    why is the engine speed macro 04 test
    • DennisDundefined
      DennisD
      hi all total noob here. so i am sorry for probably dumb questions.
      when using paneldue or Dcontrol there are some standard macros ,one of them is
      04_test_motors macro
      when pressing this
      making my xyz goes to the home positions , drive against the stops and making a loud buzz sound and it looks like the steppers are blocked but want to go up or down.
      why is this macro for?
      code_text; Motor Test Routine for Duet WiFi and Ethernet June 2018
      ;Start logging
      M929 P"test4log.txt" S1
      ; Test motors
      ;----setup motors for test----
      M906 X2000 Y2000 Z2000 E2000:2000 I100 ;set all motors to 2A with no idle current reduction
      ;The printer dimensions are deliberately set very high to allow a lot of moves during testing
      M665 R10000 L20000 B10000 H10000		; set delta radius, diagonal rod length, printable radius and homed height
      M350 X16 Y16 Z16 E16:16 I0			; Set 16x microstepping with NO interpolation
      M92 X80 Y80 Z80	E80:80				; Set axis steps/mm for 1.8deg motor even though test rig has 0.9s
      M906 X2000 Y2000 Z2000 E2000:2000 I100 		; Set all motors to 2A with no idle current reduction
      M201 X10000 Y10000 Z10000 E10000		; Acceleration limits (mm/s^2)
      M203 X100000 Y100000 Z100000 E100000		; Maximum speeds (mm/min)
      ; Test motors
      M117 PRESS ALL THREE ENDSTOPS TO END HOMING
      G91						; use relative positioning
      G1 S1 X3200 Y3200 Z3200 F9000			; move XYZ motors, stopping when endstops are triggered
      ;----end homing lines----
      M117 TEST Z
      G91
      G92 X0 Y0 Z0
      ;M201 Z1000
      G1 S2 Z2000 F50000
      G1 S2 Z-2000 F50000
      G1 S2 Z2000 F50000
      G1 S2 Z-2000 F50000
      G1 S2 Z2000 F50000
      G1 S2 Z-2000 F50000
      G1 S2 Z2000 F50000
      G1 S2 Z-2000 F50000
      M117 TEST Y
      G91
      G92 X0 Y0 Z0
      ;M201 Y1000
      G1 S2 Y2000 F50000
      G1 S2 Y-2000 F50000
      G1 S2 Y2000 F50000
      G1 S2 Y-2000 F50000
      G1 S2 Y2000 F50000
      G1 S2 Y-2000 F50000
      G1 S2 Y2000 F50000
      G1 S2 Y-2000 F50000
      M117 TEST X
      G91
      G92 X0 Y0 Z0
      ;M201 X1000
      G1 S2 X2000 F50000
      G1 S2 X-2000 F50000
      G1 S2 X2000 F50000
      G1 S2 X-2000 F50000
      G1 S2 X2000 F50000
      G1 S2 X-2000 F50000
      G1 S2 X2000 F50000
      G1 S2 X-2000 F50000
      ; Test E0 mapped to X
      M117 TEST E0
      M584 X3
      G91
      G92 X0 Y0 Z0
      ;M201 X1000
      G1 S2 X2000 F50000
      G1 S2 X-2000 F50000
      G1 S2 X2000 F50000
      G1 S2 X-2000 F50000
      G1 S2 X2000 F50000
      G1 S2 X-2000 F50000
      G1 S2 X2000 F50000
      G1 S2 X-2000 F50000
      M584 X0 Y1 Z2 E3:4
      ; Test E1 mapped to Y
      M117 TEST E1
      M584 Y4
      G91
      G92 X0 Y0 Z0
      ;M201 Y1000
      G1 S2 Y2000 F50000
      G1 S2 Y-2000 F50000
      G1 S2 Y2000 F50000
      G1 S2 Y-2000 F50000
      G1 S2 Y2000 F50000
      G1 S2 Y-2000 F50000
      G1 S2 Y2000 F50000
      G1 S2 Y-2000 F50000
      M584 X0 Y1 Z2 E3:4
      M84 ; disable motors
      M117 END OF TEST - POWER OFF BEFORE OPENING LID!; send message to DWC
      cloghopping in the codes.. read my bio to understand me.
        jay_s_uk
        delete all those macros. they are for testing and not for use by end users
        • DennisDundefined
          DennisD
          aha ok wil do that ,thank u !👍 👍
