    Wifi error
    Firmware installation
    1.0k
      Check the setup page on the PanelDue. What firmware is installed?
      Did you try to flash it yet? What firmware version did you use? What hardware version of PanelDue is it?
      docfailundefined 1 Reply Last reply Reply Quote 0
      • docfailundefined
        docfail @Phaedrux
        @phaedrux the firmware version displayed on the panel due is 3.2.11 which is the version I flashed, my panel has a ATSAM4S4B so hardware version 3 I believe.
        also my start g code:
        M201 X500.00 Y500.00 Z100.00 E5000.00 ;Setup machine max acceleration
        M203 X500.00 Y500.00 Z10.00 E50.00 ;Setup machine max feedrate
        M204 P500.00 R1000.00 T500.00 ;Setup Print/Retract/Travel acceleration
        M205 X8.00 Y8.00 Z0.40 E5.00 ;Setup Jerk
        M220 S100 ;Reset Feedrate
        M221 S100 ;Reset Flowrate
        G28 ;Home
        G92 E0 ;Reset Extruder
        G1 Z2.0 F3000 ;Move Z Axis up
        G1 X10.1 Y20 Z0.28 F5000.0 ;Move to start position
        G1 X10.1 Y200.0 Z0.28 F1500.0 E15 ;Draw the first line
        G1 X10.4 Y200.0 Z0.28 F5000.0 ;Move to side a little
        G1 X10.4 Y20 Z0.28 F1500.0 E30 ;Draw the second line
          Phaedrux Moderator @docfail
          @docfail said in Wifi error:
          Remove those lines from your start gcode. They are over writing your settings from config.g with settings for Marlin.
          Which firmware binary specifically did you use for the PanelDue?
          If it's a 7i it should be this one: https://github.com/Duet3D/PanelDueFirmware/releases/download/3.2.11/PanelDueFirmware-5.0i-7.0i.zip
          Please try reflashing.
          • docfailundefined
            docfail
            @phaedrux ok now it work thanks !!! Before I tried using the PanelDueFirmware-v3-7.0.zip, why isn't it correct ? G code also runs at normal speed !
            I'm also using a cr10s stock layer fan but it isn't turning on, the hotend fan is working great but not this one even on the same output. Layer fan works on the psu output, could this be something pwm related ?
              No, because you have the 7i
              I don't see anything wrong in your config for fan0. Can you confirm you have it connected to the fan0 port?
              Manually send M106 P0 S1 and it should turn on. If not, check the mosfets next to the fan headers for damage.
              see example here: https://duet3d.dozuki.com/Wiki/Connector_and_spare_part_numbers#Section_Fan_mosfet
              • docfailundefined
                docfail @Phaedrux
                @Phaedrux The M106 doesn't works and now my always on fan works only when jumper is on 5V, mosfets don't seems damaged, and checked with a multimeter no voltage when jumper is on 12v
                  Can you post a photo of how you have the fans wired?
                  What kinds of fans are they and how are you trying to use them?
                  See here for more details on fans: https://duet3d.dozuki.com/Wiki/Connecting_and_configuring_fans
                  • docfailundefined
                    docfail @Phaedrux
                    @phaedrux
                    Red and black wire is a 12V small blower fan used for layer cooling
                    White and yellow is a 12V 40mm fan used to cool the hotend
                    But the problems comes very probably from the black fuse I found on documentation that it's used for Vin fans, and it's blown up...
                    So I probably messed up something... I'm not really sure maybe reversed polarity with dupont wires...
                    how can I get a replacement fuse ?
                      The 1amp fuse can be found online or from a local car or motorcycle parts shop.
                      If you can't find a 1amp fuse a larger fuse can be used, but you also reduce the protection offered. Obviously something shorted out to blow it, so be sure your wiring is correct.
                      • docfailundefined
                        docfail @Phaedrux
                        @phaedrux I found a fuse online, it's i the mail , I'll double check my wiring and install it. So I believe there is finally no more problem .Thanks a lot for the help !!
