    tool position freeze (3.2.2)
    Duet Web Control
    740
    • Pseud3mysundefined
      Pseud3mys
      Hi !
      I just update to 3.2.2 (https://github.com/Duet3D/RepRapFirmware/releases/tag/3.2.2) and I have some bugs with the web interface:
      • the mode stay to "FFF" even when I try to put in into CNC with:
      M453 C"!out9" F100 T2 R12000
      • the coordinate freeze, I can move the axis but it stay to the same position. I need to refresh the google tab to have the correct value, but it still freeze if I move after.
      I run a M122:
      M122
      RepRapFirmware for Duet 3 MB6HC version 3.2.2 running on Duet 3 MB6HC v1.01 or later (standalone mode)
      Board ID: 08DJM-956BA-NA3TJ-6J1D2-3SD6M-9B9LT
      Used output buffers: 1 of 40 (13 max)
      Static ram: 149788
      Dynamic ram: 93284 of which 60 recycled
      Never used RAM 115700, free system stack 159 words
      Tasks: NETWORK(ready,189) ETHERNET(blocked,110) HEAT(blocked,282) CanReceiv(blocked,848) CanSender(blocked,352) CanClock(blocked,352) TMC(blocked,51) MAIN(running,1107) IDLE(ready,19)
      Owned mutexes:
      Last reset 00:03:21 ago, cause: software
      Last software reset at 2021-04-15 17:13, reason: User, GCodes spinning, available RAM 115684, slot 2
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0044a000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a
      Error status: 0x00
      Aux0 errors 0,0,0
      Aux1 errors 0,0,0
      MCU temperature: min 41.7, current 43.0, max 44.6
      Supply voltage: min 27.9, current 35.9, max 36.0, under voltage events: 0, over voltage events: 0, power good: yes
      12V rail voltage: min 12.0, current 12.1, max 12.1, under voltage events: 0
      Driver 0: position 125000, standstill, reads 31113, writes 11 timeouts 0, SG min/max 0/0
      Driver 1: position 0, standstill, reads 31113, writes 11 timeouts 0, SG min/max 0/0
      Driver 2: position 58750, standstill, reads 31113, writes 11 timeouts 0, SG min/max 0/0
      Driver 3: position 0, standstill, reads 31113, writes 11 timeouts 0, SG min/max 0/0
      Driver 4: position 0, standstill, reads 31114, writes 11 timeouts 0, SG min/max 0/0
      Driver 5: position 0, standstill, reads 31114, writes 11 timeouts 0, SG min/max 0/0
      Date/time: 2021-04-15 17:17:14
      Slowest loop: 7.02ms; fastest: 0.10ms
      === Storage ===
      Free file entries: 9
      SD card 0 detected, interface speed: 25.0MBytes/sec
      SD card longest read time 2.4ms, write time 3.1ms, max retries 0
      DMs created 125, maxWait 49455ms, bed compensation in use: none, comp offset 0.000
      === MainDDARing ===
      Scheduled moves 8, completed moves 8, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 2], CDDA state -1
      === AuxDDARing ===
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is idle in state(s) 0
      Aux2 is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 6.76ms; fastest: 0.02ms
      Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions Telnet(0), 0 sessions
      HTTP sessions: 1 of 8
      - Ethernet -
      State: active
      Error counts: 0 0 1 0 0
      Socket states: 5 2 2 2 2 0 0 0
      === CAN ===
      Messages queued 851, send timeouts 0, received 104, lost 0, longest wait 1ms for reply type 6018, free buffers 48
      How can I fix those please ?
      Thanks for your answers !
        Pseud3mys
        I found what start the bug, it is this line in the config file:
        M558 P8 K2 C"^!125.io0.in" F300 T3000
        I wanted to make a Z probe for a toolboard.
        Do you see what is bad in this line ?
          @pseud3mys said in tool position freeze (3.2.2):
          Doi you get any error message if you send that command from the DWC console?
          Do you have a tool board at CAN address 125 ?
          Pseud3mysundefined 1 Reply Last reply Reply Quote 0
            Pseud3mys @dc42
            @dc42 No I don't get error message and yes I have a toolboard at can 125:
            M115 B125
            Duet TOOL1LC firmware version 3.2.2 (2021-02-12)
            The freeze append instantly after I send the command in the console, I try to delete it from the config file (the coordiante and mode were correctly updated) and when I send it to the command in the console the coordinate freeze.
              dc42 administrators @Pseud3mys
              I've just tried running that command on my system, with the address changed to 121 because that is where my tool board is, and it is working for me. However, I am running firmware based on version 3.3beta2. Please can you test whether the problem still occurs after you upgrade the main board and tool board firmware to 3.3beta2.
              Pseud3mysundefined 3 Replies Last reply Reply Quote 0
                Pseud3mys @dc42
                This post is deleted!
                  Pseud3mys @dc42
                  @dc42 I updated the boards to 3.3beta2 but is still freeze (I have the web interface 3.2.2).
                  Is there an other way to create a pin for a Z probe (it is a simple button) ?
                    Pseud3mys @dc42
                    @dc42 rerefind what go wrong, it is the K parameter
                    this work fine:
                    M558 P8 C"^!125.io0.in" F300 T3000
                    and this start the freeze thing:
                    M558 K1 P8 C"^!125.io0.in" F300 T3000
                    In fact this paramerter is not in the M558 doc:
                    https://duet3d.dozuki.com/Wiki/Gcode#Section_M558_Set_Z_probe_type
                    but in this section it is given as an exemple:
                    https://duet3d.dozuki.com/Wiki/Gcode#Section_M585_Probe_Tool
                    New code:
                    M558 K1 P5 C"!e0stop" ; create probe #1 for use with M585, active low
                    M585 X100 F600 P1 S0 ; probe X until probe #1 is triggered
                      @pseud3mys, please share your complete config.g file.
                        Phaedrux Moderator @Pseud3mys
                        YOu may also need DWC to match.
                        https://github.com/Duet3D/RepRapFirmware/releases/download/3.3beta2/DuetWebControl-SD-3.3b2.zip
                        Pseud3mysundefined 2 Replies Last reply Reply Quote 0
                          Pseud3mys @dc42
                          @dc42 , this is my config file for 3.3beta2 with a little change for 3.3beta2
                          G90                                                          ; send absolute coordinates...
                          M83                                                          ; ...but relative extruder moves
                          M550 P"MultiTool Cartesian"                                  ; set printer name
                          ;emergency stop !
                          M950 J0 C"^io0.in"
                          M581 P0 T0 S1 R0
                          M552 P0.0.0.0 S1                                             ; enable network and acquire dynamic address via DHCP
                          M586 P0 S1                                                   ; enable HTTP
                          M586 P1 S0                                                   ; disable FTP
                          M586 P2 S0                                                   ; disable Telnet
                          G4 S1   ;wait for expansion boards to start
                          ; Extruders
                          M569 P121.0 S1 D3 V2000	; ToolBoard drive 121.0 goes forwards
                          M569 P122.0 S1 D3 V2000	; ToolBoard drive 122.0 goes forwards
                          M584 E121.0:122.0       ; set extruders drivers
                          M350 E64:64 I0          ; configure microstepping without interpolation for extruder
                          ; speed
                          M92 E415.00:415.00		; set steps per mm
                          M203 E1200.00:1200.00	; set maximum speeds (mm/min)
                          M201 E250.00:250.00		; set accelerations (mm/s^2)
                          M566 E120.00:120.00		; set maximum instantaneous speed changes (mm/min)
                          M906 E800:800			; set motor currents (mA)
                          G10 L2 P1 X0.00 Y0.00 Z0.00 ;reset the 1st coordinate system to coorspond to the machine one
                          ;XYZ axis
                          M569 P41.0 S1 R0 T2.6:2.6:0:5	; X
                          M569 P40.0 S0 R0 T2.6:2.6:0:5	; Y
                          M569 P42.0 S0 R0 T2.6:2.6:0:5	; Z
                          M584 Y40.0 X41.0 Z42.0			; set Y, X and Z drivers
                          ;speed
                          M92 X125.00 Y125.00 Z125.00 		; step per mm
                          M203 X19200.00 Y19200.00 Z15000.00 	; maximum speeds (mm/min)
                          M566 X900.00 Y900.00 Z900.00 		; maximum instantaneous speed changes (mm/min)
                          M201 X1500.00 Y1200.00 Z800.00 		; accelerations (mm/s^2). théorical max: 6400
                          M84 S0	; Disable motor idle current reduction
                          M208 X0 Y0 Z0 S1                                             ; set axis minima
                          M208 X1000 Y950 Z500 S0                                     ; set axis maxima
                          ;alarms
                          ;X axis fail
                          M950 J10 C"41.io2.in" ; create a GPIO pin number 2 on 1XD board at CAN address 41 for alarm reset
                          M581 P10 S0 T10 ; invoke trigger 10 when an active-to-inactive edge is detected on input 10
                          ;Yaxis fail
                          M950 J11 C"40.io2.in" ; create a GPIO pin number 2 on 1XD board at CAN address 40 for alarm reset
                          M581 P11 S0 T11 ; invoke trigger 11 when an active-to-inactive edge is detected on input 11
                          ;Z axis fail
                          M950 J12 C"42.io2.in" ; create a GPIO pin number 2 on 1XD board at CAN address 42 for alarm reset
                          M581 P12 S1 T12 ; invoke trigger 12 when an inactive-to-active edge is detected on input 12
                          M574 X2 S1 P"41.io1.in"
                          M574 Y1 S1 P"40.io1.in"
                          M574 Z2 S1 P"42.io1.in"
                          ; Spindle board Z probe
                          ; ! All work fine without this line:
                          ; M558 P8 K2 C"^!125.io0.in" F300 T3000
                          M308 S0 P"temp0" Y"thermistor" T100000 B4138		; configure sensor 0 as thermistor on pin temp0
                          M950 H0 C"out0" T0                                  ; create bed heater output on out0 and map it to sensor 0
                          M307 H0 B0 S1.00                                    ; disable bang-bang mode for the bed heater and set PWM limit
                          M140 H0                                             ; map heated bed to heater 0
                          M143 H0 S120                                        ; set temperature limit for heater 0 to 120C
                          ; configure sensor 1 as thermistor on pin 121.temp0
                          M308 S1 P"121.temp0" Y"thermistor" T500000 B3600 C1.196220e-7 H-12
                          M950 H1 C"121.out0" T1		; create nozzle heater output on 121.out0 and map it to sensor 1
                          M307 H1 B0 S0.35            ; disable bang-bang mode for heater  and set PWM limit
                          M143 H1 P1 S285 A0 			; raise a heater fault if it exceeds 285C
                          ; configure sensor 2 as thermistor on pin 122.temp0
                          M308 S2 P"122.temp0" Y"thermistor" T500000 B3600 C1.196220e-7 H-15 L-12
                          M950 H2 C"122.out0" T2      ; create nozzle heater output on 122.out0 and map it to sensor 2
                          M307 H2 B0 S0.35            ; disable bang-bang mode for heater  and set PWM limit
                          ; Fans de hotend
                          M950 F0 C"121.out2" Q500                                     ; create fan 0 on pin 121.out2 and set its frequency
                          M106 P0 S0 H1 T45 L255										 ; set fan 0 value. Thermostatic control is turned on (ON/OFF, no PWM)
                          M950 F1 C"122.out2" Q500                                     ; create fan 1 on pin 122.out2 and set its frequency
                          M106 P1 S0 H2 T45 L255                                      ; set fan 1 value. Thermostatic control is turned on (ON/OFF, no PWM)
                          ; Fans de filaments
                          M563 P0 S"Extrudeur 0" D0 H1 F0                              ; define tool 0
                          G10 P0 X0 Y0 Z0                                              ; set tool 0 axis offsets
                          G10 P0 R0 S0                                                 ; set initial tool 0 active and standby temperatures to 0C
                          M563 P1 S"Extrudeur 1" D1 H2 F1                              ; define tool 1
                          G10 P1 X0 Y0 Z0                                              ; set tool 1 axis offsets
                          G10 P1 R0 S0                                                 ; set initial tool 1 active and standby temperatures to 0C
                          ; !! for version 3.3
                          M950 R0 C"!out9" L12000 ; Create spindle index 0, with PWM pin on heater 3 and 12000 RPM achieved at full PWM
                          M563 P2 S"Spindle" R0 ; Create tool 1 with spindle 0 and call it "Spindle"
                          ; !! version 3.x
                          ; M563 P2 S"Spindle" F-1                                       ; define tool 2
                          ; M453 C"!out9" Q100 T2 R12000
                          G10 P2 X0 Y0 Z0                                              ; set tool 2 axis offsets
                          M5
                          ; relay spdindle activation
                          M950 P8 C"out4"	; create output
                          M42 P8 S0	; desactivate it
                          ;M563 P3 S"Laser" F-1                                        ; define tool 3
                          ;G10 P3 X0 Y0 Z0                                             ; set tool 3 axis offsets
                          ; Triggers
                          ; extrudeur 0 and 1 toolboard
                          M950 J2 C"!121.button0"
                          M581 P2 T2 S0
                          M950 J3 C"!121.button1"
                          M581 P3 T3 S0
                          M950 J4 C"!122.button0"
                          M581 P4 T4 S0
                          M950 J5 C"!122.button1"
                          M581 P5 T5 S0
                          ; spindle board:
                          M950 J6 C"!125.button0"
                          M581 P6 T6 S0
                          M950 J7 C"!125.button1"
                          M581 P7 T7 S0
                          M501                                                         ; load saved parameters from non-volatile memory
                          M929 P"logs/log.txt" S1 ; start log
                            Pseud3mys @Phaedrux
                            @phaedrux okay thank you, I will make the complete update.
                              Pseud3mys @Phaedrux
                              @phaedrux the bug stay the same in 3.2.2 or in 3.3beta2 (with the right DWC version). It is the all "status" box how freeze (the status "idle" don't go to "busy", speed and coordinates don't change) just the sensors part is not impacted.
                                @pseud3mys, I'm running your config.g file with tool boards at addresses 121 and 125. I sent G92 X0 Y0 Z0 to pretend-home the printer. I un-commented the M558 K2 line.
                                When I command movement in X and/or Y and/or Z, the status goes busy for a short while and the coordinates in the display change as expected.
                                I am running in standalone mode using the main board firmware, tool board firmware and DWC at https://www.dropbox.com/sh/dupd9u1xppr1om5/AADYg4guuj2n8LJokVqtK-C7a?dl=0. Please try those files.
                                  Pseud3mys
                                  @dc42 I change the firmawre and DWC with your files and I try with my setup (3 extarnals drivers boards (CAN 40, 41, 42) and one toolboard with CAN 125) in standalone but only the busy status goes fine, the coordinate and speed still freeze after I send exactly this command (the same that in the config.g file).
                                    Pseud3mys @dc42
                                    @dc42 To overcome this issues I use the 3.3beta2 metacommand:
                                    ; in my config.g file:
                                    M950 J8 C"^!125.io0.in"
                                    ; in a macros:
                                    G91
                                    while sensors.gpIn[8].value == 0 ; this loop run fine
                                    	G1 Z-0.01 F500
                                    G0 Z20 F300
                                    M400
                                    	G1 Z-0.01 F100
                                    G90
                                    And I have one question:
                                    • and after, can this replace a Z probe ? did the loop will stop at the exact moment the button is closed (with this 0.01 resolution) ?
                                    Thank you for your time and help !
                                      Pseud3mys @Pseud3mys
                                        I managed to reproduce this by sending the command again. The Object Model browser reports the positions correctly, so this appears to be a bug in DWC. One for @chrishamm. https://github.com/Duet3D/DuetWebControl/issues/357
                                        I found a workaround: create Z probe 0 as well.
                                        dc42 created this issue in Duet3D/DuetWebControl
                                        closed Tool position coordinates freeze if you have Z probe #2 but not #0 #357
                                          Pseud3mys @dc42
                                          @dc42 ok thank you !
