Led connect to fan ?
hello,
i try to connect the the duet wifi. in past i did it on fan2 and control the led with the slider. my question is how much power i can get from the fan output. i readed that i can only get 1a and from heater output 6a. is it possible that i connect the plus from the led to the power supply and the ground or minus the the fan connector ? -
https://duet3d.dozuki.com/Wiki/Connecting_and_configuring_fans#Section_Overview
This shows the maximum current available on the FAN connectors.
yes i know but i believe that when i connect the vin to the power supply and only ground to the fan than is more possible but i am not sure
Yes, that is right.
- Connect the power supply positive output to the LED strip positive.
- Connect the LED strip negative to the FAN- pin
- Connect the power-supply negative output to the Duet power supply negative output if they are two different supplies.
- Make sure your LED power supply voltage is not too high for the type of Duet board you are using.
