    Can't build RRF 3.3
    Firmware developers
    665
    • User3Dundefined
      User3D
      I followed steps provided to build 3.3 at https://github.com/Duet3D/RepRapFirmware/wiki/Building-RepRapFirmware
      According to which I am supposed to select Duet3_V06 as build configuration. But eclipse doesn't show that option. So I proceeded with option Duet3 .
      I was able to build successfully with "Gnu make builder" , but this didn't generate .elf/.bin . So I chose "CDT Internal builder" ( https://reprap.org/forum/read.php?416,718274 ) But doing so resulted in following error:
      I also observed that some of the folders are disabled:
      To enable Duet3_V06 , I deleted unnecessary build configurations. It enabled the folder. But I still don't get Duet3_V06 in options and build fails with above error.
      Board: Duet3 MB6HC
      Projects :
      CoreNG dev
      FreeRTOS 3.3-dev
      RRFLibraries 3.3-dev
      CANlib 3.3-dev
      RepRapFirmware 3.3-dev(also tried with 3.3beta1 tag)
      How do I solve it?
        droftarts administrators @User3D
        @User3D said in Can't build RRF 3.3:
        Projects :
        CoreNG dev
        FreeRTOS 3.3-dev
        CANlib 3.3-dev
        I know the instructions say it is for Mini 5+ only, but maybe use CoreN2G library: https://github.com/Duet3D/CoreN2G
        It does say it's needed 'To build RepRapFirmware 3.3 from the latest development sources'.
        User3Dundefined 1 Reply Last reply Reply Quote 1
        • User3Dundefined
          User3D @droftarts
          @droftarts I tired that too. I kept both coreNG and coreN2G which didn't work so I built after removing coreNG. But both failed :
          09:57:03 **** Incremental Build of configuration Duet3 for project RepRapFirmware ****
          Info: Internal Builder is used for build
          arm-none-eabi-gcc -LC:\Users\Nikunj\eclipse-workspace\Firmware\CoreN2G\SAME70_CAN_SDHC_USB_RTOS -LC:\Users\Nikunj\eclipse-workspace\Firmware\RRFLibraries\SAME70_RTOS -LC:\Users\Nikunj\eclipse-workspace\Firmware\FreeRTOS\SAME70 -LC:\Users\Nikunj\eclipse-workspace\Firmware\CANlib\SAME70_RTOS --specs=nosys.specs -Os -Wl,--gc-sections -Wl,--fatal-warnings -mcpu=cortex-m7 -mfpu=fpv5-d16 -mfloat-abi=hard -TC:\Users\Nikunj\eclipse-workspace\Firmware\RepRapFirmware\src\Hardware\SAME70\same70q20b_flash.ld -Wl,-Map,C:\Users\Nikunj\eclipse-workspace\Firmware\RepRapFirmware\Duet3/Duet3Firmware_MB6HC.map -o Duet3Firmware_MB6HC.elf -mthumb -Wl,--cref -Wl,--check-sections -Wl,--gc-sections -Wl,--entry=Reset_Handler -Wl,--unresolved-symbols=report-all -Wl,--warn-common -Wl,--warn-section-align -Wl,--warn-unresolved-symbols -Wl,--start-group src\Accelerometers\Accelerometers.o src\CAN\CanInterface.o src\CAN\CanMessageGenericConstructor.o src\CAN\CanMotion.o src\CAN\CommandProcessor.o src\CAN\ExpansionManager.o src\Comms\AuxDevice.o .
          src\Tools\Spindle.o src\Tools\Tool.o src\bossa\Applet.o src\bossa\BossaFlash.o src\bossa\Device.o src\bossa\EefcFlash.o src\bossa\Flasher.o src\bossa\Samba.o src\bossa\WordCopyApplet.o src\bossa\WordCopyArm.o src\bossa\WordCopyArm.o src\libc\memcmp.o src\libc\memcpy.o src\libc\memmove.o src\libc\memset.o src\libc\nano-mallocr.o src\libc\strptime.o src\libcpp\eh_alloc.o src\libcpp\vterminate.o -lCoreN2G -lRRFLibraries -lFreeRTOS -lCANlib -lsupc++ -Wl,--end-group -lm
          c:/program files (x86)/gnu arm embedded toolchain/10 2020-q4-major/bin/../lib/gcc/arm-none-eabi/10.2.1/../../../../arm-none-eabi/bin/ld.exe: src\bossa\WordCopyArm.o: in function start': (.text+0x0): multiple definition of start'; src\bossa\WordCopyArm.o:(.text+0x0): first defined here
          c:/program files (x86)/gnu arm embedded toolchain/10 2020-q4-major/bin/../lib/gcc/arm-none-eabi/10.2.1/../../../../arm-none-eabi/bin/ld.exe: src\bossa\WordCopyArm.o: in function stack': (.text+0x20): multiple definition of stack'; src\bossa\WordCopyArm.o:(.text+0x20): first defined here
          c:/program files (x86)/gnu arm embedded toolchain/10 2020-q4-major/bin/../lib/gcc/arm-none-eabi/10.2.1/../../../../arm-none-eabi/bin/ld.exe: src\bossa\WordCopyArm.o: in function reset': (.text+0x24): multiple definition of reset'; src\bossa\WordCopyArm.o:(.text+0x24): first defined here
          c:/program files (x86)/gnu arm embedded toolchain/10 2020-q4-major/bin/../lib/gcc/arm-none-eabi/10.2.1/../../../../arm-none-eabi/bin/ld.exe: src\bossa\WordCopyArm.o: in function dst_addr': (.text+0x28): multiple definition of dst_addr'; src\bossa\WordCopyArm.o:(.text+0x28): first defined here
          c:/program files (x86)/gnu arm embedded toolchain/10 2020-q4-major/bin/../lib/gcc/arm-none-eabi/10.2.1/../../../../arm-none-eabi/bin/ld.exe: src\bossa\WordCopyArm.o: in function src_addr': (.text+0x2c): multiple definition of src_addr'; src\bossa\WordCopyArm.o:(.text+0x2c): first defined here
          c:/program files (x86)/gnu arm embedded toolchain/10 2020-q4-major/bin/../lib/gcc/arm-none-eabi/10.2.1/../../../../arm-none-eabi/bin/ld.exe: src\bossa\WordCopyArm.o: in function words': (.text+0x30): multiple definition of words'; src\bossa\WordCopyArm.o:(.text+0x30): first defined here
          c:/program files (x86)/gnu arm embedded toolchain/10 2020-q4-major/bin/../lib/gcc/arm-none-eabi/10.2.1/../../../../arm-none-eabi/bin/ld.exe: src\bossa\WordCopyApplet.o: in function WordCopyApplet::WordCopyApplet(Samba&, unsigned long)': WordCopyApplet.cpp:(.text._ZN14WordCopyAppletC2ER5Sambam+0x34): warning: undefined reference to WordCopyApplet::applet'
          c:/program files (x86)/gnu arm embedded toolchain/10 2020-q4-major/bin/../lib/gcc/arm-none-eabi/10.2.1/../../../../arm-none-eabi/bin/ld.exe: src\bossa\WordCopyApplet.o: in function WordCopyApplet::setDstAddr(unsigned long)': WordCopyApplet.cpp:(.text._ZN14WordCopyApplet10setDstAddrEm+0x10): warning: undefined reference to WordCopyApplet::applet'
          c:/program files (x86)/gnu arm embedded toolchain/10 2020-q4-major/bin/../lib/gcc/arm-none-eabi/10.2.1/../../../../arm-none-eabi/bin/ld.exe: src\bossa\WordCopyApplet.o: in function WordCopyApplet::setSrcAddr(unsigned long)': WordCopyApplet.cpp:(.text._ZN14WordCopyApplet10setSrcAddrEm+0x10): warning: undefined reference to WordCopyApplet::applet'
          c:/program files (x86)/gnu arm embedded toolchain/10 2020-q4-major/bin/../lib/gcc/arm-none-eabi/10.2.1/../../../../arm-none-eabi/bin/ld.exe: src\bossa\WordCopyApplet.o: in function WordCopyApplet::setWords(unsigned long)': WordCopyApplet.cpp:(.text._ZN14WordCopyApplet8setWordsEm+0x10): warning: undefined reference to WordCopyApplet::applet'
          collect2.exe: error: ld returned 1 exit status
          Info: Parallel threads used: 1
          09:57:04 Build Failed. 16 errors, 0 warnings. (took 718ms)
            The build configuration for the MB6HC is just called Duet3 in the 3.3-dev source code, not Duet3_V06 any more.
            The 3.3-dev branch uses CoreN2G for all build configurations, not CoreNG.
            The linker errors are because of this part of the command line:
            That file has been included twice. I don't know why that is. However. Eclipse no longer recommends the internal builder, so I suggest you revert to using make. The output files should be build in the RepRapFirmware/Duet3 folder.
            User3Dundefined 1 Reply Last reply Reply Quote 2
            • User3Dundefined
              User3D @dc42
              @dc42 Doing so is generating:
              I don't see any .elf generated ? what am I supposed to do with these generated files to get .bin?
                It should not be creating those subdirectories, instead it should put all the .o files directly in /src.. Please use the version of 'make' that we recommend.
                User3Dundefined 1 Reply Last reply Reply Quote 0
                • User3Dundefined
                  User3D @dc42
                  @dc42 Changed it. But now I get :
                  Building target: Duet3Firmware_MB6HC.elf
                  Invoking: Cross G++ Linker
                  arm-none-eabi-gcc -L"C:\Users\Nikunj\eclipse-workspace\Firmware\CoreN2G\SAME70_CAN_SDHC_USB_RTOS" -L"C:\Users\Nikunj\eclipse-workspace\Firmware\RRFLibraries\SAME70_RTOS" -L"C:\Users\Nikunj\eclipse-workspace\Firmware\FreeRTOS\SAME70" -L"C:\Users\Nikunj\eclipse-workspace\Firmware\CANlib\SAME70_RTOS" --specs=nosys.specs -Os -Wl,--gc-sections -Wl,--fatal-warnings -mcpu=cortex-m7 -mfpu=fpv5-d16 -mfloat-abi=hard -T"C:\Users\Nikunj\eclipse-workspace\Firmware\RepRapFirmware\src\Hardware\SAME70\same70q20b_flash.ld" -Wl,-Map,"C:\Users\Nikunj\eclipse-workspace\Firmware\RepRapFirmware\Duet3/Duet3Firmware_MB6HC.map" -o "Duet3Firmware_MB6HC.elf" -mthumb -Wl,--cref -Wl,--check-sections -Wl,--gc-sections -Wl,--entry=Reset_Handler -Wl,--unresolved-symbols=report-all -Wl,--warn-common -Wl,--warn-section-align -Wl,--warn-unresolved-symbols -Wl,--start-group  ./src/libcpp/eh_alloc.o ./src/libcpp/vterminate.o  ./src/libc/memcmp.o ./src/libc/memcpy.o ./src/libc/memmove.o ./src/libc/memset.o ./src/libc/nano-mallocr.o ./src/libc/strptime.o  ./src/bossa/Applet.o ./src/bossa/BossaFlash.o ./src/bossa/Device.o ./src/bossa/EefcFlash.o ./src/bossa/Flasher.o ./src/bossa/Samba.o ./src/bossa/WordCopyApplet.o ./src/bossa/WordCopyArm.o  ./src/Tools/Filament.o ./src/Tools/Spindle.o ./src/Tools/Tool.o  ./src/Storage/CRC16.o ./src/Storage/CRC32.o ./src/Storage/FileInfoParser.o ./src/Storage/FileStore.o ./src/Storage/MassStorage.o  ./src/PrintMonitor/PrintMonitor.o  ./src/Platform/Heap.o ./src/Platform/Logger.o ./src/Platform/OutputMemory.o ./src/Platform/Platform.o ./src/Platform/PortControl.o ./src/Platform/RepRap.o ./src/Platform/Roland.o ./src/Platform/Scanner.o ./src/Platform/Tasks.o  ./src/ObjectModel/ObjectModel.o  ./src/Networking/LwipEthernet/Lwip/src/netif/bridgeif.o ./src/Networking/LwipEthernet/Lwip/src/netif/bridgeif_fdb.o ./src/Networking/LwipEthernet/Lwip/src/netif/ethernet.o ./src/Networking/LwipEthernet/Lwip/src/netif/lowpan6.o ./src/Networking/LwipEthernet/Lwip/src/netif/lowpan6_ble.o ./src/Networking/LwipEthernet/Lwip/src/netif/lowpan6_common.o ./src/Networking/LwipEthernet/Lwip/src/netif/slipif.o ./src/Networking/LwipEthernet/Lwip/src/netif/zepif.o  ./src/Networking/LwipEthernet/Lwip/src/core/ipv6/dhcp6.o ./src/Networking/LwipEthernet/Lwip/src/core/ipv6/ethip6.o ./src/Networking/LwipEthernet/Lwip/src/core/ipv6/icmp6.o ./src/Networking/LwipEthernet/Lwip/src/core/ipv6/inet6.o ./src/Networking/LwipEthernet/Lwip/src/core/ipv6/ip6.o ./src/Networking/LwipEthernet/Lwip/src/core/ipv6/ip6_addr.o ./src/Networking/LwipEthernet/Lwip/src/core/ipv6/ip6_frag.o ./src/Networking/LwipEthernet/Lwip/src/core/ipv6/mld6.o ./src/Networking/LwipEthernet/Lwip/src/core/ipv6/nd6.o  ./src/Networking/LwipEthernet/Lwip/src/core/ipv4/autoip.o ./src/Networking/LwipEthernet/Lwip/src/core/ipv4/dhcp.o ./src/Networking/LwipEthernet/Lwip/src/core/ipv4/etharp.o ./src/Networking/LwipEthernet/Lwip/src/core/ipv4/icmp.o ./src/Networking/LwipEthernet/Lwip/src/core/ipv4/igmp.o ./src/Networking/LwipEthernet/Lwip/src/core/ipv4/ip4.o ./src/Networking/LwipEthernet/Lwip/src/core/ipv4/ip4_addr.o ./src/Networking/LwipEthernet/Lwip/src/core/ipv4/ip4_frag.o  ./src/Networking/LwipEthernet/Lwip/src/core/altcp.o ./src/Networking/LwipEthernet/Lwip/src/core/altcp_alloc.o ./src/Networking/LwipEthernet/Lwip/src/core/altcp_tcp.o ./src/Networking/LwipEthernet/Lwip/src/core/def.o ./src/Networking/LwipEthernet/Lwip/src/core/dns.o ./src/Networking/LwipEthernet/Lwip/src/core/inet_chksum.o ./src/Networking/LwipEthernet/Lwip/src/core/init.o ./src/Networking/LwipEthernet/Lwip/src/core/ip.o ./src/Networking/LwipEthernet/Lwip/src/core/mem.o ./src/Networking/LwipEthernet/Lwip/src/core/memp.o ./src/Networking/LwipEthernet/Lwip/src/core/netif.o ./src/Networking/LwipEthernet/Lwip/src/core/pbuf.o ./src/Networking/LwipEthernet/Lwip/src/core/raw.o ./src/Networking/LwipEthernet/Lwip/src/core/stats.o ./src/Networking/LwipEthernet/Lwip/src/core/sys.o ./src/Networking/LwipEthernet/Lwip/src/core/tcp.o ./src/Networking/LwipEthernet/Lwip/src/core/tcp_in.o ./src/Networking/LwipEthernet/Lwip/src/core/tcp_out.o ./src/Networking/LwipEthernet/Lwip/src/core/timeouts.o ./src/Networking/LwipEthernet/Lwip/src/core/udp.o  ./src/Networking/LwipEthernet/Lwip/src/apps/netbiosns/netbiosns.o  ./src/Networking/LwipEthernet/Lwip/src/apps/mdns/mdns.o  ./src/Networking/LwipEthernet/Lwip/src/api/api_lib.o ./src/Networking/LwipEthernet/Lwip/src/api/api_msg.o ./src/Networking/LwipEthernet/Lwip/src/api/err.o ./src/Networking/LwipEthernet/Lwip/src/api/if_api.o ./src/Networking/LwipEthernet/Lwip/src/api/netbuf.o ./src/Networking/LwipEthernet/Lwip/src/api/netdb.o ./src/Networking/LwipEthernet/Lwip/src/api/netifapi.o ./src/Networking/LwipEthernet/Lwip/src/api/sockets.o ./src/Networking/LwipEthernet/Lwip/src/api/tcpip.o  ./src/Networking/LwipEthernet/GMAC/ethernet_sam.o  ./src/Networking/LwipEthernet/LwipEthernetInterface.o ./src/Networking/LwipEthernet/LwipSocket.o  ./src/Networking/FtpResponder.o ./src/Networking/HttpResponder.o ./src/Networking/Network.o ./src/Networking/NetworkBuffer.o ./src/Networking/NetworkInterface.o ./src/Networking/NetworkResponder.o ./src/Networking/TelnetResponder.o ./src/Networking/UploadingNetworkResponder.o  ./src/Movement/StepperDrivers/DriverMode.o ./src/Movement/StepperDrivers/TMC22xx.o ./src/Movement/StepperDrivers/TMC2660.o ./src/Movement/StepperDrivers/TMC51xx.o  ./src/Movement/Kinematics/CoreKinematics.o ./src/Movement/Kinematics/FiveBarScaraKinematics.o ./src/Movement/Kinematics/HangprinterKinematics.o ./src/Movement/Kinematics/Kinematics.o ./src/Movement/Kinematics/LinearDeltaKinematics.o ./src/Movement/Kinematics/PolarKinematics.o ./src/Movement/Kinematics/RotaryDeltaKinematics.o ./src/Movement/Kinematics/RoundBedKinematics.o ./src/Movement/Kinematics/ScaraKinematics.o ./src/Movement/Kinematics/ZLeadscrewKinematics.o  ./src/Movement/HeightControl/HeightController.o  ./src/Movement/BedProbing/Grid.o ./src/Movement/BedProbing/RandomProbePointSet.o  ./src/Movement/DDA.o ./src/Movement/DDARing.o ./src/Movement/DriveMovement.o ./src/Movement/InputShaper.o ./src/Movement/Move.o ./src/Movement/RawMove.o ./src/Movement/StepTimer.o  ./src/Linux/DataTransfer.o ./src/Linux/LinuxInterface.o  ./src/Libraries/sha1/sha1.o  ./src/Libraries/sd_mmc/ctrl_access.o ./src/Libraries/sd_mmc/sd_mmc.o ./src/Libraries/sd_mmc/sd_mmc_mem.o ./src/Libraries/sd_mmc/sd_mmc_spi.o  ./src/Libraries/Fatfs/diskio.o ./src/Libraries/Fatfs/fattime_rtc.o ./src/Libraries/Fatfs/ff.o ./src/Libraries/Fatfs/ffunicode.o  ./src/InputMonitors/InputMonitor.o  ./src/Heating/Sensors/AdditionalOutputSensor.o ./src/Heating/Sensors/CpuTemperatureSensor.o ./src/Heating/Sensors/CurrentLoopTemperatureSensor.o ./src/Heating/Sensors/DhtSensor.o ./src/Heating/Sensors/LinearAnalogSensor.o ./src/Heating/Sensors/RemoteSensor.o ./src/Heating/Sensors/RtdSensor31865.o ./src/Heating/Sensors/SensorWithPort.o ./src/Heating/Sensors/SpiTemperatureSensor.o ./src/Heating/Sensors/TemperatureSensor.o ./src/Heating/Sensors/Thermistor.o ./src/Heating/Sensors/ThermocoupleSensor31855.o ./src/Heating/Sensors/ThermocoupleSensor31856.o ./src/Heating/Sensors/TmcDriverTemperatureSensor.o  ./src/Heating/FOPDT.o ./src/Heating/Heat.o ./src/Heating/Heater.o ./src/Heating/HeaterMonitor.o ./src/Heating/LocalHeater.o ./src/Heating/RemoteHeater.o ./src/Heating/TemperatureError.o  ./src/Hardware/SharedSpi/SharedSpiClient.o ./src/Hardware/SharedSpi/SharedSpiDevice.o  ./src/Hardware/SAME70/Ethernet/ksz8081rna/ethernet_phy.o  ./src/Hardware/SAME70/Ethernet/GmacInterface.o  ./src/Hardware/SAME70/Devices.o ./src/Hardware/SAME70/Main.o  ./src/Hardware/ExceptionHandlers.o ./src/Hardware/I2C.o ./src/Hardware/IoPorts.o ./src/Hardware/NonVolatileMemory.o ./src/Hardware/SoftwareReset.o  ./src/GPIO/GpInPort.o ./src/GPIO/GpOutPort.o  ./src/GCodes/GCodeBuffer/BinaryParser.o ./src/GCodes/GCodeBuffer/ExpressionParser.o ./src/GCodes/GCodeBuffer/GCodeBuffer.o ./src/GCodes/GCodeBuffer/StringParser.o  ./src/GCodes/GCodeException.o ./src/GCodes/GCodeFileInfo.o ./src/GCodes/GCodeInput.o ./src/GCodes/GCodeMachineState.o ./src/GCodes/GCodeQueue.o ./src/GCodes/GCodes.o ./src/GCodes/GCodes2.o ./src/GCodes/GCodes3.o ./src/GCodes/GCodes4.o ./src/GCodes/ObjectTracker.o ./src/GCodes/RestorePoint.o ./src/GCodes/StraightProbeSettings.o ./src/GCodes/Trigger.o ./src/GCodes/Variable.o  ./src/FilamentMonitors/Duet3DFilamentMonitor.o ./src/FilamentMonitors/FilamentMonitor.o ./src/FilamentMonitors/LaserFilamentMonitor.o ./src/FilamentMonitors/PulsedFilamentMonitor.o ./src/FilamentMonitors/RotatingMagnetFilamentMonitor.o ./src/FilamentMonitors/SimpleFilamentMonitor.o  ./src/Fans/Fan.o ./src/Fans/FansManager.o ./src/Fans/LedStripDriver.o ./src/Fans/LocalFan.o ./src/Fans/RemoteFan.o  ./src/Endstops/Endstop.o ./src/Endstops/EndstopsManager.o ./src/Endstops/LocalZProbe.o ./src/Endstops/RemoteZProbe.o ./src/Endstops/StallDetectionEndstop.o ./src/Endstops/SwitchEndstop.o ./src/Endstops/ZProbe.o ./src/Endstops/ZProbeEndstop.o  ./src/Duet3_V06/Pins_Duet3_V06.o  ./src/Comms/AuxDevice.o ./src/Comms/FirmwareUpdater.o ./src/Comms/PanelDueUpdater.o  ./src/CAN/CanInterface.o ./src/CAN/CanMessageGenericConstructor.o ./src/CAN/CanMotion.o ./src/CAN/CommandProcessor.o ./src/CAN/ExpansionManager.o  ./src/Accelerometers/Accelerometers.o  ./src/RepRapFirmware.o   -lCoreN2G -lRRFLibraries -lFreeRTOS -lCANlib -lsupc++ -Wl,--end-group -lm
                  Finished building target: Duet3Firmware_MB6HC.elf
                  make --no-print-directory post-build
                  Generating binary file
                  arm-none-eabi-objcopy -O binary "C:\Users\Nikunj\eclipse-workspace\Firmware\RepRapFirmware\Duet3/Duet3Firmware_MB6HC.elf" "C:\Users\Nikunj\eclipse-workspace\Firmware\RepRapFirmware\Duet3/Duet3Firmware_MB6HC.bin" && crc32appender "C:\Users\Nikunj\eclipse-workspace\Firmware\RepRapFirmware\Duet3/Duet3Firmware_MB6HC.bin"
                  c:/program files (x86)/gnu arm embedded toolchain/10 2020-q4-major/bin/sh: crc32appender: not found
                  makefile:109: recipe for target 'post-build' failed
                  make[1]: [post-build] Error 127 (ignored)
                  13:25:16 Build Failed. 1 errors, 0 warnings. (took 1m:18s.336ms)
                  even thogh I've it available in PATH (C:\Users\User3D\eclipse-workspace\Firmware\RepRapFirmware\Tools\crc32appender).
                    dc42 administrators @User3D
                    Looks like you are nearly there. If you are using the file structure as on github, the path you need is:
                    C:\Users\User3D\eclipse-workspace\Firmware\RepRapFirmware\Tools\crc32appender\win-x86_64
                    • User3Dundefined
                      User3D @dc42
                      @dc42 Yo, It worked! Thank you : )
                      P.S. : I also had to copy bin of GNU ARM in GNU TOOL's bin as gnu arm eclipse was installed in program files due is 64 bits and gnu tools arm in program files x86 due is 32 bits.
