    Z endstop switch + Mini height sensor ir board
    • esobreiroundefined
      esobreiro
      How to combine endstop switch and the mini heigth sensor board as low and high limits?
      So far the homing performs well using the low z endstop as reference, but when I start the bed leveling the optical sensor is activate but the bed keeps rising - not triggering.
      Board: Duet 2 WiFi (2WiFi)
      Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.2.2 (2021-02-11)
      Duet WiFi Server Version: 1.25
      config.g
      M569 P3 S0 ; physical drive 3 goes forwards
      M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
      M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
      M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X5 Y5 Z5 S1 ; set axis minima
      M208 X300 Y300 Z360 S0 ; set axis maxima
      M574 X2 S1 P"!xstop" ; configure active-high endstop for high end on X via pin !xstop
      M574 Y2 S1 P"!ystop" ; configure active-high endstop for high end on Y via pin !ystop
      M574 Z1 S1 P"!zstop" ; configure active-high endstop for low end on Z via pin !zstop
      M558 P2 C"zprobe.in+zprobe.mod" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds (p2)
      G31 P500 X20 Y20 Z1.0 ; set Z probe trigger value, offset and trigger height (era 500)
      M557 X15:215 Y15:195 S20 ; define mesh grid
      M307 H1 B0 S1.0 ; disable bang-bang mode for heater and set PWM limit era B0
      M143 H1 S280
      G10 P0 X5 Y5 Z10 ; set tool 0 axis offsets
      M501
      homeall.g
      G91 ; relative positioning
      G1 H1 X295 Y295 F1800 ; move quickly to X or Y endstop and stop there (first pass)
      G1 H1 X295 ; home X axis
      G1 H1 Y295 ; home Y axis
      G1 X5 Y5 F6000 ; go back a few mm
      G1 H1 X295 F360 ; move slowly to X axis endstop once more (second pass)
      G1 H1 Y295 ; then move slowly to Y axis endstop
      G1 H1 Z335 F360 ; move Z down stopping at the endstop
      G90 ; absolute positioning
      G92 Z360 ; set Z position to axis minimum (you may want to adjust this)
      ;G91 ; relative positioning
      G1 Z5 F300 ; lift Z relative to current position
      ;G90 ; absolute positioning
      Many thanks,
      Erick
        jay_s_uk
        you should use G30 to home using a probe, not G1 H1 Z...
          esobreiro
          Thanks.
          Ok, but in this case the low endstop will stop work. Is ir right?
            jay_s_uk @esobreiro
            @esobreiro typically you home with one or the other.
            you could have in your homing routine to home the bed using G30 and then measure the distance to maximum endstop using G1 H3, that way if you ever lose power, you have a way of recovering and homing Z
              esobreiro
              @jay_s_uk thank you!
              Is it possible home with the endstop and leveling with the sensor?
                jay_s_uk @esobreiro
                @esobreiro you probably can but its best to use the probe when performing levelling due to making sure you use the same Z reference point for everything. less headaches
