fan0 and set its frequency
      M106 P0 S0 H-1                                 ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"fan1" Q500                           ; create fan 1 on pin fan1 and set its frequency
      M106 P1 S1 H1 T45                              ; set fan 1 value. Thermostatic control is turned on
      M950 F2 C"fan2" Q500                           ; create fan 2 on pin fan2 and set its frequency
      M106 P2 S1 H1:0 T45                            ; set fan 2 value. Thermostatic control is turned on
      M563 P0 D0 H1 F0                               ; define tool 0
      G10 P0 X0 Y0 Z0                                ; set tool 0 axis offsets
      G10 P0 R0 S0                                   ; set initial tool 0 active and standby temperatures to 0C
      M575 P1 S1 B57600                              ; enable support for PanelDue
      code_text ; homeall.g
      ; called to home all axes
      G91                   ; relative positioning
      G1 H2 Z5 F6000        ; lift Z relative to current position
      G1 H1 X305 Y305 F3000 ; move quickly to X and Y axis endstops and stop there (first pass)
      G1 H2 X-5 Y-5 F6000   ; go back a few mm
      G1 H1 X305 Y305 F240  ; move slowly to X and Y axis endstops once more (second pass)
      G1 H1 Z265 F240       ; move Z up stopping at the endstop
      G90                   ; absolute positioning
      G92 Z260              ; set Z position to axis maximum (you may want to adjust this)
      ;G91                  ; relative positioning
      ;G1 Z5 F100           ; lift Z relative to current position
      ;G90                  ; absolute positioning
      code_text; bed.g
      G29  ; probe the bed and enable compensation
      anyway i hope u can guide me on a better track here .. once again thank u all
      cloghopping in the codes.. read my bio to understand me.
        The Bondtech steps per mm is around ~400 or so I think. NOt sure what your documentation for it says. That gets changed in the M92 command.
        Becomes
        M92 X80.00 Y80.00 Z400.00 E400 ; set steps per mm
        The motor current for the pancake stepper will depend on what the max rated current is for that motor. Do you have the specs for it? If the rated current is 1000ma, you would want to set it to use 60-80% of that, so 600 to 800ma. That gets set in M906 E
        For the E3D thermistor you'd need to change the values in this line
        To become this
        M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8
        You should also look into PID tuning your heaters.
        https://duet3d.dozuki.com/Wiki/Tuning_the_heater_temperature_control
        • DennisDundefined
          DennisD
          thank u for pointing me out on this... i will have to look for the exact pancake specs settings for the settings .. once again thank u !!
          • DennisDundefined
            DennisD
            i found this about the bondtech
            internal gear ratio of 3:1 and 415 steps per mm so i that wil be
            M92 X80.00 Y80.00 Z400.00 E415 ; set steps per mm
            Motor Tyle: Bipolar Stepper Motor
            Size: NEMA 17 (42x42x22.6mm)
            Works with 12V and 24V Printers
            Max Current: 1 Amp/Phase
            Step Angle: 1.8 deg.
            do i have to change more due to the gear ratio or no need to change that?
            zaptaundefined 1 Reply Last reply Reply Quote 0
              The gear ratio is taken into consideration when they give the steps per mm count.
              @Lampie said in Bondtech settings vref:
              So I had a good guess before and the max rated current is 1000ma, so using 600 to 800 ma would be a good start.
              • zaptaundefined
                zapta @DennisD
                The 415 microsteps/mm already accommodates the gear and 1.8deg/step stepper motor. If your extruder stepper happen to have 0.9deg/step you need to double that value.
                • DennisDundefined
                  DennisD
                  thank u for the help guys..
