My print cant get a first layer
I have set my Z 0 by using a piece of paper as a height reference and sending the G92 Z0 command. i also set my trigger height z off set in my config.g file, ran the mesh compensation (G29) to get the adjusted height map for my prints. but the only problem is that it doesn't seem to be compensating during my prints.
I'm wondering if that is caused by this error produced by my slicer (cura) :
Error: in GCode file line 19: M280: missing parameter 'P'it could be irrelevant, just thought it should be noted.
regardless, my prints are failing from the initial first layer and it seems to be that the compensation is not running during the print.
for my config-override.g :
; config-override.g file generated in response to M500 at 2021-03-17 10:41
; Delta parameters
M665 L397.190:397.190:397.190 R157.922 H519.993 B155.0 X0.118 Y-0.262 Z0.000
M666 X0.663 Y-0.748 Z0.085 A0.00 B0.00
; Heater model parameters
M307 H0 A211.5 C687.6 D1.4 S1.00 V24.2 B0
M307 H1 A340.0 C140.0 D5.5 S1.00 V0.0 B0
; Workplace coordinates
G10 L2 P1 X0.00 Y0.00 Z0.00
G10 L2 P2 X0.00 Y0.00 Z0.00
G10 L2 P3 X0.00 Y0.00 Z0.00
G10 L2 P4 X0.00 Y0.00 Z0.00
G10 L2 P5 X0.00 Y0.00 Z0.00
G10 L2 P6 X0.00 Y0.00 Z0.00
G10 L2 P7 X0.00 Y0.00 Z0.00
G10 L2 P8 X0.00 Y0.00 Z0.00
G10 L2 P9 X0.00 Y0.00 Z0.00is my workplace coordinates suppose to be populated with the compensation data points???
Post your full config.g, homedelta, bed.g, your slicer start gcode. I assume a delta?
Post the results of M122 and M98 P"config.g" too. -
config:
; generated by RepRapFirmware Configuration Tool v3.2.3 on Mon Mar 15 2021 23:10:38 GMT-0700 (Mountain Standard Time); General preferences
M550 P"My Printer" ; set printer name
M665 R155 L397.19 B155 H520 ; Set delta radius, diagonal rod length, printable radius and homed height
M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M92 X80.00 Y80.00 Z80.00 E403.00 ; set steps per mm
M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2)
M906 X1200 Y1200 Z1200 E1200 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 Z0 S1 ; set minimum Z; Endstops
M574 X2 S1 P"xstop" ; configure active-high endstop for high end on X via pin xstop
M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
M574 Z2 S1 P"zstop" ; configure active-high endstop for high end on Z via pin zstop; Z-Probe
G31 P500 X0 Y0 Z1.1667; set Z probe trigger value, offset and trigger height
M557 R150 S45 ; define mesh grid; Heaters
M143 H1 S280 ; set temperature limit for heater 1 to 280C; Fans
M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on; Tools
M563 P0 S"Extruder1" D0 H1 F0 ; define tool 0
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power lossHome delta------
; homedelta.g
G91 ; relative positioning
G1 H1 X705 Y705 Z705 F6000 ; move all towers to the high end stopping at the endstops (first pass)
G1 H2 X-5 Y-5 Z-5 F3000 ; go down a few mm
G1 H1 X10 Y10 Z10 F1200 ; move all towers up once more (second pass)
G1 Z-5 F6000 ; move down a few mm so that the nozzle can be centred
G90 ; absolute positioning
G1 X0 Y0 F6000 ; move X+Y to the centreBed.g-----------
; bed.g
; called to perform automatic delta calibration via G32
; Probe the bed at 6 peripheral and 6 halfway points, and perform 6-factor auto compensation
; Before running this, you should have set up your Z-probe trigger height to suit your build, in the G31 command in config.g.
G30 P0 X0 Y149.9 H0 Z-99999
G30 P1 X129.82 Y74.95 H0 Z-99999
G30 P2 X129.82 Y-74.95 H0 Z-99999
G30 P3 X0 Y-149.9 H0 Z-99999
G30 P4 X-129.82 Y-74.95 H0 Z-99999
G30 P5 X-129.82 Y74.95 H0 Z-99999
G30 P6 X0 Y74.9 H0 Z-99999
G30 P7 X64.87 Y37.45 H0 Z-99999
G30 P8 X64.87 Y-37.45 H0 Z-99999
G30 P9 X0 Y-74.9 H0 Z-99999
G30 P10 X-64.87 Y-37.45 H0 Z-99999
G30 P11 X-64.87 Y37.45 H0 Z-99999
G30 P12 X0 Y0 H0 Z-99999 S6
; Use S-1 for measurements only, without calculations. Use S4 for endstop heights and Z-height only. Use S6 for full 6 factors
; If your Z probe has significantly different trigger heights depending on XY position, adjust the H parameters in the G30 commands accordingly. The value of each H parameter should be (trigger height at that XY position) - (trigger height at centre of bed)M122 Results
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later
Board ID: 0JD0M-9P6B2-NJ4S8-6J1F4-3S86P-9A7GL
Used output buffers: 3 of 24 (21 max)
Static ram: 27980
Dynamic ram: 93000 of which 60 recycled
Exception stack ram used: 512
Never used ram: 9520
Tasks: NETWORK(ready,348) HEAT(blocked,1224) MAIN(running,1816) IDLE(ready,80)
Owned mutexes: WiFi(NETWORK)
Last reset 00:04:16 ago, cause: power up
Last software reset at 2021-03-17 11:21, reason: User, spinning module GCodes, available RAM 9104 bytes (slot 1)
Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
Error status: 0
MCU temperature: min 29.4, current 29.7, max 30.0
Supply voltage: min 24.0, current 24.1, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
Driver 0: standstill, SG min/max 0/216
Driver 1: standstill, SG min/max 0/208
Driver 2: standstill, SG min/max 0/214
Date/time: 2021-03-17 17:51:00
Cache data hit count 418806310
Slowest loop: 4.84ms; fastest: 0.14ms
=== Storage ===
Free file entries: 10
SD card longest read time 3.2ms, write time 0.0ms, max retries 0
Hiccups: 0(0), FreeDm: 169, MinFreeDm: 166, MaxWait: 243757ms
=== MainDDARing ===
Scheduled moves: 4, completed moves: 4, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
=== AuxDDARing ===
Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
Daemon is idle in state(s) 0
Code queue is empty.M98 P"config.g"
HTTP is enabled on port 80
FTP is disabled
TELNET is disabled
Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365CStart of cura code
;FLAVOR:Repetier
;TIME:4883
;MINX:-30.301
;MINY:41.493
;MINZ:0.3
;MAXX:40.707
;MAXY:123.903
;MAXZ:50.7
;Generated with Cura_SteamEngine 4.5.0
M190 S20
M104 S215
M109 S215
M82 ;absolute extrusion mode
G28 ;Home
G92 E0
M280 P S3
G1 Z50 F25000 ; lift noizzle
G30 Z2.3 ; my noizzle hight - je mehr umso näher zum boden
M280 P0 S7 ; Lift BL Sensor
G92 E0
G92 E0
G1 F2400 E-3
;LAYER_COUNT:337
;LAYER:0
M107
G0 F3600 X-6.852 Y41.676 Z0.3
;TYPE:SKIRT
G1 F2400 E0
G1 F1800 X-6.08 Y41.885 E0.0399 -
@Jeffrey_101 said in My print cant get a first layer:
You haven't set the XY offset for the probe. That will lead to some problems.
https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Measuring_Probe_X_Y_Offset
M280 P0 S7 ; Lift BL SensorG30 doesn't take a Z parameter like that. Not sure what the intention is there.
And M280 P0 S7 isn't a valid bltouch servo position as far as I know.
@Phaedrux said in My print cant get a first layer:
M280 P0 S7 ; Lift BL Syeah the cura code generated the G30 Z2.3 and M280 S7
- the M280 S7 was the line of code that flashed the :
I'm might mess around with some of the Cura setting to see if that will fix some of it.
ill go ahead and set the xy offset as well.
so there was a setting in cura that had to be switched. I had to change the "code Flavor" from repetier host to reprap. Must have forgot to do that after I installed the board. it seems that the mesh compensations is working now.
