M291 messages ignored by PanelDue
@mfs12 sorry again for my late reply, I am currently moving and it is difficult to manage work, the move and these topics at the same time.
I tried what you suggested, but all it does is delaying whatever comes after the messages by 30 seconds and still does not display the second message (M291 S1) on the PanelDue (only on DWC).
@flobler, "S1 message" is missed. This happens due to paneldue's polling interval of 500ms. If it's reduced to 250ms the "S1 message" is more likely seen. But same issue applies to DWC if a state update of the OM is missed then the message is lost.
@dc42 can this be improved on RRF side somehow so message are always catched?
@flobler all messages which don't require any confirmation may be overwritten by any following message.
So if you want to be sure to see a S1 or S0 message which may be followed by another message you best add a timeout after the message, i.e. "G4 S20".
@mfs12 I tried that previously in this thread and it did not solve the problem but just caused a 20 second wait with the S1 message still not displaying on the PanelDue.
@flobler said in M291 messages ignored by PanelDue:
I just re-tried and saw the same behavior. This is what I did:
- Test
M291 P"Do you want to load FILAMENT now? Press OK to continue or CANCEL to abort!" S3 ; requires user input to start the filament loading procedure M291 P"Loading FILAMENT..." S1 T60 ; message confirming that filament is being loaded M291 P"Do you want to load FILAMENT now? Press OK to continue or CANCEL to abort!" S3 ; requires user input to start the filament loading procedure
The initial S3 messages pops-up on the PanelDue, I press OK and the following S1 message is being ignored. Instead both PanelDue and DWC direclty jump to the next S3 message.
- Test
M291 P"Do you want to load FILAMENT now? Press OK to continue or CANCEL to abort!" S3 ; requires user input to start the filament loading procedure M291 P"Loading FILAMENT..." S1 T60 ; message confirming that filament is being loaded G4 S30 M400 M291 P"Do you want to load FILAMENT now? Press OK to continue or CANCEL to abort!" S3 ; requires user input to start the filament loading procedure
The initial S3 message pops-up on the PanelDue, I press OK and then the following S1 message is only displayed in DWC and not on PanelDue, after 30 seconds the next S3 message pops-up on both PanelDue and DWC.
Any other ideas? I am setting this back to "unresolved".
Thank you for your help
undefined flobler has marked this topic as unsolved
@flobler, i ran the following test
If macro is launched from dwc the s1 message is displayed on paneldue.
If macro is launched from paneldue the s1 message is not displayed on paneldue.M291 S3 P"S3 message" M291 S1 P"S1 message" G4 S5 M400 M291 S3 P"S3 message 2"
Log from paneldue when launched from DWC
;dbg 19 FindSeqByKey(555): key ;dbg 19 UpdateSeq(577): state 70 -> 71 ;dbg 19 UpdateSeq(577): volumes 73 -> 74 ;dbg 19 main(2375): requesting state N44 M409 K"state" F"vn"*124 ;dbg 19 ProcessReceivedValue(1563): message S3 message ;dbg 19 main(2248): message updated last action time ;dbg 20 EndReceivedMessage(973): seq state 1 DONE ;dbg 20 main(2375): requesting volumes N45 M409 K"volumes" F"v"*31 ;dbg 20 EndReceivedMessage(973): seq volumes 1 DONE N46 M409 F"d99f"*120 ;dbg 20 FindSeqByKey(555): key ;dbg 21 UpdateSeq(577): state 71 -> 73 ;dbg 21 main(2375): requesting state N47 M409 K"state" F"vn"*127 ;dbg 21 ProcessReceivedValue(1563): message S1 message ;dbg 21 main(2248): message updated last action time ;dbg 21 EndReceivedMessage(973): seq state 1 DONE N48 M409 F"d99f"*118 ;dbg 21 FindSeqByKey(555): key N49 M409 F"d99f"*119 ;dbg 22 FindSeqByKey(555): key N50 M409 F"d99f"*127 ;dbg 22 FindSeqByKey(555): key N51 M409 F"d99f"*126 ;dbg 23 FindSeqByKey(555): key N52 M409 F"d99f"*125 ;dbg 23 FindSeqByKey(555): key N53 M409 F"d99f"*124 ;dbg 24 FindSeqByKey(555): key N54 M409 F"d99f"*123 ;dbg 24 FindSeqByKey(555): key N55 M409 F"d99f"*122 ;dbg 25 FindSeqByKey(555): key N56 M409 F"d99f"*121 ;dbg 25 FindSeqByKey(555): key ;dbg 26 UpdateSeq(577): state 73 -> 74 ;dbg 26 main(2375): requesting state N57 M409 K"state" F"vn"*126 ;dbg 26 ProcessReceivedValue(1563): message S3 message 2 ;dbg 26 main(2248): message updated last action time ;dbg 26 EndReceivedMessage(973): seq state 1 DONE
Log from paneldue when launched from PanelDue
N239 M98 P"0:/macros/test-m291-s3s1-sleep.g"*41 N240 M409 F"d99f"*76 ;dbg 117 FindSeqByKey(555): key ;dbg 118 UpdateSeq(577): state 75 -> 76 ;dbg 118 UpdateSeq(577): volumes 75 -> 76 ;dbg 118 main(2375): requesting state N241 M409 K"state" F"vn"*75 ;dbg 118 ProcessReceivedValue(1563): message S3 message ;dbg 118 main(2248): message updated last action time ;dbg 118 EndReceivedMessage(973): seq state 1 DONE ;dbg 118 main(2375): requesting volumes N242 M409 K"volumes" F"v"*42 ;dbg 119 EndReceivedMessage(973): seq volumes 1 DONE N243 M409 F"d99f"*79 ;dbg 119 FindSeqByKey(555): key N244 M409 F"d99f"*72 ;dbg 120 FindSeqByKey(555): key N245 M409 F"d99f"*73 ;dbg 120 FindSeqByKey(555): key N246 M409 F"d99f"*74 ;dbg 121 FindSeqByKey(555): key N247 M409 F"d99f"*75 ;dbg 121 FindSeqByKey(555): key N248 M409 F"d99f"*68 ;dbg 122 FindSeqByKey(555): key N249 M409 F"d99f"*69 ;dbg 122 FindSeqByKey(555): key ;dbg 122 main(2229): delta 4703 state 1 ;dbg 122 main(2231): pressed N250 M292 P0*109 N251 M409 F"d99f"*76 ;dbg 123 FindSeqByKey(555): key ;dbg 123 UpdateSeq(577): state 76 -> 78 ;dbg 123 main(2375): requesting state N252 M409 K"state" F"vn"*73 ;dbg 124 FindSeqByKey(555): key ;dbg 124 main(2375): requesting state N253 M409 K"state" F"vn"*72 ;dbg 125 FindSeqByKey(555): key ;dbg 125 main(2375): requesting state N254 M409 K"state" F"vn"*79 ;dbg 126 FindSeqByKey(555): key ;dbg 126 main(2375): requesting state N255 M409 K"state" F"vn"*78 ;dbg 127 FindSeqByKey(555): key ;dbg 127 main(2375): requesting state N256 M409 K"state" F"vn"*77 ;dbg 127 FindSeqByKey(555): key ;dbg 128 UpdateSeq(577): state 78 -> 79 ;dbg 128 ProcessReceivedValue(1563): message S3 message 2 ;dbg 128 main(2248): message updated last action time ;dbg 128 EndReceivedMessage(973): seq state 1 DONE ;dbg 128 ProcessReceivedValue(1563): message S3 message 2
To conclude, the sequence number on RRF side increment and when the state seq request is executed the S1 message is not delivered from RRF. To me it looks like an issue on RRF side.
I have to talk to @dc42 about this.
@flobler, good news. It looks like we understood the problem so there might be a solution in reach.
@mfs12 awesome, thank you very much for investigating!
@mfs12 Is this the issue we are talking about here?
https://github.com/Duet3D/PanelDueFirmware/issues/239 -
@mfs12 it looks like upgrading everything to 3.4.0 fixed this for me and all messages are now displayed as they should
thank you very much for your help along the way!!!
undefined flobler has marked this topic as solved
