Problem with downgrade to 3.1.1
M115 is showing you the firmware version, and in the browser you are seeing the DWC version installed.
If you want to change the DWC version, you need to upload the version you want.
https://github.com/Duet3D/RepRapFirmware/releases/download/3.1.1/DuetWebControl-SD-3.1.1.zip
They can be found alongside the other files in the version release.
@Phaedrux thx.
i tried that but it doesn´t work... i uploaded the file and dwc was unzipping but nothing else happened...
while downgrade i had an error and not all command worked. i guess there is something wrong
i got it with bussa. it´s done thx
@ErwinH78 said in Problem with downgrade to 3.1.1:
Glad to hear it.
Just out of curiosity why did you want to go back to 3.1.1?
