    Duet 2 wifi board bricked
    duet2 wifi duet2wifi
    • danielmar90undefined
      danielmar90
      Hi all. I need you help if possible.
      Mu printer works fine for around a year. Yesterday I've started another print after one was done and printer just freeze. Panel due didn't respond for any commands. Board doesn't start after restart it, WiFi led is off all the time. 5V and 3.3V led is on, diag led is constantly lit. I tried connect it to pc but my pc is not detecting it, so I tried with other 2 pc's and same problem, so I can't even upgrade firmware, I also tried to use erase pins tens times without success, reset button also not working. Here is a video. I have tried also change sd card, and tried to turn it on wit or without sd card nothing changed.
      https://drive.google.com/folderview?id=14i4SGier2PTxSpmZJ1VWIQZtTBinCvwE
        Your video is private and I cannot access it.
        Can you go through these troubleshooting steps and see how far you can get?
        https://duet3d.dozuki.com/Wiki/What_to_do_if_your_Duet_won't_respond
