    Mesh compensation disappeared from drop down menu
    Duet Web Control
    • Jeffrey_101undefined
      Jeffrey_101
      My mesh compensation map disappeared from my drop down menu. it was there before but now it is not there. it disappeared after I tried leveling the bed a bunch of times because the map was getting a bunch of errors. I restarted my machine a few times already and i am still have this issue.
        Jeffrey_101
          What is your screenshot showing?
          What firmware and DWC version?
          If you send G29 S1 does it make mesh compensation active?
          Jeffrey_101undefined 1 Reply Last reply Reply Quote 0
            Jeffrey_101 @Phaedrux
            @Phaedrux yes it does, there is just no graphical interface that shows the height map in the control drop down.
              What do you mean by control drop down? The compensation & calibration drop down menu?
              Again, what version of firmware and DWC are you using? Did you recently update? The heightmap display is handled by a plugin in recent versions.
              So if you're on a recent version check under Settings > General > and the plugins tab and enable the heightmap plugin.
                Jeffrey_101
                OK that worked, thank you
                  Phaedrux Moderator @Jeffrey_101
                  Happy to help.
