    TempTower Temp - PrusaSlicer
    • d0minik96undefined
      d0minik96
      Hello Boys,
      when i print a TempTower i add in prusaslicer the following Gcode:
      M104 S255 in order to change my Printtemperature at a layer.
      It's not looking like the print will wait for the Temp to be reached, can you confirm this?
      Is there a M command to let the print wait for the targettemp? like M109 (for bed temp)?
      After looking in the G Code Dictionary, i am not sure if M192: Wait for Probe Temperature maybe is this command? But im not sure what is meant with probe.
      Edit: The reason i ask is, that i use a copper hotend, and i have the feeling that the temp is falling pretty slow.
      Stephen6309undefined Argoundefined 2 Replies Last reply Reply Quote 0
      • Stephen6309undefined
        Stephen6309 @d0minik96
        @d0minik96 https://duet3d.dozuki.com/Wiki/Gcode#Section_M109_Set_Extruder_Temperature_and_Wait
        Or, use G10 S### and M116.
        • Argoundefined
          Argo @d0minik96
          @d0minik96 said in TempTower Temp - PrusaSlicer:
          Are you beginning with the lowest temp?
          When printing I temp tower I usually start with the lowest temp and increase the temp at a set layer. So I don't have to worry about falling temps.
          d0minik96undefined 1 Reply Last reply Reply Quote 0
            d0minik96 @Argo
            @argo
            i print from highest to lowest. Ty for the commands 🙂
