    How is the “Height Map” Used?
    4.4k
    • tmeryhewundefined
      tmeryhew @Phaedrux
      @Phaedrux so when I run the test print the second time with G29 S0, should it still probe the bed? Because that is what it's doing right now.
      • fcwiltundefined
        fcwilt @tmeryhew
        @tmeryhew said in How is the “Height Map” Used?:
        Yes G29 S0 probes the bed.
        G29 by itself first looks for a file mesh.g - if found the file is executed.
        If the file is not found then G29 behaves just like G29 S0 and probes the bed creating the height map.
        Some folks create a height map with every print.
        Others, like me, have a separate macro for creating the height map when desired.
        That height map is then simply loaded using G29 S1 at the start of every print.
        Your printer - your choice.
          Sorry I should have said G29 S2 to clear the heightmap.
          https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_G29_Mesh_bed_probe
          • tmeryhewundefined
            tmeryhew
            This first one is with the start code set to G29 S2.
            This second picture is when I had it set to G29.
              And when it had G29 did it actually probe the bed surface?
              tmeryhewundefined 1 Reply Last reply Reply Quote 0
              • tmeryhewundefined
                tmeryhew @Phaedrux
                @Phaedrux Yes it did. It just seems like it performed worse with the mesh compensation on...
                  Ok, let's work on improving your BLtouch performance.
                  M558 P9 C"^zprobe.in" H5 F240 T12000
                  Let's try changing that to this
                  M558 P9 C"^zprobe.in" H4 F120 T6000 R0.5 A10
                  It may take slightly longer to perform the G29 but the results should be more accurate.
                  You should also go through this again and remeasure your trigger height and XY offsets for G31.
                  https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
