    Bltouch blinking red on Duet wifi+ Duex5 RRF 3
    1.5k
    • Eman74undefined
      Eman74
      I'm in the middle of a BLTouch nightmare... and I keep banging my head over it...
      My BLTouch is original latest version 3.1
      I updated to RRF 3 (lost a lot of time to get all axis and endstop working but all seems good a part from the BLTouch)
      here is my config.g related (deployprobe and retracct are standard..):
      M574 Z1 S2 ; configure Z-probe endstop for low end on Z
      M558 P9 C"^zprobe.in" H5 F100 T3000 ; BLTouch connected to Z probe IN pin, free up MOD pin
      M950 S0 C"exp.heater7" ; servo/gpio 0 is Z probe MOD pin tried also duex.pwm5 and !exp.heater7 without success
      M280 P0 S10 ; send control signal to BLTouch through servo/gpio 0
      G31 P25 X28 Y-61 Z0 ; BLTouch set offset
      M557 X50:350 Y50:350 S50 ; define mesh grid
      My Troubleshooting:
      Double-checked wiring and tested connectivity with a tester;
      verified jumper presence on duex 5
      verified led on heater7 is switched on when I start the system
      replaced BLTouch with another perfectly working on my cartesian printer with duet wifi and the behaviour is the same erroneous one, it does lights on and blink red without passing the switch-on test
      tried other heaters on the duex with same result...
      NOTE: I have 3 Z motors configured and working on Drive 5:6:7 (M584 X0 Y1 Z5:6:7 E3)
      Any help would be really appreciated I followed all documents but somewhere something is just not right and I know it shouldn't be a huge thing cause I tried with another surely working one and it does the same thing so it's a config matter somewhere...
      Emanuele
      DIY-O-Sphereundefined droftartsundefined 4 Replies Last reply Reply Quote 0
      • DIY-O-Sphereundefined
        DIY-O-Sphere @Eman74
        @Eman74 said in Bltouch blinking red on Duet wifi+ Duex5 RRF 3:
        Change that to
        M950 S0 C"!exp.heater7"
        Edit:
        The Duex is inverting the signal
        (UTC+1)
          And remove that command from the config.g
          (UTC+1)
            @Eman74
            I don't know how you proceeded. The best way is to use the config tool. There are other files besides config.g that need to be modified.
            Also deploy.g, retract.g and some of homing files.
            Please provide them too.
            (UTC+1)
              droftarts administrators @Eman74
              @Eman74 Please post your deployprobe.g and retractprobe.g files.
              Does the BLTouch do the self test at start up, ie lights up red, pin deploys and retracts twice? If not, check ground and 5V.
              Does M401 deploy the probe, does M402 retract the probe?
              What is the probe reading in DWC, 0 or 1000? If the probe is deploying, do you get a Z probe reading in DWC when you lightly push the pin? 0 or 1000?
              Posting a clear picture of your wiring may also help.
                Also see https://duet3d.dozuki.com/Wiki/BLTouch_Troubleshooting
                • Eman74undefined
                  Eman74
                  sorry guys yesterday I was out, I tried both with:
                  and
                  M950 S0 C"duex.pwm5"
                  they don't work for me.
                  I looked to all troubleshooting documents and tried using the config tool, here are
                  deployprobe.g:
                  ; deployprobe.g
                  ; called to deploy a physical Z probe
                  ; generated by RepRapFirmware Configuration Tool v3.1.3 on Sat Jul 04 2020 19:19:39 GMT-0300 (Argentina Standard Time)
                  M280 P0 S10 ; deploy BLTouch
                  and retractprobe.g:
                  ; retractprobe.g
                  ; called to retract a physical Z probe
                  M280 P0 S90 ; retract BLTouch
                  some pictures of my wiring:
                  I also tried using both 5V logic and 3.3V logic from the jumper, when I issue the M401 the BLTouch(3.1) starts blinking but does not deploy, I tried also using another BLTouch(3.1) already working on my cartesian printer but it has the same behaviour.
                  All wiring signals are tested and double-checked with a tester.
                  I'm starting to think if there is a way to connect the BLTouch all on the main board, just in case my duex has something wrong.
                  Emanuele
                  • Eman74undefined
                    Eman74
                    do I need to remove the M307 here? that's the only thing I saw somewhere in the docs but I'm not sure.
                    ; config-override.g file generated in response to M500
                    ; Heater model parameters
                    M307 H0 A99.1 C453.2 D2.2 S1.00 V0.0 B0
                    M307 H1 A372.3 C109.6 D4.6 S1.00 V24.2 B0
                    M307 H2 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                    M307 H3 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                    M307 H4 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                    M307 H5 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                    M307 H6 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                    M307 H7 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                    G10 L2 P1 X0.00 Y0.00 Z0.00
                    G10 L2 P2 X0.00 Y0.00 Z0.00
                    G10 L2 P3 X0.00 Y0.00 Z0.00
                    G10 L2 P4 X0.00 Y0.00 Z0.00
                    G10 L2 P5 X0.00 Y0.00 Z0.00
                    G10 L2 P6 X0.00 Y0.00 Z0.00
                    G10 L2 P7 X0.00 Y0.00 Z0.00
                    G10 L2 P8 X0.00 Y0.00 Z0.00
                    G10 L2 P9 X0.00 Y0.00 Z0.00
                    Emanuele
                      Yes. It’s defining H7, which is shared with PWM5, after the probe is defined, so overriding it. You haven’t posted your whole config.g, so difficult to know you were using config_override.g. Was it like this in RRF 2.x as well?
                      You haven’t answered my earlier questions. You have a clone Duex. You have non standard wiring colours, and don’t show the BLTouch itself to know what is wired where. All this makes it difficult to help you. I’m not omniscient and omnipresent!
                      • Eman74undefined
                        Eman74
                        I'm deeply sorry, I did not saw your previous question, and if any additional config file is needed please let me know.
                        here is my config.g:
                        ; generated by RepRapFirmware Configuration Tool v3.2.3 on Sat Mar 20 2021 18:21:46 GMT+0100 (Central European Standard Time)
                        G90                                            ; send absolute coordinates...
                        M83                                            ; ...but relative extruder moves
                        M550 P"EmanXY"                                 ; set printer name
                        M669 K1                                        ; select CoreXY mode
                        M552 S1                                        ; enable network
                        M586 P0 S1                                     ; enable HTTP
                        M586 P1 S0                                     ; disable FTP
                        M586 P2 S0                                     ; disable Telnet
                        M569 P0 S1                                     ; physical drive 0 goes forwards
                        M569 P1 S1                                     ; physical drive 1 goes forwards
                        M569 P2 S1                                     ; physical drive 2 goes forwards
                        M569 P3 S1                                     ; physical drive 3 goes forwards
                        M584 X0 Y1 Z5:6:7 E3                               ; set drive mapping
                        M350 X16 Y16 Z16 E16 I1                        ; configure microstepping with interpolation
                        M92 X80.00 Y80.00 Z400.00 E409.00              ; set steps per mm
                        M566 X900.00 Y900.00 Z60.00 E120.00            ; set maximum instantaneous speed changes (mm/min)
                        M203 X6000.00 Y6000.00 Z180.00 E1200.00        ; set maximum speeds (mm/min)
                        M201 X500.00 Y500.00 Z20.00 E250.00            ; set accelerations (mm/s^2)
                        M906 X800 Y800 Z800 E800 I30                   ; set motor currents (mA) and motor idle factor in per cent
                        M84 S30                                        ; Set idle timeout
                        M208 X0 Y0 Z0 S1                               ; set axis minima
                        M208 X400 Y425 Z520 S0                         ; set axis maxima
                        M574 X1 S1 P"xstop"                            ; configure active-high endstop for low end on X via pin xstop
                        M574 Y1 S1 P"ystop"                            ; configure active-high endstop for high end on Y via pin ystop
                        ;M558 P1 C"zprobe.in" H5 F120 T6000            ; set Z probe type to unmodulated and the dive height + speeds
                        ;G31 P500 X0 Y0 Z2.5                           ; set Z probe trigger value, offset and trigger height
                        ; BLTouch
                        M558 P9 C"^zprobe.in" H3 F120 T3000             ; BLTouch connected to Z probe IN pin, free up MOD pin
                        M950 S0 C"!exp.heater7"                          ; servo/gpio 1 is Z probe MOD pin
                        ;M950 S0 C"duex.pwm5" 			                ; create servo/gpio 0 on pwm5 on Duex5
                        ;M558 P9 C"^zprobe.in" H5 F100 T6000            ; set Z probe type to bltouch and the dive height + speeds old C"zprobe.in+zprobe.mod"
                        ;M950 S0 C"exp.heater7"                         ; assign GPIO port 0 to heater7 on expansion connector, servo mode
                        ;M280 P0 S10 				                    ; send control signal to BLTouch through servo/gpio 0
                        M950 H0 C"bedheat" T0                          ; create bed heater output on bedheat and map it to sensor 0
                        M307 H0 B0 S1.00                               ; disable bang-bang mode for the bed heater and set PWM limit
                        M140 H0                                        ; map heated bed to heater 0
                        M143 H0 S120                                   ; set temperature limit for heater 0 to 120C
                        M308 S1 P"e0temp" Y"thermistor" T100000 B4138  ; configure sensor 1 as thermistor on pin e0temp
                        M950 H1 C"e0heat" T1                           ; create nozzle heater output on e0heat and map it to sensor 1
                        M307 H1 B0 S1.00                               ; disable bang-bang mode for heater  and set PWM limit
                        M143 H1 S280                                   ; set temperature limit for heater 1 to 280C
                        M950 F0 C"fan0" Q500                           ; create fan 0 on pin fan0 and set its frequency
                        M106 P0 S0 H-1                                 ; set fan 0 value. Thermostatic control is turned off
                        M950 F1 C"fan1" Q500                           ; create fan 1 on pin fan1 and set its frequency
                        M106 P1 S1 H1 T45                              ; set fan 1 value. Thermostatic control is turned on
                        M950 F2 C"duex.fan4" Q500                      ; create fan 2 on pin duex.fan4 and set its frequency
                        M106 P2 S1 H1 T15                              ; set fan 2 value. Thermostatic control is turned on
                        M950 F3 C"duex.fan5" Q500                      ; create fan 3 on pin duex.fan5 and set its frequency
                        M106 P3 S1 H1 T15                              ; set fan 3 value. Thermostatic control is turned on
                        M950 F4 C"duex.fan6" Q500                      ; create fan 4 on pin duex.fan6 and set its frequency
                        M106 P4 S1 H1 T15                              ; set fan 4 value. Thermostatic control is turned on
                        M950 F5 C"duex.fan7" Q500                      ; create fan 5 on pin duex.fan7 and set its frequency
                        M106 P5 S1 H1 T45                              ; set fan 5 value. Thermostatic control is turned on
                        M950 F6 C"duex.fan8" Q500                      ; create fan 6 on pin duex.fan8 and set its frequency
                        M106 P6 S1 H1 T45                              ; set fan 6 value. Thermostatic control is turned on
                        M563 P0 D0 H1 F0                               ; define tool 0
                        G10 P0 X0 Y0 Z0                                ; set tool 0 axis offsets
                        G10 P0 R0 S0                                   ; set initial tool 0 active and standby temperatures to 0C
                        M575 P1 S1 B57600                              ; enable support for PanelDue
                        All original only duex5 I think is not (I don't recall if I bought the original one it was long ago, the rest is all original 100%), the original cable provided was too short, I just replaced it.
                        regarding the M401 when I launch it the BLTouch starts to blink.
                        when nothing is wired I can see a red 1000 on z-probe, when all is wired the value is 0.
                        I changed the config so many times that my SD cards started to fail, I just replaced it with a 32Gb one.
                        I removed the M307 from the override file on the H7 but keeps doing it, I'll proceed disabling all M307 and give it a try.
                        My wiring it's still not perfect, and it's my first ever build... but here's the picture (I tried to hide the flat cable which cover the rest):
                        Emanuele
                        Eman74undefined dc42undefined 2 Replies Last reply Reply Quote 0
                        • Eman74undefined
                          Eman74 @Eman74
                          Emanuele
                            dc42 administrators @Eman74
                            M950 S0 C"!exp.heater7" ; servo/gpio 1 is Z probe MOD pin ;M950 S0 C"duex.pwm5" ; create servo/gpio 0 on pwm5 on Duex5
                            As you have connected the BLTouch servo input to the DueX PWM output, the second M950 command is the correct one.
                            Eman74undefined 1 Reply Last reply Reply Quote 0
                            • Eman74undefined
                              Eman74 @dc42
                              @dc42 I just retried it but it doesn't work, it doesn't even try to blink when I launch the M401.
                              It's so frustrating, my other duet wifi on the cartesian works sweetly.
                              can I try using some PWM on the duet wifi to make the bltouch work? (just thinking to use the duex5 only for motors and 12v fans up until I'll buy an original one)
                              Emanuele
                                @Eman74 Apologies, thinking about it I was wrong about M307 in config_override.g. It shouldn’t matter as M950 sets the pin in config.g. It would cause problems in RRF 2.x.
                                I’ll ask once more: does the probe deploy and retract on power up? If it doesn’t, disconnect all wiring except +5V and GND, and work out why it doesn’t.
                                Somewhere between the BLTouch and the Duex, the wiring changes, and I can’t see where (on mobile). I suspect either a short between wires, or a swapped wire.
                                Edit: unfortunately there are no other PWM pins in the board apart from those on the expansion connector.
                                • Eman74undefined
                                  Eman74 @droftarts
                                  @droftarts my english is probably not good enough, that's also on mr, unfortunately no matter what config I used till now at the startup nothing happens, sometimes I so the bltouch starting blinking (as if the deploy test was failing).
                                  With a tester I made sure all signals were proper directly from the BlTouch connection up to the other end, so no swapped wires. On top of that I can tell you that wires on the probe (Black correspond to black on the BLTouch and Green correspond to white on the BLTouch) and on the servo (Blue is Brown, Red is Red and yellow is green on the BLTouch)
                                  I quitted buying non original things long time ago I'm starting to suspect all this mess is cause of the F.... duex clone... anyway I'll redo all pin crimping, just in case.
                                  I tried using only 5V and GND with and without Z Probe with all available M950 (just in case... with no luck)
                                  Now I'm not the kind of person which leave things unresolved so I started looking around the DUEX (cause I felt the problem was there...). Now I don't know if this happens also on the original DUEX but the clone do not provide power to the PWM...
                                  ...wait for it...
                                  ...rolling the drums....
                                  unless you remember to put the jumper on the 5V AUX Jumper select...
                                  so.. now it works perfectly with the proper config:
                                  M558 P9 C"^zprobe.in" H5 F120 T6000             ; BLTouch connected to Z probe IN pin, free up MOD pin
                                  IT WORKSSSS!!!!
                                  Thank you all for the help, Grazie, Merci.
                                  Emanuele
                                    @Eman74 glad you worked it out! My next suggestion was to remove the Duex and try it directly on the Duet pins. That should have narrowed it down to wiring or the Duex.
                                    • Eman74undefined
                                      Eman74 @droftarts
                                      @droftarts Thank you very much Ian, at the moment I can finally see the bltouch running a full self test at printer startup which is a huge improvement finally.
                                      When I send M401 the pin is deployed and when I send M402 the pin is retracted but when I try to home as soon as the pin retracts the bltouch starts blinking and the bed keep rising towards my hotend (trying triggering manually the bltouch to avoid the hotend digging in my bed)
                                      here is my homez.g:
                                      ; homez.g
                                      ; called to home the Z axis
                                      G91                ; relative positioning
                                      G1 H2 Z5 F6000     ; lift Z relative to current position
                                      G90                ; absolute positioning
                                      G1 X200 Y210 F6000 ; Probe Z on the center of the bed
                                      G30                ; home Z by probing the bed
                                      ;G91               ; relative positioning
                                      ;G1 Z5 F100        ; lift Z relative to current position
                                      ;G90               ; absolute positioning
                                      I completely deleted the config-override and my config.g for z is:
                                      ; BLTouch
                                      G31 P25 X28 Y-61 Z0.0    		                    ; BLTouch set offset
                                      is there any additional option I can use to improve probing... like adding something on the zprobe.in or similar? Any idea of what can it be? (I'll keep looking for all possible solutions in the meantime)
                                      Emanuele
                                      DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
                                        @Eman74
                                        The homez looks fine.
                                        Please post the homeall.g (In the older ones there was a call for deployprobe.g witch should be replaced )
                                        (UTC+1)
                                        • Eman74undefined
                                          Eman74 @DIY-O-Sphere
                                          @DIY-O-Sphere sure, here it is:
                                          ; homeall.g
                                          ; called to home all axes
                                          G1 H1 X-348 Y326 F3000 ; move quickly to X or Y endstop and stop there (first pass)
                                          G1 H1 X-348            ; home X axis
                                          G1 H1 Y326             ; home Y axis
                                          G1 X5 Y-5 F6000        ; go back a few mm
                                          G1 H1 X-348 F360       ; move slowly to X axis endstop once more (second pass)
                                          G1 H1 Y326             ; then move slowly to Y axis endstop
                                          Emanuele
                                            @Eman74
                                            Seems to be right.
                                            Does the Bltouch perform the selftest at the power up?
                                            (UTC+1)
