    duel 3 mini fan
    • peter247undefined
      peter247
      O.K , Slowly wiring up my Duet 3 mini and understand the jump from the duet 2 wifi and the duet 3 mini.
      I have 24v fans same as Vin , So question 1 , What two pins do I use GND and outx- or V_outlc1 and Gnd , I think that is a lower voltage pin , But why GND and OUT minus ?.
      Question 2 , By default is the jumper set for 12v fan 3 / 4 and Vin 5/ 6 ?
      Ender 5 plus linear rail and hemera powered by duet 2 wifi , CR10s pro v1 with bltouch mostly stock , BLV mgn Cube slowly being built powered by duet 3 mini 5+
      Luke'sLaboratoryundefined 1 Reply Last reply Reply Quote 0
      • Luke'sLaboratoryundefined
        Luke'sLaboratory @peter247
        @peter247 V_outtlc1 and out- for two-wire fans that you want board PWM control on.
        There is an extra ground because out- is the side that does the switching, not the input voltage (outtlc)
        1. probably. Choose what you need
        Luke
        http://lukeslab.online
          The fans need to connect to the positive voltage side and the negative voltage side, not to ground.
          V_OUTLC1 and OUT3- for instance.
          Some examples https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+3+Mini+5++Guide+Part+1:+Wiring/87#s252
