    Motors Don't Stop At End Stops
    Using Duet Controllers
    281
    • Jonathan Buildsundefined
      Jonathan Builds
      After reading through all related forum posts and troubleshooting guides, I am at a loss with setting up homing on the X and Y-axis. The motors do not stop when their corresponding end-stops are hit even though using M119 and machine properties in the web GUI, all switches are detected and functional. Any help would be much appreciated as I feel I have tried everything that can be done here. Thank you.
      Specs:
      Duet 2 Maestro 24V
      NEMA 17 steppers
      End stops from Ender 3
      Custom-built machine (900x320x500mm) x,y,z
      2 Outer pins on the Ender 3 end stop switches wired to the 2 outer pins on the board (GND & signal (ystop))
      ; Configuration file for Duet Maestro (firmware version 2.03)
      ; generated by RepRapFirmware Configuration Tool v3.2.3 on Fri Mar 26 2021 20:19:05 GMT+0000 (Greenwich Mean Time)
      M564 S0 H0
      M550 P"Ender 3 Pro" ; set printer name
      M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P3 S0 ; physical drive 3 goes backwards
      M92 X80.00 Y80.00 Z1600.00 E93.00 ; set steps per mm
      M566 X1200.00 Y1200.00 Z24.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X9000.00 Y9000.00 Z180.00 E6000.00 ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E1000 I50 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X900 Y320 Z500 S0 ; set axis maxima
      M574 X2 Y1 Z1 S1 ; set active high endstops
      M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
      M557 X15:215 Y15:195 S20 ; define mesh grid
      M140 H-1 ; disable heated bed
      M305 P1 T100000 B4092 R2200 ; set thermistor + ADC parameters for heater 1
      M143 H1 S275 ; set temperature limit for heater 1 to 275C
      M106 P0 S0 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P1 S1 I0 F500 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P2 S1 I0 F500 H1:0 T45 ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
      ; homey.g
      ; called to home the Y axis
      G91 ; relative positioning
      G1 H1 Y-325 F3000 ; move quickly to Y axis endstop and stop there (first pass)
      G1 H2 Y5 F6000 ; go back a few mm
      G1 H1 Y-325 F240 ; move slowly to Y axis endstop once more (second pass)
      G1 H2 Z-5 F6000 ; lower Z again
      G90 ; absolute positioning
        Can you send M122 and M98 P"config.g" and post the results please?
        I wonder if your firmware version matches your config.
        Jonathan Buildsundefined 1 Reply Last reply Reply Quote 0
          Jonathan Builds
            Jonathan Builds @Phaedrux
              Those warnings would indicate a mismatch between your firmware and your config.
              The config you posted is for RRF2, but it doesn't have the commands that are showing the warnings. Are you sure that the config you posted is the config you're using in the system folder?
              Your firmware is quite out of date.
              If you still have access to DWC. Upload these 3 zip files, one at a time in the system tab. Don't extract them. Reboot after each. Use M115 to verify the firmware has been applied.
              https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
              https://github.com/Duet3D/RepRapFirmware/releases/download/3.2.2/Duet2and3Firmware-3.2.2.zip
              That will get your firmware and DWC up to date.
              You can see the change logs here:
              https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x
              For your config, might be a good idea to run through the configurator tool and generate a fresh set for RRF3.
              https://configtool.reprapfirmware.org/Start
              Backup your existing config files in the sys folder in case you want to switch back to RRF3. IT’s easy to switch back and forth, just upload the zip file for the version you want and then upload your config files.
              These documents will come in handy during the conversion.
              https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview
              https://duet3d.dozuki.com/Wiki/Gcode
                @Phaedrux I have uploaded the first .zip however during the upload an error appeared saying that some files were not uploaded because they were not suitable for the board... Is this still alright?
                  Jonathan Builds
                    Yes it looks like you're on 3.2.2 now.
                    Your DWC doesn't look like it's updated yet. Or you're still using an old URL that is pointing to the older version.
                    Can you connect to DWC by just the ip address of the Duet?
                    You can check the DWC version as well in one of the tab views on DWC.
                    You can upload the 3.2.2 zip file again. Sometimes it won't all update on the first attempt.
                      @Phaedrux f30200ba-6ac7-4907-bce9-41b6b77763be-image.png M122
                      RepRapFirmware for Duet 2 Maestro version 3.2.2 running on Duet Maestro 1.0
                      Board ID: 08DJM-9X66L-LG3SN-6JTDJ-3S06Q-T8X2P
                      Used output buffers: 1 of 24 (19 max)
                      Static ram: 22284
                      Dynamic ram: 66232 of which 40 recycled
                      Never used RAM 26276, free system stack 222 words
                      Tasks: NETWORK(ready,254) HEAT(blocked,353) TMC(blocked,117) MAIN(running,498) IDLE(ready,21)
                      Owned mutexes:
                      Last reset 00:01:13 ago, cause: software
                      Last software reset details not available
                      Error status: 0x00
                      Aux0 errors 0,0,0
                      MCU temperature: min 37.2, current 37.4, max 38.1
                      Supply voltage: min 0.0, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
                      Driver 0: position 0, standstill, read errors 0, write errors 1, ifcnt 50, reads 12270, writes 6, timeouts 0, DMA errors 0
                      Driver 1: position 0, standstill, read errors 0, write errors 1, ifcnt 50, reads 12270, writes 6, timeouts 0, DMA errors 0
                      Driver 2: position 0, standstill, read errors 0, write errors 1, ifcnt 49, reads 12270, writes 6, timeouts 0, DMA errors 0
                      Driver 3: position 0, standstill, read errors 0, write errors 1, ifcnt 49, reads 12270, writes 6, timeouts 0, DMA errors 0
                      Driver 4: position 0, standstill, read errors 0, write errors 1, ifcnt 47, reads 12270, writes 6, timeouts 0, DMA errors 0
                      Driver 5: position 0, assumed not present
                      Driver 6: position 0, assumed not present
                      Date/time: 2021-03-27 17:35:43
                      Slowest loop: 98.76ms; fastest: 0.17ms
                      === Storage ===
                      Free file entries: 10
                      SD card 0 detected, interface speed: 15.0MBytes/sec
                      SD card longest read time 0.9ms, write time 95.4ms, max retries 0
                      === MainDDARing ===
                      === AuxDDARing ===
                      Bed heaters = 0 -1, chamberHeaters = -1 -1
                      Segments left: 0
                      Movement lock held by null
                      HTTP is idle in state(s) 0
                      Telnet is idle in state(s) 0
                      File is idle in state(s) 0
                      USB is idle in state(s) 0
                      Aux is idle in state(s) 0
                      Trigger is idle in state(s) 0
                      Queue is idle in state(s) 0
                      LCD is idle in state(s) 0
                      Daemon is idle in state(s) 0
                      Code queue is empty.
                      === Network ===
                      Slowest loop: 98.79ms; fastest: 0.02ms
                      HTTP sessions: 1 of 8
                      Interface state active, link 100Mbps full duplex
                        Jonathan Builds
                        5ac9972c-b988-4445-ad6e-86e8df41f990-image.png This may be the issue
                          Your DWC is still not updated. I think you will need to manually update it by pulling the SD card from the duet and using your PC to replace the /www folder.
                          Download this zip file and use it to replace the contents of the /www folder on the SD card.
                          https://github.com/Duet3D/RepRapFirmware/releases/download/3.2.2/DuetWebControl-SD.zip
                          As for your config and homing files I suggest you use the config tool linked above to generate a new set for RRF3.
                            Jonathan Builds
                            Thanks for all the help, I have now got it all updated and looks to be the new version, whole new web GUI... end stops now work perfectly, cannot thank you enough for the help. 👍
                              No problem. Glad we got you sorted.
