    Can't get printer to connect to wifi
    591
    • Jasonpgrundefined
      Jasonpgr
      I had this printer running wonderfully for the last year, but I just got a new router with a slightly different network id and now I can't get the board to learn the new wifi info. I followed the set up instructions. Using my mac I connected using SerialTools via the usb, I was able to get m115 to work, but for some reason I had to send the same command about 4-5 times before I got any response from the board. This is what it returned.
      FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 1.21 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2018-03-21
      I tried M587 S"Jasons Home" P"3382Rockwood" in order to set my network info, but no matter how many times I send the command, I see no return info or anything at all. I have tried it with the wifi module both disabled and abled. I tried a M587 to view my network list and see if it saved my new info anyway and I got this message.
      Error: M587: Failed to retrieve network list
      Any ideas as to what to try next? I have no idea why I've always struggled so much with getting the wifi working properly. I have the double straight quote thing enabled in my keyboard settings and all that. Just can't sort out what's going on here.
        droftarts administrators @Jasonpgr
        @Jasonpgr said in Can't get printer to connect to wifi:
        That's pretty old firmware you are running, and I expect you are running an old WiFi server version, too. There have been bug-fixes and improvements, too. Worth updating (without having to change your config.g and other files, which you will if you update to RRF 3.x) to 2.05.1 (https://github.com/Duet3D/RepRapFirmware/releases/tag/2.05.1), which includes a newer version of the DuetWiFiServer v1.23; you're most probably on DuetWiFiServer v1.21.
        Is your new router creating only a 5G WiFi network? Duet 2 WiFi only works with 2.4G. Sometimes you need to set the router to broadcast both, or to broadcast a separate 2.4G network.
        When adding WiFi networks and there is no stored network, it's best to connect via USB, turn the WiFi off, then on in idle mode, then add the WiFi SSID. eg:
        M552 S-1
        M552 S0
        PS I get that using Serial tools on Mac. I think, if you press delete at any point in the line, the Gcode doesn't seem to send correctly, so you have to type it correctly first time, or the command isn't recognised.
        • Jasonpgrundefined
          Jasonpgr
          I'll try the firmware update I think. I did try the turn wifi off, then idle then add the wifi. The part where it can't find the library of saved networks at all is my biggest concern. But a firmware update should create all new libraries and directories if I'm not mistaken.
          • Jasonpgrundefined
            Jasonpgr
            That reminds me though, what about all the printer settings and firmware and all that? It was kind of a huge pain to get all the motors, heaters, probe, bed, start and stop commands all that jazz, working properly. If there is some way to salvage those settings that would be super super cool.
              All the configuration of the printer is contained in the .g files in the sys folder on the SD card. All of that will stay the same between firmware updates.
              Going from 1.21 to 2.0 to 2.05.1 won't require much if any changes to the config files. Maybe a change to homing files. The big changes requiring a whole new config comes when upgrading to RRF3.
              In your case I would suggest making a backup of the contents of your SD card on your computer first.
              The first update to 2.0 will allow you to use the modern simple method of uploading the entire release zip file to update the firmware making future updates a lot easier.
              Updating from 1.21 to 2.0 will require placing the bin file and some IAP files and sending M997 S0 to initiate the flash.
              First batch of files to put on the SD card in the /sys folder:
              https://github.com/Duet3D/RepRapFirmware/releases/download/2.0/iap.bin
              https://github.com/Duet3D/RepRapFirmware/releases/download/2.0/iap4e.bin
              https://github.com/Duet3D/RepRapFirmware/releases/download/2.0/iap4s.bin
              https://github.com/Duet3D/RepRapFirmware/releases/download/2.0/Duet2CombinedFirmware.bin
              https://github.com/Duet3D/RepRapFirmware/releases/download/2.0/DuetWiFiServer.bin
              Then extract this zip file into the /www folder
              https://github.com/Duet3D/RepRapFirmware/releases/download/2.0/DuetWebControl-1.21.1.zip
              Then connect via USB and send M997 S0:1 and it should update the firmware to 2.0 and wifi server to 1.21. Send M115 to verify the firmware version. Send M122 and look at the end to verify the wifi server version.
              Now hopefully you can send the commands to clear all saved wifi networks and re-add your new SSID.
              Check the notes here to see if your new SSID and password might be affected by your terminal program sending capital letters. Use YAT for your usb terminal software if on windows to avoid any issues.
              https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M587_Add_WiFi_host_network_to_remembered_list_or_list_remembered_networks
              Then if you are able to gain access to DWC again, you can complete the firmware update to 2.05.1 like so.
              Then upload this zip file as is to the system tab in DWC. Don't extract it first.
              That should get you up to date in RRF2. Use M115 to verify again. Check your DWC version. It should be 2.0.7 (I think)
              When connecting to DWC make sure you're just using the bare IP address so that the new interface is loaded.
              Send M122 and check the wifi server version at the end. Should be 1.23.
              Going further to RRF3 would require uploading the 3.0 zip file, and then 3.2.2 zip file, and would require generating a new config file from the config tool.
              https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
              https://github.com/Duet3D/RepRapFirmware/releases/download/3.2.2/Duet2and3Firmware-3.2.2.zip
              https://configtool.reprapfirmware.org/Start
              Change log for RRF2: https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-1.x-&-2.x#version-20--duet-2-series--and-1211--other-hardware-
              • mrehorstdmdundefined
                mrehorstdmd
                @Jasonpgr
                From the M587 definition in the wiki:
                "The use of special characters in the SSID cannot be guaranteed to work. In general it's best to avoid most special characters. Spaces, periods, dashes, underscores, and other punctuation is likely ok, but special characters on the number keys likely are not safe. (@#$%^&*). If you are having troubles adding your SSID, try a simplified version with only letters and numbers."
                Try taking the space character out of the network SSID and try again (that means you have to rename it at your router).
                • Jasonpgrundefined
                  Jasonpgr
                  So I finally got around to trying these suggestion and I got the firmware up to 2.0 but replacing those files and it seems to look okay. When I connected via serialtools to try to get the wifi going I get the following start up message.
                  Executing config.g…Error: M587: Failed to add SSID to remembered list
                  HTTP is enabled on port 80
                  FTP is disabled
                  TELNET is disabled
                  Microstepping - X:16(on), Y:16(on), Z:16(on), E:16(on):16(on):16:16:16:16:16:16:16
                  Done!
                  RepRapFirmware for
                  The error at the top seems like the main issue I'm having. I finally just changed the network name at the router and I was able to get the board to connect to wifi. At least it says it is in Serial Tools.
                  M552 S1
                  WiFi module is connected to access point Jason-home, IP address 192.168.0.18
                  The problem now, is that I type that IP address in to the bar and it wont load the DWC.
                  I sent M122 and this is the message I received about the wifi server.
                  RepRapFirmware for Duet 2 WiFi/Ethernet version 2.0(RTOS) running on Duet WiFi 1.02 or later
                  Board ID: 08DGM-95BLL-N65TJ-6J9F4-3SD6R-1JXHM
                  Used output buffers: 1 of 20 (1 max)
                  • WiFi -
                    Network state is running
                    WiFi firmware version 1.21
                    WiFi MAC address 2c:3a:e8:0b:37:e5
                    WiFi Vcc 3.38, reset reason Turned on by main processor
                    WiFi flash size 4194304, free heap 15992
                    WiFi IP address 192.168.0.18
                    WiFi signal strength -61dBm, reconnections 0, sleep mode modem
                    === Expansion ===
                  Any idea what I can try next?
                    Phaedrux Moderator @Jasonpgr
                    @jasonpgr You cannot use M587 inside of config.g anymore. It only needs to be sent once to save the SSID to the wifi module.
                    @jasonpgr said in Can't get printer to connect to wifi:
                    Well at least it looks like you're connected to the SSID, so that's a good start.
                    I think you may need to double check your DWC files in the /www folder on the SD card.
                    The contents of that zip file should replace the contents of the /www folder.
                    What error message are you getting in the browser when trying to connect?
                    What URL are you trying to connect to?
                    You may need to clear your browser cache.
                    • Jasonpgrundefined
                      Jasonpgr
                      Nailed it. I guess I managed to type the IP address in wrong about 200 times last night because it seems to be working perfectly now. Now to try a print and see if any of my settings got screwed up or shifted somehow.
                        That's good. Don't stop at 2.0 though. Upgrade to at least 2.05.1 as described above. Then if everything is working you can consider updating to RRF3.
