    Problem after update
    Duet Web Control
    • Tinchusundefined
      Tinchus
      Hello, I have just tried my first update attempt. I did:
      sudo apt update
      sudo apt upgrade
      After the update I did a sudo raspi-config and changed the hostname because I have 2 printers with duet 3 (both with a raspberry pi coencted with SPI method)
      Everything seems to have gone ok, at least everything finished without errors I think. I rebooted, but now the duet web control does not show up in my touch screen.
      Im able to see the printer using the new hostname through a web interface in my computer. But the DWC does not start in the printer touch screen as before.
      What can I do?
      Thanks in advance
        Phaedrux Moderator @Tinchus
        @tinchus What is the hostname of the pi itself and does it match the name set in config.g?
        https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Duet_Web_Control
        Tinchusundefined 1 Reply Last reply Reply Quote 0
        • Tinchusundefined
          Tinchus @Phaedrux
          @phaedrux There is no name in config.g file. I read somewhere than with latest version that was no necesary/or accepted. I changed the hostname using the sudo raspi-config method (and changing hostname there).
            Sorry I mistook your first post. You're saying the touch screen connected to the Pi is not displaying the DWC?
            Does it display the desktop at all? Can you launch it manually? Or are you getting errors?
