    RPI4 cannot start if DUET3 is powered
    • psychotik2k3undefined
      psychotik2k3
      Hi , i have a duet 3 and a rpi4, everything is configured but i noticed this:
      (nota the rpi4 is in a argon case)
      the 5v jumpers are configured only in internal 5v, no other jumper.
      and i noticed this: if i power up the duet 3 then power up the rpi4 the rpi seems to do nothing no boot, but as soon as i shutdown the power of the duet the RPI boots up.
      and if i power up the rpi with the duet unpowered then the RPI boots correctly.
      any idea ?
        Phaedrux Moderator @psychotik2k3
        @psychotik2k3 said in RPI4 cannot start if DUET3 is powered:
        Which argon case is that? Is it the one that has a PCB to extend the GPIO header and has fan control and a power button? If so you might not be able to use that case.
        psychotik2k3undefined 1 Reply Last reply Reply Quote 0
          psychotik2k3 @Phaedrux
          @phaedrux yes this is this one. why should i not use it ?
          it does not extend GPIO, the bord extend the and regroups the HDMI and power on teh same side as USB but GPIO is still on the top untouched
            The GPIO is not untouched. The HDMI etc is a separate PCB yes, but the GPIO pins are extended by the case. If it's the same one I'm thinking.
            I have the same case and wasn't able to get it to work, but I'm not entirely sure why. I just use that case for a different pi project that could better use the cooling.
            If you want to try using that case we can try digging deeper on why it doesn't work the same.
              @phaedrux yes you're right gpio is extended and power seems to go the GPIO too.
              just tried to set the jumper in allways on mode so i bypass the swithc but it d'ont change anything. send a mail to argon to ask why i have this behaviour.
