    The most useless warning message ever?
    Duet Web Control
    372
    • o_lampeundefined
      o_lampe
      Hi guys,
      while I tried to get my CoreXYV running, I frequently ran M98 P"config.g" to see any faults.
      One time I got a warning like " improper use of 'P' parameter" without further details. (don't remember the real words)
      I opened config.g and highlighted all 'P' characters. There were 50+... 😁
      It's like finding a needle in the hay...
      oliofundefined dc42undefined 2 Replies Last reply Reply Quote 0
      • oliofundefined
        oliof @o_lampe
        @o_lampe Time for the good old binary search. Try with only first half of config.g, if a match, first half of that; otherwise second half of original. Repeat until only one P remains (-:
        (I searched the source code for "improper" but nothing comes up. A genuine replica of the error might help pin stuff down).
          dc42 administrators @o_lampe
          @o_lampe said in The most useless warning message ever?:
          Hi guys,
          Which firmware version? Standalone or with SBC?
          • o_lampeundefined
            o_lampe @dc42
            It's RRF3.3.b2 in standalone mode, Duet2WiFi
            The error only appeared once, I had no chance to take a screenshot
              Thanks. I too searched the code base for the word "improper", and it doesn't appear anywhere. So I think it must have been a different word.
              All RRF error messages that report a problem interpreting a command also report which command (G- or M-code) it was processing at the time.
              If you get a useless error message again, please take a screen shot.
              • oliofundefined
                oliof @dc42
                Casting a wider net, I found something in Endstops/EndstopsManager.cpp in GCodeResult EndstopsManager::HandleM574. Maybe that helps (i.e., check your M574s).
                dc42undefined o_lampeundefined 2 Replies Last reply Reply Quote 0
                  dc42 administrators @oliof
                  @oliof said in The most useless warning message ever?:
                  Thanks. I found "Invalid use of P parameter" there, however if this message was produced then it should have been prefixed by "M574: ".
                  • o_lampeundefined
                    o_lampe @oliof
                    @oliof
                    Might be, I had some endstop-warning, too. But not at the same time. IIRC it claimed some endstop was already in use. But in fact it wasn't.
                    • o_lampeundefined
                      o_lampe @dc42
                      @dc42 said in The most useless warning message ever?:
                      No there was no hint of anything. No line number or G-code relation.
                      • o_lampeundefined
                        o_lampe
                        I just noticed, I had RRF3.3.b2 running, but DWC is still 3.2.
                        Could this lead to unexpected behaviour, like echos of previous reboots popping up
                        Will upgrade ASAP.
