    Adjusting dual y-axis
    444
    • Kaneundefined
      Kane
      With my cnc I recently switch to FW 3.2.2 and by the way had to fit on my config.g and home configuration. I have a 2 motors belt driven y-axis with 2 independent endstops. Everything works just fine, but with the new already combined y axis, I can’t set a offset for one of the y-axis drives. If I measure after homing, I have an offset of about 1.1mm between both motors, so my gentry is not square. In RepRep FW2.. I solved the Problem before combining both axis, but know I am a little at a loss. Unlikely I didn’t found a solution in the forum jet.
        The instructions here for the Z axis and multiple endstops also applies to other axis with multiple motors and endstops.
        https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors#Section_In_RepRapFirmware_Num_3
        Kaneundefined 1 Reply Last reply Reply Quote 0
        • Kaneundefined
          Kane @Phaedrux
          @phaedrux Thank you for your very fast response. But in the text you linked I couldn't find the answer of my problem, or I don't understand how to use G30 command for equaling my y-axis.
          • Kaneundefined
            Kane
            Did anyone else have a solution for my Problem?
            here an abstract of my config.g file
            M584 X0 Y1:3 Z2 ; Apply custom drive mapping Y-Axes with two drives
            M574 Y1 S1 P"!ystop+!e0stop" ; configure active-high endstop for low end on Y via pin !ystop and e0stop Pin
            homeall.g
            G91 ; relative positioning
            G1 H1 Z200 F1200 ; move quickly to Z axis endstop and stop there (first pass)
            G1 Z-3 F150 ; go back a few mm
            G1 H1 Z200 F100 ; move slowly to X axis endstop once more (second pass)
            G1 H1 X-698 Y-355 F3000 ; move quickly to X and Y axis endstops and stop there (first pass)
            G1 H2 X5 Y5 F6000 ; go back a few mm
            G1 H1 X-698 Y-355 F360 ; move slowly to X and Y axis endstops once more (second pass)
            G90 ; absolute positioning
            nether M574 or G1 allow me to set an offset to drive 3 in example
              No in my link it was meant to show the endstop setup for homing.
              I see now that you're actually wanting to add an offset to one motor of the combined axis.
              Can you just change the physical position of the endstop or striker to change where it triggers?
              • Kaneundefined
                Kane @Phaedrux
                @phaedrux I thought I could do this in the software. Never mind i try to solve this hardware wise.
                  Well you could do it in software by using the older method from RRF2 of splitting the Y axis into separate axis for each motor and then homing them and adjusting the position of one of them before re-combining into the Y axis.
                  The RRF2 method is also described in that link above.
                  • Kaneundefined
                    Kane @Phaedrux
                    @phaedrux Ok, so I will use my old method.
                    Here the code from RRF2
                    |config.g
                    M584 X0 Y1 Z2 U3
                    M574 X1 Y1 U1 S0 ; Set active low endstops
                    M574 Z2 S0 ; Set active high endstops
                    |homeall.g
                    .... ;Z-axis stuff
                    G1 S1 Y-1500 U-1500 F2400 ; move quickly to X and Y axis endstops and stop there (first pass)
                    G1 Y+10 U+10 F2400 ; go back a few mm
                    G1 S1 Y-1500 U-1500 F300 ; move slowly to X and Y axis endstops once more (second pass)
                    G1 U+0.9 F100 ; move only U 0.9mm back so achieve squareness
                    M584 Y1:3 P3 ;combine 1 and 3 to Y
                    Here my Version for RRF3
                    |config.g
                    M584 X0 Y1 Z2 U3
                    M574 Y1 S1 P"!ystop" ; configure active-high endstop for low end on Y via pin !ystop
                    M574 U1 S1 P"!e0stop" ; configure active-high endstop for low end on U (second Y motor) via pin !e0stop
                    |homeall.g
                    .... ;Z-axis stuff
                    M584 Y1:3 ;combine drive 1 and drive 3 to one axis
                    • Kaneundefined
                      Kane
                      Sorry for my stupid post above, ist much easier than that. Fortunately my axis to adjust was y. So here my code from my homeall.g
                      M584 Y1 U3 P4        ;split y axis
                      G1 Y1.2 F100           ; drive y axis (drive 1) 1.2mm back
                      M584 Y1:3 P3          ;recombine drive 1 and 3 to y axis
