    Wifi error
    Firmware installation
    1.0k
    • docfailundefined
      docfail @Phaedrux
      @Phaedrux The M106 doesn't works and now my always on fan works only when jumper is on 5V, mosfets don't seems damaged, and checked with a multimeter no voltage when jumper is on 12v
        Can you post a photo of how you have the fans wired?
        What kinds of fans are they and how are you trying to use them?
        See here for more details on fans: https://duet3d.dozuki.com/Wiki/Connecting_and_configuring_fans
        docfailundefined 1 Reply Last reply Reply Quote 0
        • docfailundefined
          docfail @Phaedrux
          @phaedrux
          Red and black wire is a 12V small blower fan used for layer cooling
          White and yellow is a 12V 40mm fan used to cool the hotend
          But the problems comes very probably from the black fuse I found on documentation that it's used for Vin fans, and it's blown up...
          So I probably messed up something... I'm not really sure maybe reversed polarity with dupont wires...
          how can I get a replacement fuse ?
            The 1amp fuse can be found online or from a local car or motorcycle parts shop.
            If you can't find a 1amp fuse a larger fuse can be used, but you also reduce the protection offered. Obviously something shorted out to blow it, so be sure your wiring is correct.
            • docfailundefined
              docfail @Phaedrux
              @phaedrux I found a fuse online, it's i the mail , I'll double check my wiring and install it. So I believe there is finally no more problem .Thanks a lot for the help !!
