Displaying Water Temp. Virtual Heater Help
@phaedrux update commands Via SSH or in the DWC console?
the sudo commands are for the pi, the M997 B1 is for the Duet firmware. Send accordingly.
@phaedrux that's what I thought, trying right now.
@phaedrux that did the trick B1 is on 3.2.2! Thank you!
Which command worked to update it by the way?
@phaedrux well to be honest I believe it was the M997 B1. Because I had previously been on 3.2.2 on the mainboard and did the ssh Sudo upgrade stuff in the pi and it did not change to a newer version on the mainboard. But I did do both, so I don't know with 100% certainty, apologies.
