G32 Error: Bed calibration :
Hello everyone, recently I'm doing 3Z, automatic leveling, but I don't know how to solve the problem, please give me some advice
Because I don't know much English, so I use the translation software. If there are some wrong words inside, please forgive me. Thank you!
difficulty
G32
Error: Bed calibration : 3 factor calibration requested but only 0 points providedG90 ; send absolute coordinates...
M550 P"DUET2"M669 K1
M552 S1
M586 P0 S1
M586 P1 S1
M586 P2 S1M569 P0 S1
M569 P1 S1
M569 P2 S1
M569 P3 S0
M569 P4 S1
M569 P10 R1 T2.5:2.5:5:5 S0
M569 P11 R1 T2.5:2.5:5:5 S0
M584 X0 Y1 Z2:3:4 E10:11M350 X32 Y32 E16:16 I0
M350 Z16 E16 E16 I1
M92 X200.00 Y200.00 Z1600.00 E396.85:396.85
M566 X600.00 Y600.00 Z60.00 E120.00:120.00
M203 X12000.00 Y12000.00 Z180.00 E4200.00:4200.00
M201 X500.00 Y500.00 Z20.00 E1000.00:1000.00
M906 X600 Y600 Z700 E800:800 I30
M84 S30
M671 X330:-20:-10 Y-20:330:330.6; Axis Limits
M208 X-20 Y0 Z0 S1
M208 X300 Y310 Z340 S0M574 X1 S1 P"xstop"
M574 Y2 S1 P"ystop"
M574 Z1 S2M950 H3 C"nil"
M950 S0 C"exp.heater3" ;
M558 P3 C"^zprobe.in" H10 F200 T600
G31 P500 X-40 Y0 Z0.85
M557 X30:270 Y30:270 S80 P4; bed.g
G30 P2 X290 Y146.6 Z-99999 ;
G30 P3 X60 Y10 Z-99999 ;
G30 P4 X60 Y280 Z-99999 S3 ;It will not be automatically leveled after 3 coordinates are detected
Have you see the examples and instructions here?
https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors
@979044817 said in G32 Error: Bed calibration ::
; bed.g
G30 P4 X60 Y280 Z-99999 S3 ;Why do you start at P2 P3 P4. Should be P0 P1 P2
@phaedrux
Thank you for your advice! After modification, the altitude can be compensated, but the direction of compensation is reversed. The compensation of P0 should be downward but upward -
@phaedrux What should be changed?
The order of the points probed must match the order of the motors making the adjustment.
Note: If you are experiencing the Z axis compensating in the opposite direction needed, that means your Z motors are swapped. You can either swap the X values in the M671 command, or swap the stepper motors plugged into the Duet.
@phaedrux Thank you for your help. 3Z auto leveling is working now
