    DWC timing out
    • Cinpro
      Cinpro last edited by
      My DWC is acting up again, it keeps timing out, thats the error it gives me anyway. I can be connected and not using the machine and it will sit there for an hour and be fine no errors. a few min into a print and BAM disconnected. I have reset my router to factory and started fresh (it does it less after this) and reloaded my card on the board. are there settings that I need to play with to tweak this? What else can I look for?
      • minim
        minim last edited by
        It's kinda hard to know what firmware you are on or even what kind of board you are running without the info.. M122?
        • Cinpro
          Used output buffers: 2 of 32 (10 max)
          Static ram used: 24996
          Dynamic ram used: 89628
          Recycled dynamic ram: 64
          Stack ram used: 1104 current, 3784 maximum
          Never used ram: 12600
          Last reset 00:40:52 ago, cause: power up
          Last software reset code 0x0003, HFSR 0x00000000, CFSR 0x00000000, ICSR 0x00400000, BFAR 0xe000ed38, SP 0xffffffff
          Spinning module during software reset: GCodes, available RAM 1024 bytes (slot 3)
          Error status: 0
          Free file entries: 10
          MCU temperature: min 49.4, current 49.7, max 52.0
          Supply voltage: min 24.3, current 24.4, max 24.5, under voltage events: 0, over voltage events: 0
          Driver 0: standstill
          Driver 1: standstill
          Driver 2: standstill
          Driver 3: standstill
          Driver 4: standstill
          Date/time: 2017-08-15 20:09:33
          Slowest main loop (seconds): 0.004150; fastest: 0.000000
          MaxReps: 0, StepErrors: 0, MaxWait: 0ms, Underruns: 0, 0
          Scheduled moves: 0, completed moves: 0
          Bed compensation in use: none
          Probe change coordinates:
          Bed heater = 0, chamber heater = -1
          Segments left: 0
          Movement lock held by null
          http is idle in state(s) 0
          telnet is idle in state(s) 0
          file is idle in state(s) 0
          serial is idle in state(s) 0
          aux is idle in state(s) 0
          daemon is idle in state(s) 0
          queue is idle in state(s) 0
          Code queue is empty.
          === Network ===
          State: 4
          === Webserver ===
          HTTP sessions: 1 of 8
          FTP connections: 0, state 0
          Telnet connections: 0, state 0
            As the M122 report doesn't Inc!ude the firmware version, you must be a few versions out of date. I suggest you start by upgrading to firmware 1.19. Read the important upgrade notes first.
            • Cinpro
              I forgot, is that on Github or here?
              • Cinpro
                I got it, both are updated now to 1.19
