    How to get fans from the Duet 2 wifi expansion pins?
    • Sphyloidundefined
      Sphyloid
      This is something I find most vexing, it seems like such a simple task at first.
      Perhaps the Duex expansion boards have logic of their own that creates the new fans and feeds a signal digitally to minimize pin use.
      If this is the case, then it would spell the failure of my current goal as I would have to resort to a fan splitter running the two part cooling fans in parallel, and giving the two hotend the remaining two stock conditional fan headers.
        You cannot run a fan directly from the expansion header.
          The DueX uses a I2C expander chip + mosfets to drive the additional fans, and a 74HCT02 chip + mosfets to drive the additional heater heater outputs.
          Sphyloidundefined 1 Reply Last reply Reply Quote 1
          • Sphyloidundefined
            Sphyloid @dc42
            This post is deleted!
