Height map makes my bed look warped…Why???
try 8 factor cal
Is there a list somewhere of what the different factors are? i saw one once but it only went up to 7.
https://duet3d.com/wiki/Calibrating_a_delta_printer
found it, going to give 8 a try
I think that is better, you can even see on the heightmap where i have binder clips holding the heatspreader plate down.
Calibrated 8 factors using 17 points, deviation before 0.087 after 0.056
Earlier you said it went off the bed. Are you saying it tried printing off the edge of the bed? Is your build plate 270mm+?
it actually went off during a calibration not a print, the first time through the calibration it looked good, later it went off the edge, yes the bed itself is 310,
Is this a Rostock, by chance?
in concept yes…but i think the heat bed is the only actual real rostock part,
