    Cr10 heatbed stays in tuning mode
    • DennisDundefined
      DennisD
      hi all digged myself in an new problem 😕
      the thing is the following.
      when execute a m303
      15-3-2021 17:14:52 Auto tune starting phase 3, fan off *
      15-3-2021 17:07:07 Auto tune starting phase 2, heater settling
      15-3-2021 17:02:33 Auto tune starting phase 1, heater on
      15-3-2021 17:02:28 M303 H0 S50 c5
      Auto tuning heater 0 using target temperature 50.0°C and PWM 1.00 - do not leave printer unattended
      i got a stock cr10 bed. 12v and a default sensor.
      hardware is stock creality cr10 but made it dual z-axis with splitted cable for two steppers
      Duet wifi with paneldue
      Bondtech cr19 directdrive kit with e3d v6
      since this is prob my 8 time to pidtune the bed i thought the cycles where to much so i added only for now C5
      but still the board is not coming out of tuning mode..
      its idle for 3 hours orso
      *question the fan is always on its the one cooling the e3dv6
      the other fan blowing below nozzle is not spinning when i do a m303 command..
      is there something off on my side
      this is my g.config
      code_text ; Configuration file for Duet WiFi (firmware version 3)
      ; generated by RepRapFirmware Configuration Tool v3.2.3 on Sun Mar 14 2021 21:51:16 GMT+0100 (Midden-Europese standaardtijd)
      G90                                            ; send absolute coordinates...
      M83                                            ; ...but relative extruder moves
      M550 P"CR10 on steroids"                       ; set printer name
      M918 P1 E4 F2000000                            ; configure direct-connect display
      M552 S1                                        ; enable network
      M586 P0 S1                                     ; enable HTTP
      M586 P1 S0                                     ; disable FTP
      M586 P2 S0                                     ; disable Telnet
      M569 P0 S0                                     ; physical drive 0 goes backwards
      M569 P1 S0                                     ; physical drive 1 goes backwards
      M569 P2 S1                                     ; physical drive 2 goes forwards
      M569 P3 S0                                     ; physical drive 3 goes backwards
      M584 X0 Y1 Z2 E3                               ; set drive mapping
      M350 X16 Y16 Z16 E16 I1                        ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z400.00 E415                 ; set steps per mm aangepast voor directdrive bondtech
      M566 X1200.00 Y1200.00 Z24.00 E300.00          ; set maximum instantaneous speed changes (mm/min)
      M203 X9000.00 Y9000.00 Z180.00 E6000.00        ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z100.00 E5000.00          ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E600 I50                  ; set motor currents (mA) and motor idle factor in per cent aangepast voor bondtech de E was 1000 ipv 600
      M84 S30                                        ; Set idle timeout
      M208 X0 Y0 Z0 S1                               ; set axis minima
      M208 X310 Y310 Z260 S0                         ; set axis maxima
      M574 X1 S1 P"xstop"                            ; configure active-high endstop for low end on X via pin xstop
      M574 Y1 S1 P"ystop"                            ; configure active-high endstop for low end on Y via pin ystop
      M574 Z1 S1 P"zstop"                            ; configure active-high endstop for low end on Z via pin zstop
      M558 P0 H5 F120 T6000                          ; disable Z probe but set dive height, probe speed and travel speed
      M557 X15:215 Y15:195 S20                       ; define mesh grid
      M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
      M950 H0 C"bedheat" T0                          ; create bed heater output on bedheat and map it to sensor 0
      M307 H0 B0 S1.00                               ; disable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                        ; map heated bed to heater 0
      M143 H0 S75                                    ; set temperature limit for heater 0 to 75C
      M308 S1 P"e0temp" Y"thermistor" T100000 B4092  ; configure sensor 1 as thermistor on pin e0temp
      M950 H1 C"e0heat" T1                           ; create nozzle heater output on e0heat and map it to sensor 1
      M307 H1 B0 S1.00                               ; disable bang-bang mode for heater  and set PWM limit
      M143 H1 S275                                   ; set temperature limit for heater 1 to 275C
      M950 F0 C"fan0" Q500                           ; create fan 0 on pin fan0 and set its frequency
      M106 P0 S0 H-1                                 ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"fan1" Q500                           ; create fan 1 on pin fan1 and set its frequency
      M106 P1 S1 H1 T45                              ; set fan 1 value. Thermostatic control is turned on
      M950 F2 C"fan2" Q500                           ; create fan 2 on pin fan2 and set its frequency
      M106 P2 S1 H1:0 T45                            ; set fan 2 value. Thermostatic control is turned on
      M563 P0 D0 H1 F0                               ; define tool 0
      G10 P0 X0 Y0 Z0                                ; set tool 0 axis offsets
      G10 P0 R0 S0                                   ; set initial tool 0 active and standby temperatures to 0C
      M575 P1 S1 B57600                              ; enable support for PanelDue
      cloghopping in the codes.. read my bio to understand me.
        jay_s_uk
        the new tuning can take a long time to complete. it also looks like your bed takes a very long time to heat up and cool down.
        It may go for as many as 30 cycles.
        As far as i'm aware, C does nothing on the new tuning algorithm.
        just leave it to do its thing
        • DennisDundefined
          DennisD
          ok than i will have to get me some patience i think. thank u.
          • DennisDundefined
            DennisD
            weee 👏 i just noticed it did stopped it was giving this command
            M307 H0 R0.159 C614.2 D0.51 S1.00 V12.4
            is this a normal outcome? and is there any info to read what this all is doing
            thanks
              jay_s_uk @DennisD
              @Lampie yes, thats normal
              you can either save that using M500 and make sure you have M501 at the end of your config or replace the M307 command you should already have for your bed.
              when you come to tune your hotend, tune it as a tool rather than a heater, so M303 T0 S220.
              move the nozzle so its about 5mm above your bed so its simulating real printing
