    BLtouch acting weird
    • R3playundefined
      R3play
      So I've recently upgraded the firmware to the following:
      Board: Duet 2 WiFi (2WiFi)
      Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.1.1 (2020-05-19b2)
      Duet WiFi Server Version: 1.23
      After that I ordered myself the new bltouch v3.1... at the beginning it worked fine, but now when I power on the printer, the self-test doesn't happen and it starts flashing red.
      However, when I pull the pin down manually and then reset with M280 P0 S160 I1
      then the BLtouch behaves normally.
      What could be wrong here?
      config file:
      ; generated by RepRapFirmware Configuration Tool v3.2.3 on Mon Mar 22 2021 18:37:17 GMT+0100 (Midden-Europese standaardtijd)
      G90                                            ; send absolute coordinates...
      M83                                            ; ...but relative extruder moves
      M550 P"AM8"                                    ; set printer name
      M552 S1                                        ; enable network
      M586 P0 S1                                     ; enable HTTP
      M586 P1 S0                                     ; disable FTP
      M586 P2 S0                                     ; disable Telnet
      M569 P0 S1                                     ; physical drive 0 goes forwards
      M569 P1 S1                                     ; physical drive 1 goes forwards
      M569 P2 S0                                     ; physical drive 2 goes forwards
      M569 P3 S0                                     ; physical drive 3 goes forwards
      M584 X0 Y1 Z2 E3                               ; set drive mapping
      M350 X16 Y16 Z16 E16 I1                        ; configure microstepping with interpolation
      M92 X200.00 Y100.00 Z800.00 E402.00            ; set steps per mm
      M566 X600.00 Y600.00 Z12.00 E120.00            ; set maximum instantaneous speed changes (mm/min) JERK-900 XY
      M203 X6000.00 Y6000.00 Z180.00 E1200.00        ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z20.00 E250.00            ; set accelerations (mm/s^2) 500 XY
      M906 X800 Y800 Z800 E800 I30                   ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                        ; Set idle timeout
      M208 X-17 Y-7 Z0 S1                            ; set axis minima
      M208 X220 Y215 Z240 S0                         ; set axis maxima
      M574 X1 S1 P"xstop"                            ; configure active-high endstop for low end on X via pin xstop
      M574 Y1 S1 P"ystop"                            ; configure active-high endstop for low end on Y via pin ystop
      M950 S0 C"exp.heater3"                          ; create servo pin 0 for BLTouch
      M558 P9 C"^zprobe.in" H3 F150 T6000           ; set Z probe type to bltouch and the dive height + speeds
      ;M558 H30                                       ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
      G31 P25 X31 Y-8 Z2.44                          ; set Z probe trigger value, offset and trigger height
      M557 X15:205 Y15:205 S23.75                      ; define mesh grid
      M950 H0 C"bedheat" T0                          ; create bed heater output on bedheat and map it to sensor 0
      M307 H0 B1 S1.00                               ; enable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                        ; map heated bed to heater 0
      M143 H0 S120                                   ; set temperature limit for heater 0 to 120C
      M308 S1 P"e0temp" Y"thermistor" T100000 B4138  ; configure sensor 1 as thermistor on pin e0temp
      M950 H1 C"e0heat" T1                           ; create nozzle heater output on e0heat and map it to sensor 1
      M307 H1 B0 S1.00                               ; disable bang-bang mode for heater  and set PWM limit
      M143 H1 S280                                   ; set temperature limit for heater 1 to 280C
      M950 F0 C"fan0" Q500                           ; create fan 0 on pin fan0 and set its frequency
      M106 P0 S0 H-1                               ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"fan1" Q500                           ; create fan 1 on pin fan1 and set its frequency
      M106 P1 S1 H1 T45                              ; set fan 1 value. Thermostatic control is turned on
      M563 P0 D0 H1 F0                               ; define tool 0
      G10 P0 X0 Y0 Z0                                ; set tool 0 axis offsets
      G10 P0 R0 S0                                   ; set initial tool 0 active and standby temperatures to 0C
      M207 S4.5 F3600 Z1						; set retraction parameters
      M575 P1 S1 B57600                              ; enable support for PanelDue
      M501                                           ; load saved parameters from non-volatile memory
        Dirty pin? Removing the set screw on top lets you slide it out. Sometimes wisps of filament get stuck to it.
        Give the set screw at the top a twist to move the magnet up or down?
        R3playundefined 1 Reply Last reply Reply Quote 0
        • R3playundefined
          R3play @Phaedrux
          @phaedrux said in BLtouch acting weird:
          It's a brand new sensor, only used for 1 print...
          I'll give the set screw a try once I get home!
          • R3playundefined
            R3play @R3play
            @r3play said in BLtouch acting weird:
            Altough turning the screw seemed to be pretty hard, looks like that solved the issue.
            Thanks!
            • R3playundefined
              R3play
              Well, 2 prints later and it started doing it again.
              After a closer look at the BLTouch I noticed that the plastic pin was slightly bend causing it to get stuck on the rim of the housing.
              I removed the pin and carefully bend it back.
              Seems to be working fine now.
              Thought I would post this in case someone else experiences the same issue in the future 🙂
                Thanks for the update. Bent pin would be a good thing to check for.
