Duet 2: Trying to output PWM on heater pin
Hi everyone,
I want to output a PWM on the "E0 Heater" pin, but I can't seem to get it to work, heres what I've been trying:
M307 H1 A-1 C-1 D-1 (disable heater)
M571 P1 F500 S1 (500hz PWM to heater pin, as I understand)I'm new to Duet3D so I expect that I'm missing some simple information or misunderstanding something. I'm using the Duet 2 wifi board w/ firmware 2.03 and I'm trying to use the Web Controller for this, can someone tell me what I'm doing wrong or point me in the right direction?
What are you trying to control?
2.03 is nearly 2 years old. Perhaps a good time to update to RRF3? It's much easier to use pins in different ways in V3 firmware. It's much more generalized.
If you still have access to DWC. Upload these 3 zip files, one at a time in the system tab. Don't extract them. Reboot after each. Use M115 to verify the firmware has been applied.
https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
https://github.com/Duet3D/RepRapFirmware/releases/download/3.2.2/Duet2and3Firmware-3.2.2.zip
That will get your firmware and DWC up to date.You can see the change logs here:
https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.xFor your config, might be a good idea to run through the configurator tool and generate a fresh set for RRF3.
https://configtool.reprapfirmware.org/StartBackup your existing config files in the sys folder in case you want to switch back to RRF3. IT’s easy to switch back and forth, just upload the zip file for the version you want and then upload your config files.
These documents will come in handy during the conversion.
https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview
https://duet3d.dozuki.com/Wiki/Gcode -
I have a DC motor that I am using as an extruder (for a concrete 3d printer), I wanted to control the speed of the motor by adjusting the voltage coming out of the battery, using a solid state relay. The PWM would just toggle the relay.
This is an inherited project so the previous team already had a bunch of stuff setup, and I didn't want to change anything because as it stands everything but the PWM works. I didn't realize the firmware was so old though, I will update it + update config later today
Is the firmware being finnicky the issue?
@ara1123
Using a SSR with PWM is unusual to say the least.
I always heard to use bang-bang mode for SSR driven heaters. But that's not an option for a DC motor.
I don't know the motor data, but if possible consider to use a hobby-RC motorcontroller.
BTW: There is no need to repurpose the heater channel, just for sending a PWM signal. Any PWM capable pin (fan or external GPIO) will do.
The only exception would be, when the SSR requires a 12V or 24V enable signal. Then you can use the fan headers but no GPIO pins. -
In that case maybe hold off on updating the firmware, or at least ensure you have everything backed up first. You'll want to be very familiar with any customizations made before attempting to update the firmware for RRF3.
Using PWM and an SSR shouldn't be a problem. It's used for bed heaters all the time.
Are you sure you've identified the correct logical pin number you wish to use? P1?
https://duet3d.dozuki.com/Wiki/Gcode#Section_M571_Set_output_on_extrude
Also check your config-override.g file for any M307 H1 commands that may undo your disable command.
I will look into hobby-RC motorcontrollers, I didn't want to overcomplicate the system by introducing another major component but if this doesn't pan out then I will have to
Also, yea there are several customizations specific to our printer- the config file is fairly short and doesn't have any M307 commands or any commands relating to heater/fan functions. I've been putting in those commands in the console and I have it wired up to a little LED on a breadboard with some resistors just to verify functionality.
What's weird is that both the VIN and PWM pin on the E0 screw terminals are reading 24V? No matter what command I send to P1, there isnt any change coming out of those terminals.
To be of much more help I'd need to see the config.g and a diagram or photo of how you have it wired.
Of course- I'll attach an image and the config is below. Three 100ohm resistors in series with the LED, we originally tried PWM pin and ground but nothing was happening, so our current wiring is going into both E0 terminals:
; generated by RepRapFirmware Configuration Tool v2.1.8 on Sun Jan 19 2020 10:21:10 GMT-0500 (Eastern Standard Time); General preferences
M550 P"My Printer" ; set printer name; Network
;M551 P"MSDP21652" ; set password
;M552 S1 ; enable network
;M586 P0 S1 ; enable HTTP
;M586 P1 S0 ; disable FTP
;M586 P2 S0 ; disable Telnet
M552 S0 ; Turn network on
M552 S-1
M589 S"P21652" P"MSDP21652" I192.168.1.1
M552 S2; Drives
; When Geared Nema17 is on X axis need to change direction
;M569 P0 S0
M569 P1 S0 ; physical drive 1 goes forwards
M569 P3 S0 ; physical drive 3 goes forwards
M584 X0 Y1:3 U1 V3 Z2 E4 ; set drive mapping
;M350 X2 Y16 Z16 E16 I1 ; configure microstepping with interpolation GEARED NEMA17
M92 X645.00 Y645.00 Z4000.00 E420.00 ; set steps per mm NOTE: This is specifically calibrated for the NEMA 17 ungeared.
;M92 X256.00 Y420.00 Z4000.00 E420.00 ; set steps per mm NOTE: This is specifically calibrated for the NEMA 17 geared.
M566 X450.00 Y450.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X10000.00 Y3000.00 Z180.00 E3001.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z20.00 E150.00 ; set accelerations (mm/s^2)
M906 X1800 Y2000 Z800 E2400 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X900 Y10000 Z10000 S0 ; set axis maxima; Endstops
M574 X1 Y0 Z0 S0 ; set active low and disabled endstops; Z-Probe
M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
M557 X15:215 Y15:195 S20 ; define mesh grid; Heaters
; M140 H-1 ; disable heated bed; Fans
M563 P0 D0 F0 ; define tool 0
T0 ; select first tool -
@ara1123 said in Duet 2: Trying to output PWM on heater pin:
M571 P1 F500 S1 (500hz PWM to heater pin, as I understand)I assume this is being sent outside of the config.g?
How are you executing the extrusion move?
And you're trying to use logical pin 1, but are wired to E0.
Did you consult the table here?
https://duet3d.dozuki.com/Wiki/Using_servos_and_controlling_unused_IO_pins#Section_RepRapFirmware_2_x_and_earlier -
Yes, those commands are sent outside of it. As for pin 1, I thought E0_heater = Heater 1 = Pin 1 based on the link you sent and this one: https://duet3d.dozuki.com/Wiki/Heaters
I finally realized that M571 required an extrusion move in order to work, I feel really dumb for not realizing that sooner but it is what it is. I am using the extrude/retract feature on DWC for that and I finally got the LED to blink but it doesn't seem to reflect the PWM frequency I send through the console. I sent in:
M307 H1 A-1 C-1 D-1
M571 P1 F1 S1And every time I extruded the LED would toggle for the duration of the extrusion, then would go back to normal (on/off depending on wiring). Its one step better than it was before as I can see some kind of response now, but no matter what frequency I pass in there is no reflection in the LED. Perhaps theres something wrong with the circuit so my next step is to throw it into an oscilloscope and see if its outputting the frequency Im requesting
@ara1123
A scope is a good idea.
Our eyes are betraying us too much.
You can't see a LED flicker above 20Hz or so....
